Oil leak on top of the engine
Old February 11th 05, 09:29 PM
Jon A.
On Fri, 11 Feb 2005 18:27:23 GMT, Orval Fairbairn
In article 6q3Pd.63958$eT5.59714@attbi_s51,
"Jay Honeck" wrote:
The point I'm trying to make is it appears that some bolts being torqued
have been overlooked and what is the chance that the cylinder nuts & thru
bolts had been overlooked also?
Simply, You don't know until you check. It'll require 10 minutes if you
have easy access to the engine.
I'm having my shop check these this morning.
To those who think that the bolt might have been loose from the start,
remember: I watched the shop build this engine, and I personally saw them
check the torque on the engine case bolts. They *were* tightened to spec.
I also know that they never re-checked them, however, and my main mechanic
has admitted that they never check these as a matter of course.
In the case of the O-540, anyway, the case bolts are torqued surprisingly
low, and they are not secured in any way. No cotter pin, no safety wire, no
LocTite, no lock washer -- NOTHING prevents those nuts/bolts from loosening
over time. It seems like a ridiculous over-sight, but that's the way it
is.
A guy on the Cherokee Chat actually had a case bolt FALL OUT after loosening
over time from vibration, so this is not an unheard-of problem. I'm
surprised it's never been addressed in this forum before -- at least not in
my 7 years here.
I've bought a torque wrench, and I'm going to be checking ALL of these bolts
every time I change the oil, from now on.
Another caveat on torquing (from an old AI): All torquing should be done
"wet", with a drop of oil to lube the nut, so as not to get a false
torque reading.
Let's hope the old AI isn't doing much any longer. Whether a bolt is
wet or dry (oil, locktite,graphite) will change the torque specs. The
manufacturer should specify the condition of the bolt for those who
have their JD's.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
