Great Stuff Kevin, thanks for your insight. I have a couple of points
I slightly disagree with however further down in your post. :-) Kevin Horton wrote: You've mixed up two different accidents here. The 330 at Toulouse was a loss of control due to the aircraft (on autopilot) going way below VMCA with one engine at idle and the other at full take-off thrust. The sat and watched until it was too late to recover. Yeah I mixed those up. Thanks for keeping me honest. Those were both IMHO over-reliance in airbus automation accidents IIRC. I saw this frequently with new-to-airbus co-pilots who would stare at the PFD trying too figure out why the last button push on the FCP didn't do anything. Instead of disconnecting everything and regaining control. After you got yourself behind the power curve, however, for whatever reason, I'm essentially talking about old-school guys like me who were used to flying non-FADEC machines capable of "overboost." If you got into trouble, because you were stupid, in say the previous generation of Boeing products: You could always push up and call for power far in excess of limiting max GA epr or N1, N2, EGT limits. (but maybe that's because like you say: old eng's didn't operate so close to the surge/stall margin.) It's unlikely the engines were going to fail like a piston or super/turbo charged engine might. Those old buckets would warp. The blades might creep and stretch and the engines might have to be scrapped (at say 5 mill a copy.) But you had a better chance of clearing the trees by going all way the to the mechanical stops (physical wire to the FCU Hydr/Mech linkage) than you do now with a Throttle resolver / PFM/MEC/ FADEC arrangement. The airbus test pilot may think he's called for Jesus power, but FADEC will not let him have it. This may have saved me a couple of times in my career flying 60's gen aircraft overseas. You smash everything to the wall and only slightly pull back on the engines that are "barking." (compressor stalling.) ATC would steer you into mountains in those days in some places. (more war stories.) The accident you are referring to was the A320 at Mulhouse-Habsheim. The pilot did a very low (30 ft AGL) pass with the thrust at idle. The speed decreased til he was at full aft stick, riding on the AOA limiter just above the stall. I haven't flown any FBW. But we had the predecessor AOA system on the A310 which had a A/T "alpha floor" mode (Vls) which would not allow you to command (not select) a speed slower than 1.2 Vso. Check pilots would scare the **** out of themselves relying on this system, and come back and rewrite the manual! This also lead to a bunch of documented (AWST) vertical tailslides at third world airlines where a little turbulence knocked the A/S below alpha floor for a second. Throttles (sometimes asymmetrically) would in about six seconds from (flight) idle reach G/A thrust: locked into what the french call Thrust Latch mode: meaning if you disconnected A/T's and manually retarded them, and let go, they would re-engauge themselves (without your permission) and smoothly place you back up to full pwr again. (New guys never noticed the uncommanded re-power up. They would fixate on the airplane departing altitude and start ****ing around with the pickle switch trim: which was active!) The auto pilot would respect redline on flaps at all costs. It would pull the airframe up into a 90 degree body angle and then stall the machine into an airshow tailslide just like Art Shoal used to. Even if you disc the A/P on the pull up it's too late. The machine has insuficient down elevator authority now to arrest the pull up(cuz nugget ran the tailplane down and "Auhhto" overshot it the back the other direction to get even; there was no aural stabilizer-in-motion sound in a/p trim so nobody noticed the comming set-up!) Great French design! Hang on Grandma! We called these man vs. machine incidents/accidents. bushes when he was looking down on them as he descended, were actually trees that were higher than he was. He couldn't raise the nose, as the fly-by-wire (FBW) was already on the AOA limiter, so the only way to climb was to get more airspeed. He slammed the thrust levers forward, and the FADEC accelerated the engine on its normal acceleration schedule. Turbine engines run more efficiently if they are running close to the surge line (i.e almost ready to compressor stall). But the engine has to come closer to the surge line to accelerate. So the closer you run to the surge line the slower acceleration you'll have. FAR 25.119(a) requires go-around performance to be calculated using the thrust that is available 8 seconds after a throttle slam from idle. Manufacturers want the engine to run as efficiently as possible, but they don't want to take a hit on the AFM go-around performance. So, they typically design the fuel controls to allow full go-around thrust to be reached in just less than 8 seconds from a throttle slam from idle. I've done tests to check the acceleration on many transport category aircraft, and the result is usually somewhere between 7 and 8 seconds, and this is the same no matter whether the engine has a FADEC or an "old fashioned" hydro-mechanical fuel control unit. Were the engines in flight idle? Were you guys pulling the ground sensor breaker? Ground idle takes longer. Older High Bypass designs eg: the GE CF6-80 series only take about six seconds from flight idle to reach GA thrust IIRC, but still cannot over boost. But it's more like twelve seconds in profile mode (slow spool up looking at FMS parameters.) So I remembered it wrong. I think he tried to change alt with Level Change and Profile mode engaged