I'm sorry, I can't find the initial thread on this subject by a person who
calculated a forward CG on his Cherokee...if I missed the pertinent newsgroup, would somebody please repost for me? 1. It would have helped if you had given us the serial number of the airplane to be sure we looked up the correct version in the Type Certificate Data sheets. 2. The empty weight and CG look a little bogus to me. Did you take them from the aircraft logbook or from a "typical" aircraft in the POH? 3. Even if you took them from the logbook, most mechanics aren't mathematicians. I've seen more than one to be a few inches or pounds in error. Go all the way back to the beginning of that airplane's time and see if the W&B as delivered from the factory is even reasonably close to the current W&B. If you want to be meticulous about it, check each subsequent calculation to see if you can find something that doesn't make sense. 4. The front seats are at arm 85.5, not 80.5. You forgot 2 gallons of oil at arm 32.5. 5. The aircraft under the conditions that you specified with the recalculations shows a weight of 2174 and a CG of 85.5. The graph in the TCD sheets shows that the max forward cg under these conditions no less than 89.9, which is one HELL of a forward CG IMHO. Jim Here is the pertinent data from the TCD sheets: III - Model PA-28-180 (Cherokee), 4 PCLM (Normal Category), 2 PCLM (Utility Category) (Cont.) Center ofGravity Range Utility Category (See NOTE 9) (+84.0) to (+86.5) at 1650 lb. or less (+85.8) to (+86.5) at 1950 lb. Normal Category (See NOTE 15) (S/N 28-671 through 28-5859) (+84.0) to (+95.9) at 1650 lb. or less (+85.9) to (+95.9) at 1975 lb. (+89.2) to (+95 9) at 2200 lb. (+92.1) to (+94.5) at 2400 lb. Normal Category (S/N 28-7105001 through 28-7205318) (+84.0) to (+95.9) at 1650 lb. or less (+87.0) to (+95.9) at 2150 lb. (+87.8) to (+95.9) at 2200 lb. (+91.0) to (+94.5) at 2400 lb. Straight Line Variation Between Points Given Empty Weight C. G. Range None Maximum Weight Normal Category: 2400 lb. Utility Category: 1950 lb. No. of Seats Normal Category: 4 (2 at +85.5, 2 at +118.1) Utility Category: 2 (2 at +85.5) III - Model PA-28-180 (Cherokee), 4 PCLM (Normal Category), 2 PCLM (Utility Category) (Cont.) Maximum Baggage Eligible Normal Category Only: 125 lb. at (+142.8) on S/N 28-671 through 28-1760, and 28-1760A. See NOTE 8. 200 lb. at (+142.8) on S/N 28-1761 through 28-5859, and 28-7105001 through 28-7205318. Fuel Capacity 50 gallons at (+95) (2 wing tanks) See NOTE 1 for data on system fuel. Oil Capacity 8 quarts at (+32.5) (6 quarts usable) See NOTE 1 for data on system oil. |
| Thread Tools | |
| Display Modes | |
| CHEROKEE NATIONAL FLY-IN - MORE INFORMATION | Don | General Aviation | 0 | June 16th 04 06:13 AM |
| Cherokee National Fly-In & Convention | Don | Owning | 0 | May 5th 04 09:13 PM |
| Cherokee National Fly-In & Convention | Don | General Aviation | 0 | May 5th 04 09:12 PM |
| Cherokee National Fly-In & Convention | Don | Owning | 0 | March 20th 04 03:17 AM |
| Cherokee National Fly-In & Convention | Don | General Aviation | 0 | March 20th 04 03:15 AM |
