Engine Preheater - any good?
Old January 30th 05, 02:02 AM
Matt Barrow
"Rosspilot" wrote in message
. After 3 hours, it's ready
to go.
3 Hours? Way too long.
I still use (and love) my trusty Red Dragon.
Last Friday it was 6 degrees when I had to do a shoot . . . preheated for
an
hour and ready to go . . . warm as toast.
I believe such products (this thing, Reiff, Tanis) are for over-night warm
ups, not spur of the moment.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old January 30th 05, 03:37 PM
PaulaJay1
In article , "Matt Barrow"
writes:
Why so? I find that my Tannis does a pretty good job after and hour or two.
After all, you don't have to get the engine up to operating temp. If I have
raised the engine temp 20 or 30 deg I have done a lot of good.
Chuck
Old January 31st 05, 01:51 AM
Matt Barrow
"PaulaJay1" wrote in message
writes:
warm
two.
have
Same with my Reiff. But around here, quite often, raising the temp 20
degrees would still not have it above freezing. :~(
Every little bit helps, even the old "light bulb in the engine compartment".
Thanks, but as so many have pointed out, you do more damage to an engine in
the first minutes of a very cold start than in 100 hours (or so) of cruising
at high speed.
For a turbo'ed (or turbonormalized) plant, the effect can be even more
devastating.
It's also nice to come into an engine compartment that's 80 degrees and have
the cabin heater kick out nice warm air from the 'git go.
Once again, every little bit helps.
Old January 31st 05, 12:07 AM
Rosspilot
an
I am tied down outside--no hangar, no power. I've had a Tanis heater since
owning the plane (it came with it) but it's useless to me.
www.Rosspilot.com
Old January 31st 05, 02:47 PM
Bob Chilcoat
Lee,
We're tied down outside, too, but we recently scored a tiedown next to a new
hangar when it was put up and several of the tiedowns (ours included) were
moved. The new hanger has outside power outlets five feet from our wingtip!
That's the main reason we're thinking about a simple preheater - nearby
power.
We would have had to run an extension cord across a taxiway where we were
before. Not practical.
Bob (Chief Pilot, White Knuckle Airways)
for
an
warm
since
www.Rosspilot.com
Mooney Engine Problem in Flight - Advise Paul Smedshammer Owning 17 December 21st 04 06:39 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
