kage wrote:
It wasn't a "Bottom overhaul." It was a prop strike inspection. The case would need to be overhauled along with at least the oil pump, plus other stuff they don't touch. That's what I was thinking. Actually, I think a prop strike inspection on a Lycoming mostly consists of inspecting the gears inside the accessory case, but they may have magafluxed the crank, too. Otherwise, they just reassembled it with the same parts they disassembled it with. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Jay Masino wrote:
: case, but they may have magafluxed the crank, too. Otherwise, they just : reassembled it with the same parts they disassembled it with. Except some things which must be replaced... like connecting rod bolts. Main bearings? Seems pretty silly to me to not do the slight bit more work to get an overhaul... basically just some magnafluxing of the steel parts is all. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
