Archer Tach Red Arc
Old January 18th 05, 03:04 AM
BTIZ
does this archer have the standard engine installed?? then I would not think
that there was an RPM limitation.. if there was an STC for a larger or
different engine prop combination, then that may require the red arc area...
and I agree.. this sounds like something from an Arrow with 3 prop blades..
if there is no documentation of the requirement in the aircraft logs.. then
it is an improper marking on the glass face..
BT
"Greg Esres" wrote in message
A student has an Archer II that has a red arc painted on the glass of
the tach between 2150 and 2350 RPM. The POH makes no mention of a red
arc.
I'm thinking that either the tach came out of an Arrow (which has a
red arc in this range) or some A&P confused the Archer with an Arrow
and painted it on.
Does anyone know of any legitimate reason for an Archer to have a red
arc, other than max RPM?
Old January 18th 05, 03:26 AM
Roger
On Mon, 17 Jan 2005 19:04:04 -0800, "BTIZ"
I thought you went to the 3-blade to get rid of the red arc, at least
that's what they said in an article on the conversion a few years
back.
OTOH I've never seen a Cherokee or Archer with the RPM range
limitation. Only an Arrow, but are at least two or three of them I've
probably missed:-))
www.rogerhalstead.com.
Old January 18th 05, 04:57 AM
Check the FAA Type Certificate Data Sheets for the Pipers.
You will probably find the prop combination liisted with a note
about the tach marking.
If the prop was a result of an STC, it may not be listed. But
I think I've seen new Pipers with tachs like this.
Probably depends on what dampers are on the engine which
would be indicatded by the engine dash number.
Bill Hale A&P
Old January 18th 05, 04:46 AM
Greg Esres
I think so.
if there was an STC for a larger or different engine prop
I'll have to check the logs.
I believe that it's the Arrow 2-blade that has the limitation. We
have one with 3 blades that the mechanic says doesn't need the red
arc, but they left it on anyway.
Thanks
Tachometer or Tach Cable Rich Owning 14 October 14th 04 02:54 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Wayward Tach O. Sami Saydjari Owning 7 February 6th 04 01:27 AM
Tach Vs. Hobbs Time John Roncallo Owning 33 January 7th 04 12:42 AM
Need new PA28 tach Michael Isaksen Owning 2 October 2nd 03 03:27 PM
