![]() "Dave Russell" wrote in message om... So there I am, rolling on 32 (turf), the tail's just come up... when an Archer blithely rolls right out in front of me on the taxiway for 4. :-| You can't see much of the taxiway from the departure end of 4 because of a hangar, and this guy was rolling along pretty good. He was fully on the runway ahead of me when he saw me, drilled the brakes, and stopped cold. I put in a pretty interesting swerve (just not enough room to go over him with the back seat loaded... but I did consider it for a split second) and managed to roll past with enough clearance not to terrify me (the swerve had already done that). Thank goodness 32 is wide. There was nothing I could have done to prevent this. I'd made a departure radio call, I'd been monitoring the frequency, and I checked (while taxiing back) to make sure I had the right frequency. This guy just didn't look or listen. How do you know he didn't look or listen? If you can't see much of the taxiway from the departure end of 4 because of a hangar, then obviously you can't see the departure end of runway 4 from much of the taxiway. Just because you're speaking into the microphone doesn't mean you're broadcasting. |
"Steven P. McNicoll" wrote in message hlink.net...
How do you know he didn't look or listen? If you can't see much of the taxiway from the departure end of 4 because of a hangar, then obviously you can't see the departure end of runway 4 from much of the taxiway. Just because you're speaking into the microphone doesn't mean you're broadcasting. My fault... I miskeyed. Let me try again. I was rolling for takeoff on 32. He was on a perpendicular taxiway and taxied right out in front of me, headed for 4. If he had looked before crossing 32, he'd have seen a propellor headed for him at takeoff power. I'm guessing he didn't look or he would have stopped short of 32. The hangars are a bit of a factor in that you can't see the end of 32 (that's the part I mistyped) until you clear them on the taxiway for 4, but there's still plenty of room if you're even romotely awake. -DJR |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
New Ulm, MN (ULM) Airport Runway Extension Study | Dan Hoehn | General Aviation | 1 | May 5th 04 03:33 PM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 02:46 AM |
