![]() "Robert Perkins" wrote in message ... On Sat, 16 Aug 2003 01:04:26 GMT, "Dan Moos" wrote: Some one please give me an "Amen!" if they feel as I do Most of the VOR terminology mentioned in this thread is correct, but that doesn't make it useful for a beginner. You can't have one from me. Learn and use a VOR the way it was designed: as an instrument which tells you your *position*, *not* your course line, and you'll never have a problem with reverse sensing. Yes, and no. First of all, my method doesn't disagree with what you say. Nothing I wrote suggests that I know which way the plane is pointing by looking at a snapshot of the CDI needle. Because it doesn't. BUT, if I have 300 degrees dialed in to the OBS and keep the needle centered for a few minutes or more, I think the VOR is great for giving you a course line. Thats why it is the primary instrument for IFR navigation. Of course, you need to use other instruments to establish yourself on that course line, and until you do, it is true that the VOR only gives you your position. And as far as describing your position to someonelse (ATC maybe), your method is much more proper. That is why when ATC says "Hold southeast of HUH on the 120 degree radial", it makes sense. If you do it that way, you're not perceiving radials, you're perceiving lines. Precisely. Most people understand lines, whereas radials require some simplification. Really the only difference in doing it my way is that I don't have to deal with reciprical values. I get the same results as your method. I have NEVER misinterpreted a VOR reading, and personally think it is the way of describing radials that is is taght in most places that is responsible for confusing people about a simple instrument. If you want to follow an arrow to your course, use an ADF. VOR's are better for position detection. My method works equally on ADF. I just think of an ADF as a VOR that requires me to read my compass or DG to get what I need. You CAN follows "radials" on an ADF this way, and my imaginary line through the NDB method is especialy usefull here because there is enough calculation going on in your head to follow a specific course line with the ADF that you don't need weird reciprical course values to muddle things up. Actually, I think a VOR is a FAR superior course following instrument then an ADF. Look at it this way. I'm enroute IFR to the IAF. Lets first suggest that the IAF in this case is an NDB. I'm enroute, and I lose my directional gyro. lets also say that turbulence isa makeing the mag compass unreadable. At this point I have no concrete idea What my course line is. What is the wind doing? Who knows, because to use the ADF for COURSE information, I need to also know my actual heading. No DG or compass, and the wind could eventually make my track WAY of line. And if I'm aproaching the IAF, I'll be maybe 1000 feet or less above pattern altitude when I get there, not good if I have no real idea from which direction I'm approaching the station. Do the same exercise whith the VOR. No problem, because the VOR is giving you constant COURSE information. If the wind screws with you, you will see it. Here lies the main problem. If you truly believe that the VOR gives you no course line info, then your way of thinking has caused you to not really understand the instrument. |
![]() Learn and use a VOR the way it was designed: as an instrument which tells you your *position*, *not* your course line, and you'll never have a problem with reverse sensing. No, with one exception, it does not tell you your position. That single exception is when you overfly the antenna. Then, you may presume the antenna is some altitude dependent radius from the nadir. Otherwise, the only thing the VOR will tell you is BEARING from the station. |
"Casey Wilson" wrote:
Learn and use a VOR the way it was designed: as an instrument which tells you your *position*, *not* your course line, and you'll never have a problem with reverse sensing. No, with one exception, it does not tell you your position. That single exception is when you overfly the antenna. No. One may use a VOR receiver and CDI to compute one's position by flying perpendicular to a radial, timing the observed deflection, and applying a simple formula. -- Dan C172RG at BFM |
![]() "Dan Luke" wrote in message ... "Casey Wilson" wrote: Learn and use a VOR the way it was designed: as an instrument which tells you your *position*, *not* your course line, and you'll never have a problem with reverse sensing. No, with one exception, it does not tell you your position. That single exception is when you overfly the antenna. No. One may use a VOR receiver and CDI to compute one's position by flying perpendicular to a radial, timing the observed deflection, and applying a simple formula. In which case the VOR did NOT give you your position. The calculation required additional instruments: A timer and some device (compass or DG) to fly perpendicular to a radial, not to mention the use of the ASI, and so forth. I say again, the VOR did NOT give you your position. By the way, flying perpendicular to one radial is NOT perpendicular to the next, so the calculation is flawed. |
![]() "Casey Wilson" wrote: In which case the VOR did NOT give you your position. The calculation required additional instruments: A timer and some device (compass or DG) to fly perpendicular to a radial, not to mention the use of the ASI, and so forth. Silly hair splitting. You also said the VOR will give you bearing from the station: how will it do that without the use of other equipment? -- Dan C172RG at BFM |
Student here, following debate with interest but I don't understand the
issue at disagreement. Considering "bearing" as distinct from "relative bearing", is not the bearing the clockwise angular direction with respect to the meridian over its origin of a line drawn from one point to another? And since the 0 radial of the VOR station is aligned to the magnetic meridian, each VOR radial indicates directly the magnetic bearing from the VOR station to an object that lies somewhere along it. To get one's bearing from the VOR station, than, can you not just rotate the OBS until the needle is centred? If the "from" flag is up then the OBS ring reads out directly the magnetic bearing to the aircraft as viewed from the VOR station, and if the "to" flag is up, the OBS is showing the reciprocal. So don't you know you're somewhere along that line? Of course, neither indication gives the actual aircraft position without using some other additional means to establish distance from the station - DME, triangulation on another station, etc. Same principle with a movable card ADF set to or slaved to one's compass heading, except that its needle is always indicating the bearing to whatever station that's tuned so one needs to convert that reading into the radial bearing from the station of interest to the plane (I know that the conversion assumes the magnetic variation at the plane's position is not different from that at the station's position, if you want to get precise). "Dan Luke" wrote in message ... "Casey Wilson" wrote: In which case the VOR did NOT give you your position. The calculation required additional instruments: A timer and some device (compass or DG) to fly perpendicular to a radial, not to mention the use of the ASI, and so forth. Silly hair splitting. You also said the VOR will give you bearing from the station: how will it do that without the use of other equipment? -- Dan C172RG at BFM |
