On Sun, 06 Feb 2005 02:01:14 GMT, "Mike Rapoport"
wrote: You might check into a "wicking sealant". I know permatex makes one, but I don't know the part number. Do it at night since it is not aircraft stuff. It has worked for me on a variety of leaks on transmissions and transaxles. Of course you need to remove the RTV and clean the area with brake cleaner first. There is a letter circulating around from TCM concerning case seam leaks. The gist of the process is remove any leaking case bolts in the area, clean thoroughly with MEK (brake cleaner would work), and apply cyanoacrylate adhesive. That's right, super glue. You hook a shop vac up to the breather, turn it on, clean things up and let dry thoroughly. Turn the vac back on, apply the glue to the seam and on the inside of the bolt holes. Let it dry, put it all back together, torque the bolts and fly the crap out of it. Had really good luck using the extremely thin hobby stuff, then painting the thicker stuff down the seam (sparingly) after the thin stuff is dry. Is an "approved" repair for TCM products, and I have used it with good results. You hit the nail on the head, it is a "wicking" leak in most cases, and a wicking sealant will stop it... Regards; TC |
![]() wrote in message ... On Sun, 06 Feb 2005 02:01:14 GMT, "Mike Rapoport" wrote: You might check into a "wicking sealant". I know permatex makes one, but I don't know the part number. Do it at night since it is not aircraft stuff. It has worked for me on a variety of leaks on transmissions and transaxles. Of course you need to remove the RTV and clean the area with brake cleaner first. There is a letter circulating around from TCM concerning case seam leaks. The gist of the process is remove any leaking case bolts in the area, clean thoroughly with MEK (brake cleaner would work), and apply cyanoacrylate adhesive. That's right, super glue. You hook a shop vac up to the breather, turn it on, clean things up and let dry thoroughly. Turn the vac back on, apply the glue to the seam and on the inside of the bolt holes. Let it dry, put it all back together, torque the bolts and fly the crap out of it. Had really good luck using the extremely thin hobby stuff, then painting the thicker stuff down the seam (sparingly) after the thin stuff is dry. Is an "approved" repair for TCM products, and I have used it with good results. You hit the nail on the head, it is a "wicking" leak in most cases, and a wicking sealant will stop it... Regards; TC TC, If you could forward me a copy of that letter I would appreciate it. Nobody here has heard of it. Thanks, Allen |
On Tue, 08 Feb 2005 22:24:37 GMT, "Allen"
wrote: snip TC, If you could forward me a copy of that letter I would appreciate it. Nobody here has heard of it. Thanks, Allen The last copy I obtained is somewhere at my previous employer's shop. I got it by calling TCM tech support and asking them for it specifically. It is an old advisory letter addressing crankcase backbone leaks, does not have a SB # or anything like that. TC |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
