Larry Dighera wrote in message . ..
On Tue, 08 Jul 2003 12:08:22 GMT, Sydney Hoeltzli wrote in Message-Id: : How does the CPSC (or the mfrs) issue a recall against consumer goods that lack the FAA's mandated paper-trail? They seem to manage. The companies involved even seem to do more for the consumer. Gosh -- no expensive FAA mandated official paper trail, and this recall bit still worked. If the FAA mandated paper-trail from raw material to finished part is unnecessary, why do you think it was made it a requirement? This would be pure speculation on my part, but my guess is that with the advent of computerized manufacturing and records keeping, many more manufactured parts are routinely trackable by mfring location, date, and lot than was the case when the regulations were written. Now let's take the pending Superior air parts piston pin AD which was pending a few years back when we bought our plane. Per engine log, the relevant part had been installed in my plane during engine overhaul 7 years ago. But for various reasons, I had my doubts. ... Here's the punch line: when one of the cylinders was pulled due to a valve problem, *the piston pin which came out was made by an entirely different manufacturer*. Once bitten by such a lack of records, an aircraft owner soon learns to obtain copies of repair records AT THE TIME OF INSTALLATION, and files them with the aircraft log books. The IA is required by FAA to document all the parts used. Um, Larry: either you didn't read the post you're responding to very carefully, or you totally missed the point. The parts used were documented in the logs. There were copies of some repair records The documentation was incorrect. It reflected the installation of a part which was not, in fact, installed. If you (or the previous owner of your airplane) had kept a record of the parts installed, it would have been possible for you to KNOW if they were among those that were recalled. I fail to see how your failure to keep a copy of the records reflects poorly on the FAA mandated record keeping practices. Hello, Larry: where did you get this notion that "failure to keep a copy of the records" was the issue here? The point is, the FAA paper trail doesn't do a thing to improve the quality of the work or to prevent simple human error, such as logging piston pins from Mfr A as being installed while in fact reaching into the parts box for Mfr B. Will you 'get it' this time? Sydney |
