If you are planning to invest in an installed system then I agree the WSI
system is the best at this point. It is a "transmission" rather than "request" system so therefore you can get continually updated weather data. Even more importantly, WSI is an extremely well-established entity in the weather data industry and therefore it is quite likely they will remain around for the foreseeable future. Even more importantly, the data displayed on their weather datalink system is basically the same data as you can get on the web via www.intellicast.com so the learning curve to learn how to interpret the data will be much less than with the other panel-mount datalink providers. I know of a client/student of mine who uses this system regularly and has been very pleased, and I saw it installed in another student's plane and he was similarly pleased with it. Frankly, if I were to put an installed datalink system in my airplane at this point then I would be most interested in the WSI system but the main reason I have not done so yet is because I have an RDR-160 radar system in my plane and the only current multi-function display which can interface with that radar is the Avidyne display. -- Richard Kaplan, CFII www.flyimc.com |
"Richard Kaplan" wrote:
If you are planning to invest in an installed system then I agree the WSI system is the best at this point. It is a "transmission" rather than "request" system so therefore you can get continually updated weather data. What, in your opinion, makes this system superior to Bendix/King's KMD 250, KDR 510 uplink system? Both are transmission systems, one satellite, one ground, how do they compare otherwise? I was pleasantly surprised by B/K's system at OSH. It seemed easy to use and the update speed ane resolution were very good. Its high baud rate seemed to eliminate some of the software funny business that satellite based systems resort to for getting images through their limited bandwith. -- Dan C172RG at BFM |
One of the main problems with the Bendix/King system is that since it is ground-based, in many situations you cannot use it to get a weather picture before takeoff or at "low" altitude ("low" depending on how near a transmission station is to where you are flying, of course). So it might not be available when you really want to use it. Yes, that is a disadvantage of their system. But it looks like WSI's map is not a moving map that will show the position and direction of the aircraft, a big disadvantage, IMO - is that true? Another nice feature of the WSI system is that the data is the same as what you see on the Internet at www.intellicast.com and it is also the same data most of us see at FBOs across the country -- please correct me if I am wrong, but I do not think there is an Internet site to view the data in the Bendix/King system. This is important because there is a learning curve in any radar or Nexrad system to learn how to interpret the graphics from the perspective of "Am I willing to fly thorugh that?" Most of us are already quite familiar with radar images from Intellicast or from WSI computers at FBOs. With the Bendix/King system, you may not even be able to turn on your avionics on the ground to work through this learning curve. They have the brochure on line at http://www.bendixking.com/static/bro...pdf/KDR510.pdf which shows the MFD depicting NEXRAD base reflectivity. Looks just like what I see on Intellicast. The unit also gives graphic METARS, etc. My main concern about the satellite systems is still the bandwith question. B/K had a pretty convincing demonstration of how other venders' bandwith-saving software tricks could cause innacurate weather images. Also, due to limited bandwidth, map resolution was not as good on the satellite systems. -- Dan C172RG at BFM |
![]() "Dan Luke" wrote in message ... Yes, that is a disadvantage of their system. But it looks like WSI's map is not a moving map that will show the position and direction of the aircraft, a big disadvantage, IMO - is that true? That is true if you use a laptop as the display for the WSI system -- then then again, a laptop is not even a display option for the Bendix/King system. If you connect the WSI system to an MFD then the MFD already has your position on the map. http://www.bendixking.com/static/bro...pdf/KDR510.pdf which shows the MFD depicting NEXRAD base reflectivity. Looks just like what I see on Intellicast. The unit also gives graphic METARS, etc. NEXRAD base reflectivity is the raw data from each data site; weather datalink vendors then merge this data to create a composite national or regional image. There is quite a bit of proprietary digital image processing involved -- that is why, for example, weather on www.intellicast.com looks different from weather on www.theweatherchannel.com etc. The color coding can be different, some vendors may choose to delete returns under 10dB or under 15dB, and some vendors have different processes to remove ground clutter by either manual or automated techniques. The bottom line is that for the critical decision of deciding