XMRadio Satellite Weather Has Arrived
Old July 28th 03, 04:02 PM
Jeff Doran
Richard, thank you for posting the info on the xmradio weatherworx. I,
like many, have been searching for reliable in-cockpit weather
solutions. The closest thing to affordibility so far has been anywhere
wx from control vision, but even that is a bit pricey, and a rats nest
of wires. I use the Palm i705, and you just can't beat it for
portability and cost. However, as reliable as it is, even in flight,
there are too many times, when I just didnt get a signal or reply when
making an inflight weather request from CBAV or TurboWX.
For that past month, I have been using a poormans version of the
control vision solution...
Globalstar SAT phone, $595 list/$495 with rebate/$395 reconditioned
Ipaq H3635 pocket pc, on ebay for $100 (or any pocket pc), you can
even hook to your i705 and switch back and forth between the wireless
palm network and the SAT connection. I prefer the higher resolution
and color on the Ipaq for maps.
Globalstar data cable, $69;
IPAQ Serial Cable (not a hotsync cable, they are not the same) $20;
SAT phone is $35/month and .99/minute with 30 included min/month, or
$50/month with 120 minutes/month, .75/minute after that.
Control Visions deal is $25/month, first 100 mins free, then .99/min
after that.
A wide range of service plans to fit both budget and use.
(I do not work for any SAT phone company or aviation product company)
Data comes down at 9.6Kbps,plus I can make reliable, consistant voice
calls in flight.
I have not had any problem aquiring and holding a SAT signal in
flight, as long as the antenna is held reasonbly close to a window.
The glare shield is fine.
Admittedly, this is a request/reply setup, and I typically use
weathertap.com and flighbrief.com for inflight weather. Not that it is
very useful or fast, I can browse the web in flight, including pop3
email, etc etc...
The result is, I am juggling only a PDA, a short cable, and the sat
phone. Not Bad.
Did you ever notice how big and cumbersome even the smallest laptops
are when in the cockpit? Screen visibility in sunlight is another
concern.
About the only thing I see that XMradio has to offer is its
"broadcast" technology, and (I assume) greater bandwidth...not that
these are bad things.
BTW, I have a Delco Xmradio mounted on the pedestal of my mooney, with
the low profile antenna hiding on the glare shield...works great...but
I can't listen to Limbaugh.
Jeff Doran
Mooney N1159P ACY
As far as WeatherWorx vs. Palm VIIx, I think the people who will pay
$49/month for WeatherWorx and deal with the wiring clutter are people who
use their airplanes fairly often for practical IFR travel. I think other
people will stick with the simplicity, compactness, and economic advantages
of the Palm VIIx. They each have their advantage. To hook up Weatherworx,
you need to set up the computer, satellite receiver, and XMRadio box,
certainly not something you could/would do on the fly in the air. The
advantage of WeatherWorx is that once this is all set up, it updates
automatically during the flight so it is a lot less distracting. The
advantage of the Palm VIIx is that it can just sit in the side pocket of
your airplane and you can turn it on basically on a whim if you see
unexpected weather. On top of that, the Palm VIIx runs on just 2 AAA
batteries, vs. WeatherWorx which requires either a freshly charged
laptop/PDA battery or else a connection to the airplane's cigarette lighter
power source.
Old July 28th 03, 08:10 PM
Richard Kaplan
"Jeff Doran" wrote in message
m...
concern.
Yes, I am somewhat concerned about that, but I know a pilot whom I have
worked with for recurrent training who swears by the WSI In Flight system
with a laptop and he says it is not inconvenient at all.. we'll see in a
month or two after some more pilots (include myself) get a bunch of
practical experience using XMRadio in the air. Maybe one of the RAM
computer mounts will be an option. Also XMRadio is supposed to support
PDAs, but we will have to see the details how well that works and what
features it can support on a PDA.
About the only thing I see that XMRadio has to offer is its
I think the "broadcast" technology advantage is immense since this allows
5-minute updates without having to worry about cost.
I think the automatic aquisition feature of XMRadio is a major advantage
over the satellite phone setup you describe -- I have tried that myself and
decided that logging onto the Internet in-flight and making regular requests
for weather was just too much of a distraction in any sort of weather where
I really wanted the datalink information... Here with WxWorx once everything
is set up on the ground it updates the signal automatically and should not
require any pilot input at all.
Richard Kaplan, CFII
www.flyimc.com
Old September 1st 03, 08:40 PM
This may be a dumb question (it sounds like all of the replies to this
thread have been far more tech-savvy than I) but is the antenna that the xm
radio system uses specific? Why couldn't you wire their receiver into an
existing gps antenna (fixed or portable)?
Are different satellite receivers able to share an antenna? If I understand
their ad, the premium service uses the same antenna but adds a gps module to
give specific mapping data. It sounds like this is a sharing arrangement
since the gps satellites and "rock" and "roll" are obviously distinct. What
if you already have a gps (portable or panel mounted) Is the premium service
able to use the signal from that? Frank
m...
after that.
calls in flight.
email, etc etc...
phone. Not Bad.
concern.
Jeff Doran
Mooney N1159P ACY
who
other
advantages
Weatherworx,
lighter
power source.
Old September 1st 03, 10:52 PM
Richard Kaplan
xm
The XM Radio antenna is looking for one geosynchronous satellite; it is not
looking for the 12 GPS satellites. Perhaps it would work with a GPS
antenna, perhaps not; at the very least that would require modifying the
antenna connectors since the XM Radio antenna has a connection different
from any GPS antennas I have seen.
As far as GPS inputs for moving map navigation, you can use any GPS with an
NMEA output; that includes a lot of handheld GPS units.
www.flyimc.com
Old September 2nd 03, 02:51 PM
Newps
The antenna isn't "looking" for anything. It merely sits there and
catches what flies by. The receiver is what is looking for specific
things. If the frequencies are close a gps antenna might work.
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
XMRadio Satellite Weather Has Arrived Richard Kaplan Instrument Flight Rules 30 September 2nd 03 02:51 PM
XMRadio Satellite Weather Has Arrived Richard Kaplan Owning 37 September 2nd 03 02:51 PM
Looks like XMradio weather is hitting the streets.. Anonymous Instrument Flight Rules 1 August 26th 03 02:00 PM
Satellite Radio to broadcast weather data James M. Knox Owning 4 July 4th 03 06:30 PM
