#21
("Scott Lowrey" wrote)
snip Today, though, what looked like an F-18 flew over. Wow. I haven't seen too many fighters in my life (still have yet to see a "real" air show). September 20-21, 2003 http://www.duluthairshow.com/index2.htm Duluth is only 150 mile straight up the freeway from MSP (Mpls/St. Paul) We want to get up there for the Air Show. -- Montblack |
"Tex Houston" wrote in message ...
"Dan Thomas" wrote in message Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm Tex That's the one. Thanks! Dan |
In article , Tex Houston
writes "Dan Thomas" wrote in message Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm Tex ISTR it was nicknamed "Thunderscreech" because of its awful noise, and caused pain and severe nausea to ground personnel in the vicinity when the prop was turning. -- Peter Ying tong iddle-i po! |
Peter Twydell wrote: In article , Tex Houston writes You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm ISTR it was nicknamed "Thunderscreech" because of its awful noise, and caused pain and severe nausea to ground personnel in the vicinity when the prop was turning. I'd put an F-106 at takeoff up against almost anything. It was pretty loud in general, but there were some godawful high harmonics in there that made you feel like someone was ripping giant sheets of canvas *in* your chest. When I worked F-4s, we had an ANG F-106 alert unit sitting at the end of one runway, and when they took off, we'd go into the EOR shack and hide for extra protection - after standing 100 feet away from multiple F-4 launches on full afterburner all day... -- Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
If you do a search for turboprop noise in the NASA archives you will
find the info - the surprising thing to me was that the noise levels were about equal clear out to the sixth harmonic. Yes, the XF84H was loud. But the Saturn 5 was mucho louder, but you couldn't get closer than about 8,000 yards. OTH, standing about 3 feet to one side from the nozzle of a J79-17 at max power is verrry interesting. Walt BJ |
Walt BJ wrote:
If you do a search for turboprop noise in the NASA archives you will find the info - the surprising thing to me was that the noise levels were about equal clear out to the sixth harmonic. Yes, the XF84H was loud. But the Saturn 5 was mucho louder, but you couldn't get closer than about 8,000 yards. OTH, standing about 3 feet to one side from the nozzle of a J79-17 at max power is verrry interesting. Walt BJ I'll second that motion. While not a J79, the engine on the F-16 is quite impressive up close. Did a job shadow with an F-16 crew chief and did final checks with him. One involved lying under the aircraft and checking something just forward of the afterburned turkey feathers. The noise was punishing. MAH |
#28
You want loud? Or annoying?
UH-1H doing a nice slow deceleration at low tq settings will produce a popping sound that is easily heard for more than a mile. And it last a long time. I was flying a CH-47D at 165 knots and the folks on the airfield said they heard us coming for at least five minutes before they saw us. Man she was a good ole bird. Don't you all just love the sounds of freedom. Fred "Scott Lowrey" wrote in message om... I reside about 6 miles off the departure end of MSP runway 12, so I'm used to hearing a lot of jet traffic. I've only lived here for 6 months but I quickly adjusted to the noise. It's acutally not that bad, excepting the venerable DC-9. Today, though, what looked like an F-18 flew over. Wow. I haven't seen too many fighters in my life (still have yet to see a "real" air show). That thing peeled off to the southeast with a thunder that even the DC-9 in full song can't match. She was probably climbing through 3 or 4 thousand when I looked up. Are afterburners used during departure? If not, I can't imagine what _that_ sounds like. -Scott |
#29
![]() "Richard Brooks" wrote in message news:bjcb7p$t17 B-47 taking off with RATO on! Loud, yes, but WORTH IT! : Harriers taking off from a short field a quarter of a mile from your squad bay. I live under the final for PDX. Every morning the F-15s come over (or roar out overhead.) I'm exactly under the point where they lower their landing gear, which means I'm exactly downrange when they throttle up to compensate. Rattles my windows every freakin' morning. I'd take it as a free airshow ("the sound of freedom") but it sets the neighbor's terrier off for the next half an hour or so. I think B-1s are the loudest things I've ever heard personally. -c |
#30
"Montblack" wrote:
September 20-21, 2003 http://www.duluthairshow.com/index2.htm Duluth is only 150 mile straight up the freeway from MSP (Mpls/St. Paul) Already on the calendar. I'll be there! |
Thinking out loud | Marco Rispoli | Owning | 21 | May 4th 04 04:22 PM |
LOUD | Scott Lowrey | Military Aviation | 40 | September 11th 03 12:39 AM |
'They want to ban recreational flying...' | Thomas J. Paladino Jr. | Piloting | 28 | July 22nd 03 07:20 PM |