whether a given area of Level 3 weather is convective or benign, it is a big help to have experience with that particular source of weather data. The WSI system lets you learn about their image processing on the ground via the Internet; the Bendix/King system only lets you learn by trial-and-error in the air. My main concern about the satellite systems is still the bandwith question. B/K had a pretty convincing demonstration of how other venders' bandwith-saving software tricks could cause innacurate weather images. Also, due to limited bandwidth, map resolution was not as good on the satellite I saw the demonstration too, and my impression was that this degree of accuracy only mattered to a turboprop or jet pilot attempting to penetrate a line of thunderstorms, in which case he ought to have high-power vertical profiling radar as well -- not an issue likely to be relevant to most of the piston IFR pilots on this group, myself included. Far more important to me is the ability to get an accurate view of the weather on the ground before takeoff and in the initial climb segment of my flight... the Bendix/King system may be more accurate, but its data is simply unavailable for these important portions of flight or during flight planning. If I can plan early and request a routing to give me a good margin around the weather, then it really does not matter if my image has slightly less resolution compared with an alternate system which only works above a given altitude. One of the best advantages of weather datalink is the ability to depart from a small airport which has no weather resources and be able to make a pre-flight decision on flying around/through areas of convective activity. A satellite-based system such as WSI works great for this purpose at any airport; the Bendix/King system will often be completely unavailable on the ground in the same situation. -- Richard Kaplan, CFII www.flyimc.com |
![]() "Richard Kaplan" wrote in message news:0c9eb7ec245c44683f14df2697f2042c@TeraNews... "Dan Luke" wrote in message ... What, in your opinion, makes this system superior to Bendix/King's KMD 250, KDR 510 uplink system? Both are transmission systems, one satellite, one ground, how do they compare otherwise? One of the main problems with the Bendix/King system is that since it is ground-based, in many situations you cannot use it to get a weather picture before takeoff or at "low" altitude ("low" depending on how near a transmission station is to where you are flying, of course). So it might not be available when you really want to use it. Another nice feature of the WSI system is that the data is the same as what you see on the Internet at www.intellicast.com and it is also the same data most of us see at FBOs across the country -- please correct me if I am wrong, but I do not think there is an Internet site to view the data in the Bendix/King system. This is important because there is a learning curve in any radar or Nexrad system to learn how to interpret the graphics from the perspective of "Am I willing to fly thorugh that?" How is it (Nexrad) different? Most of us are already quite familiar with radar images from Intellicast or from WSI computers at FBOs. With the Bendix/King system, you may not even be able to turn on your avionics on the ground to work through this learning curve. I suspect the Garmin 400/500 series with a GDL49 uplink and a subscription to EchoFlight would be more expensive?? Or EchoFlight with their Flight Cheetah? http://www.garmin.com/products/gdl49/ http://www.echoflight.com/data_link.html |
![]() "Tom S." wrote in message ... How is it (Nexrad) different? Nexrad and radar are similar but Nexrad is better than radar at showing intensities inside a given storm cell. An isolated radar or Nexrad site base reflectivity return shows ground clutter and other artifacts. For example, radar and Nexrad get less sensitive at the fringes of a given radar site's coverage area. When we talk of "Nexrad" we are usually talking about the composite national Nexrad image. That image is created by digitally processing the images from multiple sites into a national mosaic -- this process is usually partly automated and partly done manually, but in any event there is some subjectivity involved. The end result is that a composite Nexrad image usually is easier to interpret than comparing isolated radar sites. And Nexrad weather datalink allows a pilot to view the big picture of the whole country rather than just the coverage area of an airplane's onboard radar. The primary disadvantage of Nexrad composite images compared with onboard radar is that Nexrad provides no information regarding how high the reflected precip goes. So what appears as precip on Nexrad may really be no more than low-level mist; I have seen this often in flight. Airplane-mounted radar does not have nearly the range of composite Nexrad but does have the advantage that the pilot can tilt the radar's energy up or down and thus -- with training -- calculate how high precipitation goes. There is a solution to the problem of calculating Nexrad precip heights -- NOAA maintains a national network of doppler precip tops radar. Unfortunately this government-generated precip tops radar data is not available to FSS (!), but several subscription websites and some of the weather datalink vendors do indeed have make available the precip tops radar data. -- Richard Kaplan, CFII www.flyimc.com |
