Skycraft Landing Light Question
Old February 2nd 05, 01:12 PM
Jay Honeck
Default Skycraft Landing Light Question
I'm in the midst of having these lights installed, (they are the
cut-in-the-leading-edge landing lights) and we come to a fork in the road
with regards to the wiring.
The kit comes with a split L/R on/off switch, and two 10 amp circuit
breakers. This means that my existing landing light switch stays in the
panel, controlling the nose light only, while this new switch has to go in
the panel somewhere, separately controlling EACH wing light.
IMHO, this is stupid. Why would I *ever* want to turn on, for example, only
the left landing light? My idea is to replace the existing landing light
switch with the new split switch, and put the nose light on the left half,
while putting BOTH wing lights on the right half of the switch. (This
would require a 20 amp breaker on the right half of the circuit, instead of
the 10 amp that is supplied.)
My A&P says Skycraft's STC doesn't cover that option, and he would have to
get a field approval, blah, blah, blah. His idea is to remove my pitot
heat switch from the little "bank" of switches on my 235, and install the
new split landing light switch in its place. This will put it right next to
the existing nose light switch, so turning on the landing light(s) will be
almost as simple as it is now (or would be with my idea).
The pitot heat switch would then be relocated in the plane, somewhere.
This is obviously better than installing the landing light switch in some
awkward place, but it still seems goofy to me.
What do you guys think? Anyone ever installed these things? What did you
do with the switches?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 2nd 05, 01:16 PM
Darrel Toepfer
A relay with the proper approvals would work all the lights from a
single switch... Look at the anticollision people that make the lights
rotate in sequence, those are solid-state controlled...
Old February 2nd 05, 03:40 PM
Mike Rapoport
Make sure that the switch is up to the job of running both lights off one
side. You may want a relay somewhere. You don't double the CB rating
either. The CBs are there to protect the wiring and you have two wires
going to different places. If you go to one CB, it has to pop if *either*
the L or R circuit shorts. You could use a single 20A CB if you use heavier
wire from the CB to both lights.
Mike
MU-2
"Jay Honeck" wrote in message
news:Gk4Md.43024$IV5.24943@attbi_s54...
only the left landing light? My idea is to replace the existing landing
light switch with the new split switch, and put the nose light on the left
half, while putting BOTH wing lights on the right half of the switch.
(This would require a 20 amp breaker on the right half of the circuit,
instead of the 10 amp that is supplied.)
to the existing nose light switch, so turning on the landing light(s) will
be almost as simple as it is now (or would be with my idea).
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 2nd 05, 04:01 PM
Aaron Coolidge
Jay Honeck wrote:
: I'm in the midst of having these lights installed, (they are the
: cut-in-the-leading-edge landing lights) and we come to a fork in the road
: with regards to the wiring.
: The kit comes with a split L/R on/off switch, and two 10 amp circuit
: breakers. This means that my existing landing light switch stays in the
: panel, controlling the nose light only, while this new switch has to go in
: the panel somewhere, separately controlling EACH wing light.
Every airplane that I have seen with these lights has had the centerline
cowl mounted landing light removed and faired over. The 2-way switch was
in place of the original landing light switch.
Aaron C.
Old February 2nd 05, 04:45 PM
kage
You may want to turn it OFF, say if it's on fire.
Just change it willy nilly, anyway you want. Then get your own STC. Skycraft
engineers are probably just a bunch of idiots.
Karl
Old February 2nd 05, 10:45 PM
Jay Honeck wrote:
: My A&P says Skycraft's STC doesn't cover that option, and he would have to
: get a field approval, blah, blah, blah. His idea is to remove my pitot
: heat switch from the little "bank" of switches on my 235, and install the
: new split landing light switch in its place. This will put it right next to
: the existing nose light switch, so turning on the landing light(s) will be
: almost as simple as it is now (or would be with my idea).
: The pitot heat switch would then be relocated in the plane, somewhere.
I second the comment regarding the current capability of the switch.
Especially with a split toggle switch like that, it may have a max current that
prevents using both at the same time. If it's got enough rating, check the wire size
and CB rating and the bulb current draw against AC43 and field-approve it the way you
want. If it doesn't have enough current, you could go the relay route as others have
suggested. The FSDO might like that better, since you wouldn't be appreciably
modifying the kit with larger wire, fewer CB's, etc.
I think having individual controls over which lights are on is a good thing.
Maybe not three separate switches, but it's good to not burn out the bulbs, draw
****loads from the alternator at low (descent) RPM, and blind other people all at
once... Selective evils with maybe 2 separate switches. OR... get a split switch
where each is SPDT with a center detent "off" position. Wire the four potential
positions into a "landing-light code" that only you know how to decipher...
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old February 2nd 05, 11:42 PM
Mike W.
how about replacing the current nose mounted landing light with a much lower
wattage light, for taxiing. Maybe have it come on with the nav lights.
Old February 3rd 05, 03:22 AM
Jon
I thought the Skycraft's STC required the removal of the nose light.. I
would give them a call. Just seems like we went over this on the last
install we did but it might have been a small ALT.
Jon Becker
road
go in
example, only
light
half,
(This
instead of
have to
pitot
next to
will be
somewhere.
some
did you
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 3rd 05, 04:22 AM
George Patterson
The installation will still have to be able to handle the drain of the usual
bulb for that fixture, just in case someone puts one in at a later date.
George Patterson
He who would distinguish what is true from what is false must have an
adequate understanding of truth and falsehood.
Landing Light CB Hankal Owning 25 August 25th 04 02:22 AM
Would a 3 million Candlepower spotlight make a good landing light? Legrande Harris Home Built 6 June 15th 04 06:32 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
