Auto conversions & gear boxes
Old February 23rd 04, 11:40 PM
x
of one would resonate with the third harmonic of the other. But a
propeller and an engine are nowhere close to identical; their resonant
frequencies don't have anything to do with each other in the first place,
What resonance characteristics does a propeller have, and why?
so there's no point in trying to do anything to throw them out of match
with each other. (Unless you get unlucky; if resonance problems show up
in testing, then you can try re-machining one of the belt pulleys to a
Old February 25th 04, 07:43 PM
Norman Yarvin
Anything that is solid vibrates, and has resonant frequencies.
Beyond that, I haven't done any detailed analysis.
Norman Yarvin http://yarchive.net
Auto Alternator on an O-320-E2D Ebby Home Built 8 November 26th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
