Doug,
Gee I am jealous. I only get to taxi J-41s and CRJs around Dulles Airport. I get to work on them too. I would rather be flying them..... Maybe someday. Michelle Capt. Doug wrote: I had the opportunity to fly a Jetstream 31 recently. The -31 is a 19 passenger pressurized turboprop commuter with a MGTOW of 14,450 pounds. It was built by British Aerospace with Garrett engines. Most have a belly pod added for additional cargo space. In preparation, I read the limitations and reviewed the memory items for emergencies. Being written by the British, the AFM had some words and terms that seem strange. 'Torches' actually means flashlights. I sat in the cockpit for about 20 minutes to learn where all the switches and knobs were. The only thing that confounded me was the where-abouts of the control lock. I consulted the captain who pointed to a little lever near the bottom of the center pedestal. Engine starting is easy. Push the start button until 10% RPM, then just monitor the guages. The start relays cut out at 60% RPM and the engine stabilizes at 71%RPM. After both engines were started, the generators are brought online and the air conditioning is cranked up. The windshield heat is turned on even though the OAT is 30*C. This is done for birdstrike protection. Cold glass is more brittle. Garrett engines are not known for being quiet, but most of the noise stays outside the cockpit. Taxiing was different. The first thing I found out is that the brakes are powerful and touchy. Just a slight touch of brake would send the plane lurching to one side or the other. I stopped using the brakes and relied on reverse thrust to stop. As a passenger on J-31s, I had noticed that the pilots always had a hard time following the taxi lines with precision. Now I know why. The nose wheel steering has a lot of slop in it. One has to average out the slop to taxi straight. Flaps are set at 10* for normal take-off. Rotation would be at 107 KIAS and Vy was 122 KIAS. For take-off, my senses were heightened more than usual because the plane had been sitting for 2 years. The take-off was routine however. I climbed out at 160KIAS so that I would have a better look over the nose for traffic. I've heard that the Jetstream has some funky yawing because of the short coupled vertical stabilizer, but I didn't find it to be any worse than other planes in this class. As we climbed, our true airspeed stayed the same but our fuel flow decreased. We climbed to FL250 so that we could squeeze 4.5 hours out of the fuel tanks. Leveled off at FL250, we were burning a measly 570 pounds/hour with 230KTAS and an 8000' foot cabin. The controls were a little sluggish in the thin air. Along the way, the TCAS alarm went off. That's one of those things that sits you up right away with wide open eyes searching frantically for the other plane. Apparently, the other plane was well below us but without Mode C. The TCAS unit doesn't know the altitude, so we get a warning. If the other plane had an operating Mode C, the TCAS unit would have determined there was no threat. At FL250, the plane flies at about 4* nose up. We picked up some ice and lost 15 knots. I'm guessing it's because the belly and belly pod picked up quite a bit of ice due to the nose up attitude. Just before descent, the left engine started fluctuating wildly. I shut off the engine computers and it stabilized. We flew a practice ILS approach to check the avionics. The -31 is stable and airspeed is easily kept at 120 knots. The flight director makes flying the approach even easier. The stall warning sounded just as the mains hit the runway. I pulled the power levers back to the flight idle gates and felt the enormous drag of the propellers as they flatten out. Then the nose started to drop down. And drop down some more. And then some more. I had serious concerns that the nose gear wasn't right. Then the nose dropped some more. Finally the nose wheels touched down. The -31 normally sits nose low and I'm not used to it. It got my pulse rate up for sure. Reverse thrust is very effective down to about 40 knots. Below 40 knots, I started the herky-jerky with the touchy brakes and ponderous steering tiller. Over-all, I enjoyed flying the -31. It doesn't have the baggage space that comparable planes have, even with the belly pod, but operators I know who use -31s are happy with them. D. -- Michelle P CP-ASMEL-IA, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, AirLifeLine Volunteer Builder, Habitat for Humanity |
Michelle P wrote: Gee I am jealous. I only get to taxi J-41s and CRJs around Dulles Airport. I get to work on them too. I would rather be flying them..... Maybe someday. Do you need any kind of FAA cert to do that? In a movement area vs non-movement area? It never occured to me that non-pilots were taxiing planes, but I guess it's not that surprising for maintenance... -- Ben Jackson http://www.ben.com/ |
Ben,
No the FAA does not require any certification because we are not operating the aircraft for the purpose of air navigation. We do have a company mandated 18 hour training course per aircraft type before they will let you be "PIC". The instructor looked at me and skipped the airport diagrams and radio phraseology because I already have my Pilots license. Michelle Ben Jackson wrote: In article , Michelle P wrote: Gee I am jealous. I only get to taxi J-41s and CRJs around Dulles Airport. I get to work on them too. I would rather be flying them..... Maybe someday. Do you need any kind of FAA cert to do that? In a movement area vs non-movement area? It never occured to me that non-pilots were taxiing planes, but I guess it's not that surprising for maintenance... -- Michelle P CP-ASMEL-IA, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, AirLifeLine Volunteer Builder, Habitat for Humanity |
Michelle P wrote
We do have a company mandated 18 hour training course per aircraft type before they will let you be "PIC". That would be "Person-in-Cockpit"...right? Bob Moore |
Bob,
That would be the person in the left seat (PILS) at the tiller.... Rudders do not work for steering the J-41 at low speed. Michelle Robert Moore wrote: Michelle P wrote We do have a company mandated 18 hour training course per aircraft type before they will let you be "PIC". That would be "Person-in-Cockpit"...right? Bob Moore -- Michelle P CP-ASMEL-IA, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, AirLifeLine Volunteer Builder, Habitat for Humanity |
![]() "Michelle P" wrote in message ... Ben, No the FAA does not require any certification because we are not operating the aircraft for the purpose of air navigation. We do have a company mandated 18 hour training course per aircraft type before they will let you be "PIC". Or TIC...taxier in command? |
![]() "Ben Jackson" wrote in message news:sW7Pa.19537$OZ2.3738@rwcrnsc54... In article , Michelle P wrote: Gee I am jealous. I only get to taxi J-41s and CRJs around Dulles Airport. I get to work on them too. I would rather be flying them..... Maybe someday. Do you need any kind of FAA cert to do that? In a movement area vs non-movement area? It never occured to me that non-pilots were taxiing planes, but I guess it's not that surprising for maintenance... Michelle is a pilot, just no Propstream rating. She flies a Maule with a big assed engine. |