The GDL49 / EchoFlight solutions are actually much less expensive that
either WSI or the XM/WxWorx systems. However, after considerable research, I have concluded the GDL49 is not currently a viable solution for me. The download rate is an anemic 2800 baud, and the data resolution is in the 4 - 10 km range, far to coarse to make any but the most basic strategic weather decisions. There is also the issue with the VHF band used for the datalink is VERY close to your Com bands, so I have heard some grumblings about bad installs and interference with the datalink from Com (i.e. don't key the mike if you are trying to get wx data...) I have also heard horror stories about data age and delays in the request/receive. No other system is compatible with the 430/530 at this time. I have personally written off this technology unless Garmin figures out a better compression scheme and they solve the interference and data age problem. Notice that Garmin has opted for the WxWorx/XM Radio solution for their new, high dollar G1000 system, the GDL49 wasn't considered. WSI certified boxes run in the $5K range plus install. I still cannot understand how you can mount an "uncertified" box on an aircraft without an STC or 337 approval. You will need an additional antenna, and cable runs. WxWorx claims to have a "portable" system, but I still think you need one of their antennas mounted and cables run, so as far as a "less expensive" system, I doubt it. All the "broadcast" systems to date have been in the $50/month range. Echoflight has three different subscription plans, I think it was in the $40/month range. The King system using ground based towers has huge holes in coverage, especially where I tend to fly, so it is useless for me, and I doubt a ground based system will ever have utility for me. The technology is here for quality broadcast weather, but it still looks like it will be some time before a truely portable or certified system at a reasonable cost is available. It really surprises me that I bought a Sirius Satellite Radio for $100 that is 100% portable (including antenna that sits on my glareshield) and plugs into my music jack and lighter outlet and pay $12/month for 100 channels, but I can't get a 100% portable wx broadcast system, and still have to shell out over $4K+ $50/month!!!! About the only thing on the market that is reasonable and functional at the moment appears to be AnywhereWx using a Globalstar sat phone, but there are issues with interference from some models of the KT76 transponder. Looks like it will be another year or two... "Tom S." wrote in message ... "Richard Kaplan" wrote in message news:0c9eb7ec245c44683f14df2697f2042c@TeraNews... "Dan Luke" wrote in message ... What, in your opinion, makes this system superior to Bendix/King's KMD 250, KDR 510 uplink system? Both are transmission systems, one satellite, one ground, how do they compare otherwise? One of the main problems with the Bendix/King system is that since it is ground-based, in many situations you cannot use it to get a weather picture before takeoff or at "low" altitude ("low" depending on how near a transmission station is to where you are flying, of course). So it might not be available when you really want to use it. Another nice feature of the WSI system is that the data is the same as what you see on the Internet at www.intellicast.com and it is also the same data most of us see at FBOs across the country -- please correct me if I am wrong, but I do not think there is an Internet site to view the data in the Bendix/King system. This is important because there is a learning curve in any radar or Nexrad system to learn how to interpret the graphics from the perspective of "Am I willing to fly thorugh that?" How is it (Nexrad) different? Most of us are already quite familiar with radar images from Intellicast or from WSI computers at FBOs. With the Bendix/King system, you may not even be able to turn on your avionics on the ground to work through this learning curve. I suspect the Garmin 400/500 series with a GDL49 uplink and a subscription to EchoFlight would be more expensive?? Or EchoFlight with their Flight Cheetah? http://www.garmin.com/products/gdl49/ http://www.echoflight.com/data_link.html |
