EDM 700 works great for me. Just upgraded it with fuel flow - very nice.
How does the "fuel flow" option work? Where is the sensor and what does it measure? www.Rosspilot.com |
![]() "Rosspilot" wrote: EDM 700 works great for me. Just upgraded it with fuel flow - very nice. How does the "fuel flow" option work? Where is the sensor and what does it measure? It's a paddle wheel-type transducer that is cut into a fuel line. It measures actual gallons per hour. I bought that option on my EDM 700 and I'm glad I did. It is quite accurate; if it says I've burned 40 gallons, the pump will say 39 when I top off, a 2.5% error. The unit has a software "K factor" I could change to tune that out, but since it errs on the "safe" side I haven't bothered. I'm blessed with one of the few Cessnas that have accurate fuel gauges, so I'm able to cross check them with the EDM 700 and vice versa. The fuel flow reading is also a useful leaning tool. I know the fuel flows for my typical altitudes and power settings, so there's no hunting around with the mixture control when I level off in cruise. The EDM 700 is also RS-232 interfaced to my B/K GPS, so I get nmpg, range, endurance, etc. on both units--very cool. -- Dan C-172RG at BFM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