first, and when nothing much happened (norm) he smashed the thrust levers to the wall and ate wood. But Kevin, I'll concede the acceleration argument to you. (Older designs were even slower (something like fifteen seconds to spool up (e.g. GE CF700's aft-fans.) You could bust altitudes descending, if you didn't lead with the throttles a couple thousand feet before level off. So don't blame the FADEC for the A320 accident at Mulhouse-Habsheim. It was caused by a pilot who had way too much confidence in the low-speed protections of the FBW. Yep, you're right. FADEC by itself didn't put him in the trees. But most accidents have "a chain" of factors that cause the accident. If you can break any one of the factorial links the accident would not happen. I submit the inability to get over-boost power was just one of those links. Another was a FBW AOA limit that cannot be temporarily sacrificed to clear obstacles. Fortunately the FBW prevented him from raising the nose, as then the aircraft would have stalled, any many people would probably have died. As it was "only" three live were lost. Well I have to disagree with this. We train annually now to fly below stick shaker to escape microburst wind shear ground contact on t/o. We will go below stall speed (bugged) momentarily in ground effect will full power to avoid contact. We don't care about airspeed. We only look at V/S. If we didn't do this, some dry microbusts would kill us. Risking a stall is always better than contact with hard objects. (remember impact g-force energy goes up exponentially with speed) (besides: most jets don't break fast, they burble and pre-buffet a bit first. After a positive rate is obtained and we're still alive, then we fly on intermittent stick shaker (way higher deck angles than FD/AP AOA limits) until about 1000 ft AGL. AOA FBW autopilots never fly at speeds this low to escape terrain to my knowledge. But I'd have to ask an A320 driver to be sure. The other thing that bugs me about that machine is not being able to bust into a 45 degree bank. (Another thread for that one.) But keep in mind that if you'd advocated these advanced techniques twenty years ago, they would've pulled your ticket. :-( (but you'd still be alive.) :-) Now's its req FAA training. Note: These techniques vary widely from airline to airline and change from Chief Kahuna to Chief Kahuna. YMMV. For the record I think FADEC is great. Do you want it in your GA airplane? Cheers, pacplyer |
On Mon, 01 Mar 2004 17:52:00 -0800, pacplyer wrote:
Great Stuff Kevin, thanks for your insight. I have a couple of points I slightly disagree with however further down in your post. :-) Kevin Horton wrote: After you got yourself behind the power curve, however, for whatever reason, I'm essentially talking about old-school guys like me who were used to flying non-FADEC machines capable of "overboost." If you got into trouble, because you were stupid, in say the previous generation of Boeing products: You could always push up and call for power far in excess of limiting max GA epr or N1, N2, EGT limits. (but maybe that's because like you say: old eng's didn't operate so close to the surge/stall margin.) It's unlikely the engines were going to fail like a piston or super/turbo charged engine might. Those old buckets would warp. The blades might creep and stretch and the engines might have to be scrapped (at say 5 mill a copy.) But you had a better chance of clearing the trees by going all way the to the mechanical stops (physical wire to the FCU Hydr/Mech linkage) than you do now with a Throttle resolver / PFM/MEC/ FADEC arrangement. The airbus test pilot may think he's called for Jesus power, but FADEC will not let him have it. This may have saved me a couple of times in my career flying 60's gen aircraft overseas. You smash everything to the wall and only slightly pull back on the engines that are "barking." (compressor stalling.) ATC would steer you into mountains in those days in some places. (more war stories.) OK. I misunderstood your gripe against FADECs in the first message. I too am not happy to have a FADEC limit how much thrust I get out of the engine. I would much rather have some way to override it if the s*** hits the fan. But, I don't think this would have made any difference in the Habsheim accident. All published reports have said either that the engines didn't respond at all, or that they were still spooling up when he hit the trees. The only report I can find that actually quotes an N1 says the engines were at 83% N1, which must be well below TOGA, so the engines would have still been accelerating, and it wouldn't have mattered what rpm was commanded. There was a bit on an internal bun fight at Bombardier when the CRJ-700 was being designed. It has a FADEC engine, and the flight test folks were not happy about the inability to get more thrust if needed. The engine does have an Automatic Power Reserve (APR) that commands a thrust bump if you have an engine failure. The powerplants engineers were persuaded to add a heavy detent that you can push the thrust levers through to allow you to get APR thrust with both engines running if you really need it. The Bombardier Global Express also has a FADEC engine, but there are two little switches behind the thrust levers that allow the crew to manually select a back up N1 control mode. If the engine is in N1 control mode, you are no longer limited except by the overspeed limiter, which allows you to get much more thrust if needed. Turbine engines run more efficiently if they are running close to the surge line (i.e almost ready to compressor stall). But the engine has to come closer to the surge line to