Gerry Caron wrote:
"Ron Wanttaja" wrote in message ... (answering several responses) an opportunity for inductive coupling. Keep the Xpdr antenna cable away from comm and audio cables. If they have to be close, try to have the routes cross at 90 deg. The overbraid needs to be grounded because you can get some pretty big currents induced along a cable. Also only one end of the cables shield should be grounded or else your open to some ground loops which can cause some of your problems. |
On Sun, 07 Mar 2004 21:30:30 GMT, UltraJohn
wrote: Gerry Caron wrote: "Ron Wanttaja" wrote in message ... (answering several responses) an opportunity for inductive coupling. Keep the Xpdr antenna cable away from comm and audio cables. If they have to be close, try to have the routes cross at 90 deg. The overbraid needs to be grounded because you can get some pretty big currents induced along a cable. Also only one end of the cables shield should be grounded or else your open to some ground loops which can cause some of your problems. Thanks, got the same recommendation from others...and contrary advice from a few. Fortunately, with a wooden airplane, *not* grounding the other end is a lot easier than grounding it... :-) Ron Wanttaja |
Every body worries about "GROUND LOOPS" but in many cases they do not
really know what they are talking about. Antenna coax is shielded wire that is also controlled impedance wire. You will find for every transmitter that the shield is connected at BOTH ends of the wire and for most antennas the shield is also grounded at both ends. If you disconnect the shield at one end and measure the VSWR you will notice that it goes toward infinity due the shield not being connected. CURRENT ALWAYS HAS TO RETURN TO THE SOURCE. The current may not flow where you want of even where you think it is flowing but it will seek a way(s) back to the source. LOW FREQUENCY CURRENT follows the path of least RESISTANCE. HIGH FREQUENCY CURRENT follows the path of least INDUCTANCE. The current will divide inversely proportional to the impedance of each individual path among the many paths available and seek the path of least total impedance. Now what is the difference in low frequency and high frequency current you might ask. The difference is the length of the connecting wire in terms of wavelengths of the signal. If the wire is longer than 1/20 of a wavelength then the signal is considered high frequency and you must think of the wire as a transmission line not just as a common wire. For LOW frequency shielding the wire shield is only connected at one end. Low frequency in this case is defined as DC up to the top of the audio band, 20 KHz. This keeps the magnetic coupling of near by cables from inducing a voltage in the shield that couples to the signal. Connecting the shield at only one end will NOT keep out high frequency signals! For very high frequency signals where the shield thickness is many skin depths of the signal frequency you can have different independent currents on both the outside and the inside of the shield. For this reason you must have a 360 degree shield connection or the inner and outer currents on the shield couple and mix due to the inductance of the shield pigtail connection. To keep out, or in, high frequency signals you must connect the shield at BOTH ends. Here is something to think about: How many GROUND LOOPS do you have if you place a whip antenna in the center of a X Y grid of 10 wires by 10 wires where each wire is connected to the crossing wire? 100? Now we fill in the spaces between the wires with another ten wires so we have a grid that is the same size but now has 100 wires by 100 wires. Do we now have 10,000 ground loops? Is this better? What if we now fill in the spaces between the wires so that it is solid metal. Do we now have an infinite number of ground loops? Is this better? Yes, except for weight. The answer is the current will divide among the many paths and follow the path of least total impedance. John Frerichs On Sun, 07 Mar 2004 21:30:30 GMT, UltraJohn wrote: Gerry Caron wrote: "Ron Wanttaja" wrote in message ... (answering several responses) an opportunity for inductive coupling. Keep the Xpdr antenna cable away from comm and audio cables. If they have to be close, try to have the routes cross at 90 deg. The overbraid needs to be grounded because you can get some pretty big currents induced along a cable. Also only one end of the cables shield should be grounded or else your open to some ground loops which can cause some of your problems. |
