The commentators so far are referring to the excellent advantages of
the wet pump for IFR. Far as I know, none of the separators work very well with negative Gs. I have a wet pump and the Walker (airwolf now) and if I do a 0 G parabaloa, I get oil all over the belly. If you are doing both acro and ifr, the dry pump might be better. Bill Hale Loveland CO |
One thing about oil seperators. They collect water. Water freezes. Then
they don't let the crankcase breathe at all. This is for some installations, some are in a warm spot. Depends. Keep an eye on it. |
From what I understand, not only does the wet pump last MUCH longer,
but when it dies, it dies gradually rather than going belly up while you are in a cloud, on an NDB approach, one very dark night. I fly hard IFR and would never give up my wet pump. Helen |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 08:08 PM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Wet Vacuum Pump | smackey | Owning | 6 | February 24th 04 07:03 PM |
Battery and Vacuum pump | PaulaJay1 | Owning | 3 | January 16th 04 04:22 PM |