accelerate. So the closer you run to the surge line the slower acceleration you'll have. FAR 25.119(a) requires go-around performance to be calculated using the thrust that is available 8 seconds after a throttle slam from idle. Manufacturers want the engine to run as efficiently as possible, but they don't want to take a hit on the AFM go-around performance. So, they typically design the fuel controls to allow full go-around thrust to be reached in just less than 8 seconds from a throttle slam from idle. I've done tests to check the acceleration on many transport category aircraft, and the result is usually somewhere between 7 and 8 seconds, and this is the same no matter whether the engine has a FADEC or an "old fashioned" hydro-mechanical fuel control unit. Were the engines in flight idle? Were you guys pulling the ground sensor breaker? Ground idle takes longer. Older High Bypass designs eg: the GE CF6-80 series only take about six seconds from flight idle to reach GA thrust IIRC, but still cannot over boost. But it's more like twelve seconds in profile mode (slow spool up looking at FMS parameters.) So I remembered it wrong. I think he tried to change alt with Level Change and Profile mode engaged first, and when nothing much happened (norm) he smashed the thrust levers to the wall and ate wood. But Kevin, I'll concede the acceleration argument to you. (Older designs were even slower (something like fifteen seconds to spool up (e.g. GE CF700's aft-fans.) You could bust altitudes descending, if you didn't lead with the throttles a couple thousand feet before level off. The 8 second requirement is for an acceleration from flight idle. There is typically some worst case condition (specific bleed configuration, altitude and temperature) where the engine will be close to 8 seconds, and it will be a bit better at other conditions. So I am not surprised if you saw about 6 seconds in many cases. So don't blame the FADEC for the A320 accident at Mulhouse-Habsheim. It was caused by a pilot who had way too much confidence in the low-speed protections of the FBW. Yep, you're right. FADEC by itself didn't put him in the trees. But most accidents have "a chain" of factors that cause the accident. If you can break any one of the factorial links the accident would not happen. I submit the inability to get over-boost power was just one of those links. Another was a FBW AOA limit that cannot be temporarily sacrificed to clear obstacles. Fortunately the FBW prevented him from raising the nose, as then the aircraft would have stalled, any many people would probably have died. As it was "only" three live were lost. Well I have to disagree with this. We train annually now to fly below stick shaker to escape microburst wind shear ground contact on t/o. We will go below stall speed (bugged) momentarily in ground effect will full power to avoid contact. We don't care about airspeed. We only look at V/S. If we didn't do this, some dry microbusts would kill us. Risking a stall is always better than contact with hard objects. (remember impact g-force energy goes up exponentially with speed) (besides: most jets don't break fast, they burble and pre-buffet a bit first. After a positive rate is obtained and we're still alive, then we fly on intermittent stick shaker (way higher deck angles than FD/AP AOA limits) until about 1000 ft AGL. AOA FBW autopilots never fly at speeds this low to escape terrain to my knowledge. But I'd have to ask an A320 driver to be sure. The other thing that bugs me about that machine is not being able to bust into a 45 degree bank. (Another thread for that one.) Well, the AOA limiter an the Airbus's is set very close to the stall. It is well beyond where a stick shaker would be. The curve of lift vs AOA tends to have a fairly flat top with modern swept wing jets, so once you get up on top of that curve there isn't any benefit to pulling more AOA, as you don't get any more lift. I wish there was some way to get in a FBW Airbus sim with you. We could do two windshear recoveries - one using full aft stick riding on the AOA limiter, and one in Direct Law, with no AOA limiter. I'm convinced you would do better just using the AOA limiter. For the record I think FADEC is great. Do you want it in your GA airplane? Well, I'm a suspicious type, and I want to see some more service history first to assure myself that they've sorted all the bugs out. So not on my RV-8 project, but maybe on the next one. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
Kevin Horton wrote snip
Well, the AOA limiter an the Airbus's is set very close to the stall. It is well beyond where a stick shaker would be. The curve of lift vs AOA tends to have a fairly flat top with modern swept wing jets, so once you get up on top of that curve there isn't any benefit to pulling more AOA, as you don't get any more lift. I wish there was some way to get in a FBW Airbus sim with you. We could do two windshear recoveries - one using full aft stick riding on the AOA limiter, and one in Direct Law, with no AOA limiter. I'm convinced you would do better just using the AOA limiter. I would enjoy that. You could be right. For the record I think FADEC is great. Do you want it in your GA airplane? Well, I'm a suspicious type, and I want to see some more service history first to assure myself that they've sorted all the bugs out. So not on my RV-8 project, but maybe on the next one. Sounds very wise indeed. Great shots of your RV-8 by the way. pac |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
want variable pitch prop | Ray Toews | Home Built | 5 | October 7th 03 09:59 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
