![]() "mike regish" wrote in message news:HNajb.136846$%h1.138365@sccrnsc02... Ascending while holding your breath (a breath taken from a tank at a deeper level) won't cause the bends. It will burst your lungs-or something to that affect- It can cause an air embolism, which means the air bubbles in your blood can expand to the point where they block your blood vessels. as the enclosed air in your lungs expands under decreasing pressure. If you take your breath and hold it a tthe surface, descend and then ascend, there is no problem with that as your lungs are at capacity at the surface already. mike regish "Peter Duniho" wrote in message ... "John E. Carty" wrote in message .. . The trip back up is where you need to go slowly or risk the bends. Won't happen in a free dive. This is a result of taking a breath from some depth (as little as 4 feet down) and then not exhaling when returning to the surface The "bends" result solely from too rapid an ascent, whereas holding your breath is a problem no matter how slowly you ascend. The two are both dangerous, but are not the same thing. Otherwise, your point is accurate as far as I know. Pete |
Could that also happen with a breath taken at the surface? What kind of
conditions would cause this? mike regish "John E. Carty" wrote in message ... "mike regish" wrote in message news:HNajb.136846$%h1.138365@sccrnsc02... Ascending while holding your breath (a breath taken from a tank at a deeper level) won't cause the bends. It will burst your lungs-or something to that affect- It can cause an air embolism, which means the air bubbles in your blood can expand to the point where they block your blood vessels. as the enclosed air in your lungs expands under decreasing pressure. If you take your breath and hold it a tthe surface, descend and then ascend, there is no problem with that as your lungs are at capacity at the surface already. mike regish "Peter Duniho" wrote in message ... "John E. Carty" wrote in message .. . The trip back up is where you need to go slowly or risk the bends. Won't happen in a free dive. This is a result of taking a breath from some depth (as little as 4 feet down) and then not exhaling when returning to the surface The "bends" result solely from too rapid an ascent, whereas holding your breath is a problem no matter how slowly you ascend. The two are both dangerous, but are not the same thing. Otherwise, your point is accurate as far as I know. Pete |
![]() "mike regish" wrote in message . net... Could that also happen with a breath taken at the surface? What kind of conditions would cause this? mike regish It can happen, from what I remember, anytime time you take a breath from 4 feet or more under the water and then ascend without exhaling. Took dive lessons in college for PE requirements, but that was a VERY long time ago :-) "John E. Carty" wrote in message ... "mike regish" wrote in message news:HNajb.136846$%h1.138365@sccrnsc02... Ascending while holding your breath (a breath taken from a tank at a deeper level) won't cause the bends. It will burst your lungs-or something to that affect- It can cause an air embolism, which means the air bubbles in your blood can expand to the point where they block your blood vessels. as the enclosed air in your lungs expands under decreasing pressure. If you take your breath and hold it a tthe surface, descend and then ascend, there is no problem with that as your lungs are at capacity at the surface already. mike regish "Peter Duniho" wrote in message ... "John E. Carty" wrote in message .. . The trip back up is where you need to go slowly or risk the bends. Won't happen in a free dive. This is a result of taking a breath from some depth (as little as 4 feet down) and then not exhaling when returning to the surface The "bends" result solely from too rapid an ascent, whereas holding your breath is a problem no matter how slowly you ascend. The two are both dangerous, but are not the same thing. Otherwise, your point is accurate as far as I know. Pete |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 04:46 AM |
Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 03:52 AM |
