Uplink weather advice
Old August 11th 03, 04:05 AM
Richard Kaplan
"Mark T. Mueller" wrote in message
The GDL49 / EchoFlight solutions are actually much less expensive that
either WSI or the XM/WxWorx systems. However, after considerable research,
I
The portable XM/WxWorx system is MUCH cheaper (well, cheaper if I presume
you already own a laptop computer).. The system costs between $650 and $850
for the hardware plus $49/month for the subscription. The downside is that
there are lots of wires to carry around; the upside is that it is portable.
WxWorx claims to have a "portable" system, but I still think you need one
of
their antennas mounted and cables run, so as far as a "less expensive"
No, the antenna can go right on the glareshield just like a portable GPS
antenna.
The technology is here for quality broadcast weather, but it still looks
like it will be some time before a truely portable or certified system at
a
I agree there are some practical issues to the XMRadio/WxWorx system, but it
is indeed portable. My thought is that on the days when I know there will
be convective weather, it is worth putting up with the wires in order to
make the flight, but I suspect I will not use the system on non-convective
days.
system, and still have to shell out over $4K+ $50/month!!!! About the only
thing on the market that is reasonable and functional at the moment
appears
to be AnywhereWx using a Globalstar sat phone, but there are issues with
XM/WxWorx is notably cheaper and definitely more practical than AnywhereWx
with a sat phone. AnywhereWx has just as many wires and it is a
reply/request model. One really nice feature of XM/WxWorx is that you can
"set it and forget it" -- once you set it up before flight, just glance at
the laptop every 5 minutes or so and the automatically updated weather will
be there. The hard part of the technology is there (satellite reception)...
I just wish they would combine the battery/display/receiver all into one box
like a portable GPS.
Richard Kaplan, CFII
www.flyimc.com
Old August 11th 03, 11:19 AM
Mark T. Mueller
$850
that
portable.
WOW! That's much less than I had heard. IF they actually MSRP for that,
EchoFlight is DEAD, and WSI will have to reduce the cost of their box and
make it up on the subscriptions...
Any idea when the WxWorx boxes will be available? I am ready now!
antenna.
I must have missed that one at OSH. The WxWorx reps were showing me
different antenna options, and a puck to throw on the glareshield was not
one of them. However, I would probably go for the COMDAT mast that combines
the XM and VHF Com into a single antenna. Cleaner install, and one for one
replacement on my turtleback. Hopefully Garmin will get its head out of its
ass and port this thing to the 430/530.
it
days.
I hope they work them out in short order. I would use it just about anytime.
My current plans are to drop a serial connection to my 530 so I can plug a
Fujitsu 4121 Tablet PC for GPS, then pull the WxWorx into the Tablet. The
4121 is daylight readable, and I can also use it as a "laptop" for work...
Flightprep offers subscriptions for pdf approach plates, and it would be a
great backup for that as well.
will
reception)...
box
Thanks for the updates. I am sure SOMEONE will produce an integrated
solution that can be plugged into a laptop or Tablet PC... God knows the
market is there. The lines at OSH for all of the current providers was quite
long.
www.flyimc.com
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
Uplink weather advice Richard Kaplan Instrument Flight Rules 15 August 31st 03 11:39 PM
Uplink weather advice Richard Kaplan Owning 14 August 31st 03 11:39 PM
Uplink weather advice Klein Gilhousen Owning 0 August 12th 03 05:59 PM
