Owner Change/rotate spark plugs?
Old February 11th 05, 06:01 PM
Jon Woellhaf
At the last annual, my mechanic showed me how to anneal the copper spark
plug gaskets before reusing them.
Is this common practice?
Old February 11th 05, 08:02 PM
George Patterson
New gaskets cost $.19 each, with a 20% discount on a box of 100. Typical charges
for an A&P's time in this neck of the woods are $50/hr and up. I certainly hope
it's not common practice anymore.
George Patterson
He who would distinguish what is true from what is false must have an
adequate understanding of truth and falsehood.
Old February 11th 05, 08:22 PM
John Kunkel
"Jon Woellhaf" wrote in message
I don't know how common it is but it's done and it's not that time
consuming.
Mount a steel shaft horizontally in a vise and slide the gaskets to the vise
end. Below the open end of the shaft place a coffee can full of water. Slide
the gaskets out to near the open end of the shaft, heat them red, then slide
them off the end and they fall into the water.
Including setup time you can do 100 gaskets in about 10 minutes.
Old February 12th 05, 01:42 AM
RST Engineering
Oh, please, for the love of God, don't do this. This is how you HARDEN
them, not soften them for the annealing process. Heat them red hot with a
torch and let them cool in ambient air to soften them.
slide them off the end and they fall into the water.
Old February 12th 05, 01:47 AM
Jürgen Exner
[Top=-posting corrected]
then slide them off the end and they fall into the water.
HARDEN them, not soften them for the annealing process. Heat them
red hot with a torch and let them cool in ambient air to soften them.
Well, I guess this depends upon if your gaskets are made of copper or of
iron/steal.
Although, I've never seen gaskets made of iron but of course nothing is
impossible.
jue
Old February 12th 05, 05:12 AM
I just did a google search on the subject of copper annealing, and I
found this article.
http://www.evergreengardenworks.com/copperwi.htm
I can say that I used to rebuild motorcycle engines, and most of them
had solid copper head gaskets. I would anneal them by heating to red
hot and then dropping in a water bucket. They seemed to be much softer
afterward and did not leak so I guess that is a proper way to do it
(whatever works, right?). According to the article, you can use either
method, but he recommends water quenchung to minimize oxidation.
Regards,
Bruce Cunningham
N30464 C177A
Old February 12th 05, 05:19 AM
Montblack
("Jürgen Exner" wrote)
iron/steal.
impossible.
Saw this link after a few Googles.
It shows that others have had this same discussion.
http://www.steamengine.com.au/ic/faq...ng-copper.html
It made into their FAQ's :-)
Montblack
Old February 14th 05, 07:32 PM
Don Hammer
I'm a long time A&P. Back in the old days I used to hang them on a
piece of safety wire, get them red hot, then drop them in water.
Worked great for me and I didn't have to go hunt some up in the stock
room. Of course, for me, the acetylene torch was closer than the
stock room.
Old February 25th 05, 07:19 PM
Michael Houghton
Howdy!
Copper and silver (and probably many other non-ferrous metals) are annealed
by quenching. You can't harden them by heat treatment. You harden them by
working them. Yes, this is opposite to how you harden/soften steel.
Google for "anneal copper". One site I found was
http://www.key-to-metals.com/Article25.htm
which seems to cover more than just annealing work-hardened copper.
Now, one can fairly wonder why one would want to reuse old gaskets when
they can be bought fairly inexpensively, but that is a different matter.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/wwap/
Old February 11th 05, 10:08 PM
Dave Stadt
I take them home and do it in my spare time. Get them red hot with a
propane torch and drop em in a coffee can of cold water.
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Bougies blindées BG à vendre/BG spark plugs for sale stef General Aviation 0 May 14th 04 04:57 PM
Color of spark plugs john smith Owning 5 March 2nd 04 03:08 AM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
