Thanks for the thoughtful response. Using google, I found the citation for
the article to which you referred on the FAA web site: Bryan, L.A., Stonecipher, J.W., and Aron, K. (1954). 180-degree turn experiment. University of Illinois Bulletin, Aeronautics Bulletin Number 11. The current Boeing chairman is Harry C. Stonecipher, not the same person but possibly related as you said. It's a cliche, but I really regarded the private certificate as a license to learn. I got it at 70 hours, and have had no passengers until recently (a little over 200 hours). I've spent the intervening time practicing all the various PTS maneuvers (solo stalls were a little intimidating at first!), becoming more comfortable with talking to ATC, studying navigation, building the 50 hrs of cross country time for the instrument rating, attending FAA safety seminars, etc. My field is only 10 minutes away, so I can usually schedule a plane at the last minute. Nonetheless, I've cancelled due to marginal weather conditions on a number of occasions, and have not regretted even the instances when the weather actually improved. All this is a long winded way of agreeing with you that I think the IR is also merely a license to learn. I wouldn't be eager to attempt an approach at minimums the day after getting IR, accelerated or not. I'll check out Maury's West Coast Adventures--thanks for the tip. |
Wow! Good research. I've got a hard copy of it around here somewhere,
but after three moves, only God knows *where* around here. You will find that the conditions used in the study were actually a little extreme; the test aircraft was a high-perf retract, (Bonanza, i think), and the did not give them an AI. The theory was to develop a survival procedure that would work in any airplane, including those not equipped with an AI. I suspect that if the experiment were repeated using a 172 with an AI you would get better results--but not that much better, maybe a 30% survival rate rather than 0%. However, those results would, I think, be unrealistically optimistic; the uncontrolled variable is the stress factor. A private pilot in a study, under the hood, in VMC, with an instructor next to him knows that if he really screws it up the worst that is going to happen is he 'fails' the test. His life is not really at risk, and he knows it. Put that same private pilot in a 172, solo, or with non-pilot passengers, in IMC, with a little turbulence and I think the stress level will be *enormous.* If you could do a study where the pilot was convinced that it was real IMC, with real rocks below, no instructor, and no help available, then you might see some results that have validity. Listen to the guy's voice on the 17 ways tape and tell me what you think. Gene |
![]() "Joe Johnson" wrote in message ... I'll check out Maury's West Coast Adventures--thanks for the tip. Actually, it's Morey...Field Morey. His site is he http://www.ifrwest.com/ |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Germany Lost the War... So What? | robert arndt | Military Aviation | 55 | February 26th 04 08:51 AM |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 03:09 AM |
