Maule Driver wrote:
I was trying to think through the meaning of 'radar services' and 'flight following'. I was thinking that you are not bound to maintain a heading or an altitude while under FF (right?). So that would mean that you can deviate from your reported heading and altitude and enter Class D without necessarily notifying the controller. Sure, you can change heading and altitude without necessarily notifying the controller, but situational awareness and common sense do enter into it. The radar controller will make a decision on whether or not he needs to coordinate based on your altitude and direction of flight. If you need to change either or both, and that change might put you in a surface area your original altitude and heading would keep you clear of, it may not be a regulatory requirement to communicate your intentions but it only makes sense IMO. The particular situation described is problematic, because the facility providing radar services terminated them w/out a handoff. In that circumstance, I personally would probably contact the tower immediately, including in my call up something like "I had radar services from XXXX, I assume they coordinated with you". (because that's what's supposed to happen). Really puts the focus on situational awareness when that happens! Well, Steve may be correct that the communication requirements have been met, but I'd personally contact the tower in those circs, just in case there was a need to communicate; IME it takes several minutes to establish communication and radar contact with a busy approach facility, and I really don't want to be distracted from keeping a sharp look-out when I'm close to an airport, either. Cheers, Sydney |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Which post-WW2 combat aircraft have not been used in combat? | Kirk Stant | Military Aviation | 96 | December 10th 03 03:03 PM |
Hispanic Hero Recalls Experiences | Otis Willie | Military Aviation | 0 | September 30th 03 10:02 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