![]() "Steve House" wrote in message ... Student here, following debate with interest but I don't understand the issue at disagreement. Considering "bearing" as distinct from "relative bearing", is not the bearing the clockwise angular direction with respect to the meridian over its origin of a line drawn from one point to another? And since the 0 radial of the VOR station is aligned to the magnetic meridian, each VOR radial indicates directly the magnetic bearing from the VOR station to an object that lies somewhere along it. To get one's bearing from the VOR station, than, can you not just rotate the OBS until the needle is centred? If the "from" flag is up then the OBS ring reads out directly the magnetic bearing to the aircraft as viewed from the VOR station, and if the "to" flag is up, the OBS is showing the reciprocal. So don't you know you're somewhere along that line? Yes. That was my point exactly. Only, somewhere along that line could be anywhere within about a 200 square mile area when you factor in the inherent accuracy of the single VOR. Of course, neither indication gives the actual aircraft position without using some other additional means to establish distance from the station - DME, triangulation on another station, etc. Yes. That was my point exactly. |
"Casey Wilson" wrote in message
... No, with one exception, it does not tell you your position. That single exception is when you overfly the antenna. Then, you may presume the antenna is some altitude dependent radius from the nadir. Otherwise, the only thing the VOR will tell you is BEARING from the station. How is that not "position"? Granted, it's not a very accurate description of one's position, but it certainly describes one's position to an extent. Given that the word "position" is simply being used to contrast with heading, course, and other related terms, your objection seems pretty silly to me. Pete |
![]() "Peter Duniho" wrote in message ... "Casey Wilson" wrote in message ... No, with one exception, it does not tell you your position. That single exception is when you overfly the antenna. Then, you may presume the antenna is some altitude dependent radius from the nadir. Otherwise, the only thing the VOR will tell you is BEARING from the station. How is that not "position"? Granted, it's not a very accurate description of one's position, but it certainly describes one's position to an extent. Given that the word "position" is simply being used to contrast with heading, course, and other related terms, your objection seems pretty silly to me. Who is being silly? You are relating apples and oranges. Bearing is related to heading and course, position is related to geographical coordinates. A single VOR won't tell you squat about geographical coordinates. Given that the "standard service volume" (AIM 1-1-8) is at least 40 nautical miles, the definition is not a trivial thing. I have tuned into VOR stations as much as 85 miles away. So, where am I on that line from the station. Let's consider that the acceptable angular error [ FAR 91.171(b)(3) ] can be plus/minus 6 degrees. I don't have my calculator, but I think the formula is cosine of the angle times the distance... I'm only guessing, but I think that at the forty mile limit, the aircraft could be as much as five to seven miles on either side of the displayed bearing angle. Hmm, let's see: base times height divided by two [40 miles times 5 miles then divide by 2] gives 100 square miles. Wait, that was only the half-angle -- multiply by two to cover the other side and we are up to 200 square miles of area over which the airplane could be flying. I like using the VOR, I like having two of them in the panel. Hell, I even like the ADF -- got one of those too. When I triangulate any two of those, I have a rough idea of my 'position.' |
... Who is being silly? You are relating apples and oranges. Bearing is related to heading and course, position is related to geographical coordinates. A single VOR won't tell you squat about geographical coordinates. I have no idea what you're talking about. Bearing relative to the VOR station is all about your position relative to the station. Knowing your bearing relative to the station greatly narrows down your geographical coordinates. You can get a lot more accurate using a second VOR or DME, but that doesn't change the fact that even a single VOR is telling you a lot about your geographical coordinates. While on the other hand, the bearing relative to the VOR has NOTHING to do with heading or course. Nothing at all. It boggles my mind that you would say it does. The mistaken impression that it does have something to do with heading or course is where lots of people (the original poster included) get confused. You're just making matters worse by saying that it does. Given that the "standard service volume" (AIM 1-1-8) is at least 40 nautical miles, the definition is not a trivial thing. I have tuned into VOR stations as much as 85 miles away. So, where am I on that line from the station. Just knowing you're on that line is useful GEOGRAPHICAL POSITION information. [...] and we are up to 200 square miles of area over which the airplane could be flying. All you're doing is bickering about just how accurate the GEOGRAPHICAL POSITION information is. A single VOR isn't very accurate at all. Two VORs are more accurate. A VOR with DME is even more accurate. Two VORs with DME each are even more accurate. And a GPS receiver is even more accurate. So what? They all still give you geographical positions. I like using the VOR, I like having two of them in the panel. Hell, I even like the ADF -- got one of those too. When I triangulate any two of those, I have a rough idea of my 'position.' No triangulation is needed to get a rough idea of your position. Triangulation reduces the "roughness" of your position estimate, but a single VOR receiver alone gives you a rough idea of your position. (An ADF, of course, does no such thing...it MUST be referenced to another instrument to provide ANY positional information at all). Pete |
