arthlink.net... Why? That regulation doesn't apply to non-movement areas. It applies to runways and taxiways, it says nothing of "non-movement areas". Why would it say anything of non-movement areas? It DOES NOT APPLY to non-movement areas. I taxi all the time in the non-movement areas at my home airport, as well as any number of other airports. The pavement I am taxiing on is a taxiway, but because it's a non-movement area 91.129(i) doesn't apply. Your assertion is that I am in violation of 91.129(i) every time I do this? I realize that you love to argue just for the sake of the troll, but this time you are really off the deep end. The situation at Renton sounds screwed up, to be sure, but if they want to classify the entire airport except the runway as a non-movement area, then no ATC clearance is required to taxi around the airport (except on the runway of course). Pete |
![]() "Peter Duniho" wrote in message ... Why would it say anything of non-movement areas? It DOES NOT APPLY to non-movement areas. I didn't bring up non-movement areas, you did. I taxi all the time in the non-movement areas at my home airport, as well as any number of other airports. The pavement I am taxiing on is a taxiway, but because it's a non-movement area 91.129(i) doesn't apply. What do you base that on? The regulation says "runway or taxiway", it doesn't say "runway or taxiway, except those designated as non-movement areas". Your assertion is that I am in violation of 91.129(i) every time I do this? Read the regulation, it's not complicated. I realize that you love to argue just for the sake of the troll, but this time you are really off the deep end. You're an extremely poor judge of character. The situation at Renton sounds screwed up, to be sure, but if they want to classify the entire airport except the runway as a non-movement area, then no ATC clearance is required to taxi around the airport (except on the runway of course). FAR 91.129(i) says differently. I wouldn't get too excited about it, some regulations are violated regularly without consequence. |
arthlink.net... I didn't bring up non-movement areas, you did. No, actually YOU did when you replied to a post that specifically said that the taxiways had been designated non-movement areas. You should read the posts to which you reply a little more carefully. What do you base that on? The regulation says "runway or taxiway", it doesn't say "runway or taxiway, except those designated as non-movement areas". Non-movement areas are implicitly excluded from the requirement for an ATC clearance. While they physically can include a taxiway, those are not ATC-controlled taxiways and as such, 91.129(i) doesn't apply. There is no need for them to be mentioned explicitly in the regulation. Read the regulation, it's not complicated. You're right, it's not. And yet you still seem confused. Odd. I realize that you love to argue just for the sake of the troll, but this time you are really off the deep end. You're an extremely poor judge of character. Perhaps. But even a blind squirrel finds a nut once in a while. FAR 91.129(i) says differently. I wouldn't get too excited about it, some regulations are violated regularly without consequence. Put up or shut up. If you can find me one single FAA inspector that is willing to agree with your stance that an ATC clearance is required to taxi in non-movement area, I will happily admit I was wrong. Otherwise, the only conclusion is that you have no point and are arguing just for the sake of the troll. Pete |
![]() "Peter Duniho" wrote in message ... No, actually YOU did when you replied to a post that specifically said that the taxiways had been designated non-movement areas. You should read the posts to which you reply a little more carefully. Is that how it works? Gee, I would have thought the person that referred to non-movement areas in the message I was responding to would be considered the person that brought it up. Non-movement areas are implicitly excluded from the requirement for an ATC clearance. While they physically can include a taxiway, those are not ATC-controlled taxiways and as such, 91.129(i) doesn't apply. There is no need for them to be mentioned explicitly in the regulation. What do you base that on? You're right, it's not. And yet you still seem confused. Odd. You believe I brought non-movement areas into this discussion. Clearly, I'm not the one that's confused. Perhaps. But even a blind squirrel finds a nut once in a while. I suppose so, but you're still batting .000. Put up or shut up. If you can find me one single FAA inspector that is willing to agree with your stance that an ATC clearance is required to taxi in non-movement area, I will happily admit I was wrong. Otherwise, the only conclusion is that you have no point and are arguing just for the sake of the troll. I've already posted the regulation supporting my position, you've provided nothing in support of yours. Looks like it's you that needs to put up or shut up. Of course, based on your history, you'll do neither. |
![]() Peter Duniho wrote: Why would it say anything of non-movement areas? It DOES NOT APPLY to non-movement areas. Not having been there an easy way to set it up is to announce on the ATIS or by other means that all aircraft are to taxi to the runway in use. I accomplish a similar thing on the midshift by issuing all IFR clearances by ATIS. You get a transponder code and a taxi clearance from me, the rest of the clearance is covered by the ATIS. |
Newps wrote:
Not having been there an easy way to set it up is to announce on the ATIS or by other means that all aircraft are to taxi to the runway in use. I accomplish a similar thing on the midshift by issuing all IFR clearances by ATIS. You get a transponder code and a taxi clearance from me, the rest of the clearance is covered by the ATIS. How does one handle read-backs? Sydney |
![]() Sydney Hoeltzli wrote: Newps wrote: Not having been there an easy way to set it up is to announce on the ATIS or by other means that all aircraft are to taxi to the runway in use. I accomplish a similar thing on the midshift by issuing all IFR clearances by ATIS. You get a transponder code and a taxi clearance from me, the rest of the clearance is covered by the ATIS. How does one handle read-backs? The end of the ATIS message says..."All IFR aircraft are cleared to their destination airport, via the Billings Two departure, then as filed. Maintain one two thousand or your requested lower altitude, expect your transponder code on taxi. All aircraft contact Billings 120.5, advise you have..." Only one guy normally reads back his clearance, so he does, the normal way. |
this guy is a net troll, he's using at least (6) other usernames,
killfile him ASAP, below is his posting history http://groups-beta.google.com/groups...5xS36mXc24h6ww see the link above, he is using at least (10) other usernames on Usenet, they include MARCO R ROBERT J. KOLKER ROBERT MORIEN NEWPS ASK A DIFFERENT ROBERT KOLKER EARL KIOSTERUD therefore, he has no credibility- merely another net troll |
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today | Billgran | Home Built | 3 | December 6th 03 03:22 PM |
"Bush - Nazi Dealings Continued Until 1951" - Federal Documents | B2431 | Military Aviation | 0 | November 13th 03 04:26 AM |
AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 08:26 PM |
What Don Young, R-AK says about ATC privatization | Chip Jones | Instrument Flight Rules | 2 | September 19th 03 05:10 AM |
Bu$h Jr's Iran-Contra -- The Pentagone's Reign of Terror | PirateJohn | Military Aviation | 1 | September 6th 03 10:05 AM |