![]() "Mark T. Mueller" wrote in message ... The GDL49 / EchoFlight solutions are actually much less expensive that either WSI or the XM/WxWorx systems. However, after considerable research, I The portable XM/WxWorx system is MUCH cheaper (well, cheaper if I presume you already own a laptop computer).. The system costs between $650 and $850 for the hardware plus $49/month for the subscription. The downside is that there are lots of wires to carry around; the upside is that it is portable. WxWorx claims to have a "portable" system, but I still think you need one of their antennas mounted and cables run, so as far as a "less expensive" No, the antenna can go right on the glareshield just like a portable GPS antenna. The technology is here for quality broadcast weather, but it still looks like it will be some time before a truely portable or certified system at a I agree there are some practical issues to the XMRadio/WxWorx system, but it is indeed portable. My thought is that on the days when I know there will be convective weather, it is worth putting up with the wires in order to make the flight, but I suspect I will not use the system on non-convective days. system, and still have to shell out over $4K+ $50/month!!!! About the only thing on the market that is reasonable and functional at the moment appears to be AnywhereWx using a Globalstar sat phone, but there are issues with XM/WxWorx is notably cheaper and definitely more practical than AnywhereWx with a sat phone. AnywhereWx has just as many wires and it is a reply/request model. One really nice feature of XM/WxWorx is that you can "set it and forget it" -- once you set it up before flight, just glance at the laptop every 5 minutes or so and the automatically updated weather will be there. The hard part of the technology is there (satellite reception)... I just wish they would combine the battery/display/receiver all into one box like a portable GPS. -- Richard Kaplan, CFII www.flyimc.com |
![]() The portable XM/WxWorx system is MUCH cheaper (well, cheaper if I presume you already own a laptop computer).. The system costs between $650 and $850 for the hardware plus $49/month for the subscription. The downside is that there are lots of wires to carry around; the upside is that it is portable. WOW! That's much less than I had heard. IF they actually MSRP for that, EchoFlight is DEAD, and WSI will have to reduce the cost of their box and make it up on the subscriptions... Any idea when the WxWorx boxes will be available? I am ready now! No, the antenna can go right on the glareshield just like a portable GPS antenna. I must have missed that one at OSH. The WxWorx reps were showing me different antenna options, and a puck to throw on the glareshield was not one of them. However, I would probably go for the COMDAT mast that combines the XM and VHF Com into a single antenna. Cleaner install, and one for one replacement on my turtleback. Hopefully Garmin will get its head out of its ass and port this thing to the 430/530. I agree there are some practical issues to the XMRadio/WxWorx system, but it is indeed portable. My thought is that on the days when I know there will be convective weather, it is worth putting up with the wires in order to make the flight, but I suspect I will not use the system on non-convective days. I hope they work them out in short order. I would use it just about anytime. My current plans are to drop a serial connection to my 530 so I can plug a Fujitsu 4121 Tablet PC for GPS, then pull the WxWorx into the Tablet. The 4121 is daylight readable, and I can also use it as a "laptop" for work... Flightprep offers subscriptions for pdf approach plates, and it would be a great backup for that as well. XM/WxWorx is notably cheaper and definitely more practical than AnywhereWx with a sat phone. AnywhereWx has just as many wires and it is a reply/request model. One really nice feature of XM/WxWorx is that you can "set it and forget it" -- once you set it up before flight, just glance at the laptop every 5 minutes or so and the automatically updated weather will be there. The hard part of the technology is there (satellite reception)... I just wish they would combine the battery/display/receiver all into one box like a portable GPS. Thanks for the updates. I am sure SOMEONE will produce an integrated solution that can be plugged into a laptop or Tablet PC... God knows the market is there. The lines at OSH for all of the current providers was quite long. -- Richard Kaplan, CFII www.flyimc.com |
: I bought a Sirius Satellite Radio for $100 that is 100% portable (including antenna that sits on my glareshield) and plugs into my music jack and lighter outlet and pay $12/month for 100 channels, but I can't get a 100% portable wx broadcast system, and still have to shell out over $4K+ $50/month!!!! It needs a driver, and aviation isn't it. [The airlines don't care much - heck, most of them don't have GPS yet; and there just aren't all that many dollars in GA.] My big hope is the same as for GPS - the marine and sports market. There are enough coastal small boats without weather radar to force some competition. If they get interested, then we will see those $200 portable color weather receiver/displays. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
Uplink weather advice | Richard Kaplan | Instrument Flight Rules | 15 | August 31st 03 11:39 PM |
Uplink weather advice | Richard Kaplan | Owning | 14 | August 31st 03 11:39 PM |
Uplink weather advice | Klein Gilhousen | Owning | 0 | August 12th 03 05:59 PM |
