Challenger Crashe at TEB
Old February 4th 05, 11:46 AM
Matt Whiting
Ron McKinnon wrote:
"Matt Whiting" wrote in message
Peter R. wrote:
If deicing were not an option, I would have had to get a hotel and wait
until the frost melted off the next day, or some liquid deicing were
available. In no case would I have attempted to take off with it on the
wing surface.
Why? It is acceptable to "polish the frost smooth" per FAR 91.527.
Interesting. It seems a rather dubious practice to me. It would indeed
appear to be legal in the US - but, FWIW, it isn't legal in Canada.
Why? Smooth frost is less of an aerodynamic issue that a thick layer of
dirt, bugs and dust...
Matt
Old February 4th 05, 04:14 PM
Robert A. Barker
wing surface.
Matt
The last two FAA seminars I have attended indicated
it was no longer considered good practice to fly with
ANY frost, polished or not.
Bob Barker N8749S
Old February 4th 05, 06:12 PM
Ron McKinnon
...Why? It is acceptable to "polish the frost smooth" per FAR 91.527.
Be that as it may, arguing that its not as bad as something else (that you
shouldn't fly with either), isn't any argument at all for the acceptability
of flying with smooth frost.
Frost, smooth or otherwise, or other contaminants arguably affect the
aerodynamic behaviour. How much does it change with a given
level of contamination?, what level of contamination is significant?
or how significant is such a change? how much is too much? how
smooth is smooth enough? in what way will such change affect the
aerodynamic behaviour of the plane? (does it change the critical
angle of attack for the wings? the control surfaces?, what are
the new critical angles (what's the new stall behaviour? is a
tailplane stall more likely? will it spin easier? how does it change
rudder effectiveness?) for instance) are critical questions. But
these are not questions that a typical pilot is in a position to answer
operationally. This a job for computer simulations, and lab analysis
in controlled test conditions, and for test pilots in controlled test
situations.
Critical surfaces should be clean.
Old February 4th 05, 09:57 PM
Matt Whiting
situations.
They only affect the aerodynamic behavior if they significantly affectt
he flow in the boundary layer. On some airfoils this a concern with
fairly small disturbances, but on others it isn't much of a concern at
all. Saying that you should not fly an airplane that has any frost on
it is just as silly as saying you should never take off with less than
full fuel. You have to know your airplane, nobody is arguing that.
Most light airplanes will fly just fine with polished frost on the wings
and even the control surfaces, I know my 182 did.
Only if being clean is critical. :-) It often isn't.
Do you really wipe your entire airplane completely clean of bugs and
dirt after every flight? If you fly through bugs do you land
immediately to clean them off?
Matt
Old February 5th 05, 12:07 AM
Ron McKinnon
Sent: Friday, February 04, 2005 1:57 PM
you
acceptability
situations.
They only affect the aerodynamic behavior if they significantly affectt he
flow in the boundary layer. On some airfoils this a concern with fairly
small disturbances, but on others it isn't much of a concern at all.
Saying that you should not fly an airplane that has any frost on it is
just as silly as saying you should never take off with less than full
fuel. You have to know your airplane, nobody is arguing that. Most light
airplanes will fly just fine with polished frost on the wings and even the
The issue isn't whether it will fly at all, but what happens to its
flying characteristics, and whether you're still operating
with safe margins for error. A few anecdotal cases where it
'flew', does nothing to answer that. There are many other
cases on record where it didn't.
What, exactly is the expected level-flight stalling speed with
this particular amount of frost, 'polished' to this particalar
smoothness? Is it safe with the current loading, the current
density altitute, the current runway (the destination loading,
density altitude, and runway?) - do you have any safety
margin left? or have you used it all up by leaving frost on
the wings? or have you, in these particular circumstances
not affected it at all? What's the new stalling characteristics
of the stablizers, elevator and rudder effectiveness. Are you
going to be in the neigborhood of a tailplane stall on takeoff?
Is the frost layer uniform - does it affect the whole wing in the
same way?
You don't know. .
And its not just about 'knowing your airplane'. How many
pilots can say with assurance how much contamination
will significantly affect the flow in the boundary layer?, or for
which airfoils its a concern with fairly small disturbances?
There are no doubt some that can, I'll grant you. But this is
not the usual rule. (Off the top of your head - What is the
airfoil on your 182? How sensitive is it to contamination.
How much contamination is too much on your 182.
What thickness of frost is too much for this airfoil? How
'smooth' *does* it have to be? And then what about the
stabilizers, elevators and rudder? Exactly what is the new
level flight stalling speed?)
The proposition isn't that you shouldn't fly an airplane that
has *any* frost on it - it is that you shouldn't fly it with any
frost on the critical surfaces: wings, stabilizers, rudder
(propellers).
It is obviously 'legal' in the US (the original FAR citation
shows this), so in the US you may obviously feel free to
use your discretion in the matter. But that doesn't necessarily
mean it is safe.
In other places (Canada, for instance) it isn't even legal.
Old February 5th 05, 02:19 AM
Matt Whiting
My 182 flew just fine. I'm not aware of any 182 accidents from polished
frost and I know many people with many thousands of hours operating 182s
in my area and climate.
same way?
You don't know. .
Same way you don't know after you fly through a swarm of bugs. Does
this freak you out also? It never bothered me. I can detect a stall
pretty easily in all of the airplanes I've flown. If the stall
commences at 60 knots instead of 50 knots, I don't really care, I just
stay above that airspeed.
I don't care exactly what it is as I mentioned above. The stall speed
varies constantly with loading and many other factors. If you fly based
on what the ASI tells you and not what the airplane is telling you, then
you are going to be a statistic some day.
(propellers).
And I disagree with that proposition and have done so successfully for
27 years. It just requires a little common sense and discussion with
people who have a lot of experience in your make and model.
mean it is safe.
It is legal and safe if done properly. Just like most other aspects of
aviation. However, I'm not suggesting you should do it. I'm just
saying that for many of us it isn't a big deal.
Then you shouldn't do it in Canada.
Matt
Challenger forum Dico Reyers Home Built 0 December 30th 03 06:48 PM
Ignoring the Challenger? robert arndt Military Aviation 0 July 1st 03 10:24 AM
