Of course, these days folks would rather argue ad nauseum about trivia,
rather than get two spark plug gaskets. Anneal one correctly (red heat, quench in water) and the other incorrectly (red heat and air cool). See which one comes out clean and soft, and which one comes out black and hard. Matt Whiting wrote: John Clonts wrote: wrote in message oups.com... Jon A. wrote: And you're posting this during a discussion of the question whether or not an owner can change their own plugs. Horse - - - Cart Cart - - - Horse So that means that means that wheher the gaskets are annealed or reused without annealing is irrelevant? That the owner wouldn't benefit by knowing about using new or annealed gaskets? Come on. Dan Well, I have learned from elsewhere in this thread that NEW gaskets are DEFINITELY the way to go since there is debate as to whether the proper treatment of used gaskets is to include cold water quenching or ambient air cooling... Debate aside, the fact is that annealing non-ferrous metals is different than ferrous metals. Heating and quenching is the way to go for non-ferrous metals. I have several loading manuals that show this technique for annealing brass cases (which is mostly copper). You stand them upright in a tray of water, heat them with a torch and then tip them over into the water. Search around on your own and you will find this to be true. Matt |
Spark plug question: Massive electrode or fine wire? | Peter R. | Owning | 9 | February 4th 05 02:03 AM |
Which aircraft certification is required for R&D? | Netgeek | Home Built | 5 | November 23rd 04 05:59 AM |
Bougies blindées BG à vendre/BG spark plugs for sale | stef | General Aviation | 0 | May 14th 04 04:57 PM |
Color of spark plugs | john smith | Owning | 5 | March 2nd 04 03:08 AM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
