Oh how lovely.... an O/S flamewar in r.a.p.
While I tend to agree somewhat with your sentiments about MS operating systems, they're not that bad if you run a decent software firewall and antivirus package and make sure you check for updates at least a couple times each day. You should think twice about the satellite internet service, though. My boss lives out in the sticks, had it for a few months and continously complained about it sucking badly before he gave up completely on it. I have to suggest the wireless connection myself. I have a wireless internet feed to my house, from a tower that's 5 miles away and I can get a solid 8 Mbps connection to the tower's WAP. I use a Linksys model WET11 802.11b bridge (~$110 at Best Buy) and a 24db mag grid antenna from www.fab-corp.com (~$70) mounted on a 30' pole outside my house. The WET11 is mounted inside a weatherproof plastic box on the pole directly underneath the antenna. I feed 6 volts DC up the unused wires of the CAT5 cable to power the WET11 remotely so that my antenna coax jumper is only 3' from the antenna to the WET11. Long antenna coax is what kills distance performance when using cheap 802.11b stuff for long-haul duty, so the shorter you can keep the coax, the better. The WET11 comes with a 5V power supply, but the long CAT5 cable has quite a bit of voltage drop so I pump 6V into it from a 2 amp power supply at the computer end and still get 5V under load at the other end up on top the antenna pole. See if one of your airport Linux buddies has DSL or cablemodem service at his house and is willing to share a NAT'ed feed. If he lives within a few miles of the airport and you can manage to put up a pair of antenna poles with 24db antennas pointing at each other, you've then got yourself broadband Internet on a shoestring budget at your FBO. I'd approach your EAA buddies about this plan. If they are into both building airplanes and Linux, they'll probably eat this idea up. |
FBO's and WiFi | Javier Henderson | General Aviation | 43 | August 30th 03 08:22 AM |
