The bernoulli theory of starting a long thread
Old October 19th 03, 08:26 AM
Jan-Olov Newborg
David CL Francis wrote in message ...
On Sat, 11 Oct 2003 at 00:39:56 in message
, Jan-Olov Newborg
You should explain that all pressure differentials only comes from
"turning the airflow", just as NASA Glenn Research shows he
That is just not true. Even in a simplistic inviscid incompressible
potential flow there are pressure differences around an aerofoil
section. They just all cancel out to a zero overall effect!
Ofcause itīs true!
Stanford Aero shows here how "turning the fluidflow causes local
pressure gradients":
http://www.scienceweb.org/movies/aero.htm
I stick to the concept that a wing section in a real flow at a lifting
angle of attack generates lift and pressures around the section. The
airflow is, of course, turned as well. Summing the pressures around the
wing will give you the lift as will finding the total deflection of the
flow (which is more difficult to measure). Mathematical relationships
between variables do not indicate cause and effect, useful as they might
be. The input variables are the angle of attack and the flow velocity.
After that it all just happens. :-)
http://www.lerc.nasa.gov/www/K-12/airplane/right2.html
Well that is a nice page, but as far as I can see the math on it is pure
Newton although it does nicely show some simple flow patterns. The
pressure results on the demo though appear to be based on Bernoulli! So
he appears to show pressure changes by Bernoulli conversion from
velocity changes!
Most of us know that the brute force solutions using powerful computers
can now give the best answers. As I understand it these calculations are
essentially step by step iterations and gradually approach closer and
closer to reality but will never be reality.
Lets get rid of "The Reversed Bernoulli use"!
What on earth is that? Since Bernoulli is an energy conserving equation
it is, by its nature, reversible.
Thats when people write " high airflow speed causes low pressure"!
A change in velocity can never causes a change of a force (pressure)!
Jan-Olov Newborg
Old October 20th 03, 10:11 PM
David CL Francis
In article , Jan-Olov
Newborg writes
, Jan-Olov Newborg
Ofcause itīs true!
I'll try once more, then I give up. Slight misunderstanding here as I
thought your comment referred to the overall deflection of the airflow
that generates lift and not to local movements. Local pressures and
local changes in airflow direction are of course interconnected.
Yes and no. There are a number of different equations that can be
formulated about flows. Flows away from the boundary layer can be
calculated from potential flow theory and locally you can write
equations relating to the movement of individual elements of air. Fine.
Within a given stream tube Bernoulli will give you good answers - it is
based on conservation of energy. The illustration gives a balance of the
element forces across the flow but omits the effects of the forces along
the length of the flow where the air is also accelerating or
decelerating with the velocity changes.
All these equations are ways of making predictions, some of them work
better than others under different conditions. However they are all
imperfect descriptions of reality. Neither equations or 'explanations'
_are_ reality.
In a real flow pressures and velocities are what they are and you cannot
say that one causes the other except in the sense that changing the
environment (changing the wing section or the angle of attack) give rise
to different results.
[Snip]
velocity changes!
[Snip]
[1]
As you may have guessed I don't go for chicken and egg explanations but
I would just ask how you equate that statement with what happens in a
pitot tube? Some of the air comes to rest and the pressure in the pitot
tube rises to the total pressure of the air stream. Or take a venturi
where the cross section changes slowly and smoothly? The centrifugal
forces that you liked on the web page are then very small but the
velocity and pressure will still change in almost exactly the same way
as Bernoulli predicts (better actually).
The literal acceptance of your statement above [1] is that Newton's
equations are wrong. Yet the equations you prefer are based on Newton's
laws of motion! Do you also assert the converse; that a change in force
cannot cause a change in velocity? Or that flow meters cannot work? The
introduction of a venturi provokes a velocity change in an
incompressible fluid and at the point of maximum velocity the static
pressure drops and the result can be used to measure the flow.
Generalisations like [1] are, in my humble opinion, not very helpful. If
you were to say that in a flow the pressures velocities and
accelerations are all interrelated I would be much happier.
David CL Francis E-Mail reply to
Old October 22nd 03, 09:40 PM
Jan-Olov Newborg
Ofcause itīs true!
_are_ reality.
Still airflow velocity can never "cause" a change in Pressure (force)!
[Snip]
velocity changes!
[Snip]
[1]
Professor em. of Aerodynamics John D. Anderson, Maryland University
writes in one of his books of aerodynamics:
"Strictly speaking,the 1 dimensional Bernoulli equation is only valid
along one streamline in the venturi pipe, namely the centerline and
then we are neglecting all the compressible effects taking place ( and
the ignorance of viscous effects)!"
I think you my postings like The Devil reads the Bible!
How can you say that I write that Newton`s laws are wrong!
As you well know, you can cut off the entrance part of the venturi
pipe, because itīs only the divergent backpart that lowers the
pressure due to THE COANDA EFFECT!
If you look at the speedsensor of the Piper Colt, PA22, you can see
this type of "cut venturi pipe"!
All old german aircraft used this device in the 1920!
Can you explain the behavior of the Windsock, seen at every airport,
using Bernoulli and the continity equation?
The harder it blows, the higher the pressure gets inside the windsock!
All constrictions works this way in a pipe for real flow
(ideal/perfect flows is a mathematical, non existing, flow model)!
Jan-Olov Newborg
Old October 23rd 03, 11:48 PM
David CL Francis
On Wed, 22 Oct 2003 at 13:40:11 in message
, Jan-Olov Newborg
[snip - Your posts would be better if you cut out unnecessary
repetition]
A nice statement, and true, 'strictly speaking' but ,as far as I am
concerned, irrelevant to what I was saying or what we were discussing.
I realise from the above that you are not writing in your first
language. I cannot criticise that as am fluent only in English (and not
perfect even in that!). Your English is good but sometimes fails.
Sorry, that is wrong and seems to show that you do not understand what
happens in a normal venturi. You do not seem able to differentiate
between details at the molecular level, the effects of viscosity and
compressibility and the range of situations where broader principles
explain a large percentage of fluid phenomena.
I am not familiar with that design.
I accept what you say about that. However you have not explained the
purpose or principle behind these devices.
Well first think of it like a very small parachute with a large hole in
the top! If there was no opening the pressure inside would rise to the
total pressure. A small opening in this case where there is no expansion
section will restrict the flow due to the inevitable back pressure.
With an upper limit of the total air pressure of the wind.
No they don't. Your part in brackets is strictly true but so what? What
matters is the deviation from the simple explanation in each case.
Because relativity explains things that Newton doesn't it does not mean
that we run about using it in engineering designs or that we abandon
Newton as inaccurate.
I give up altogether now as we seem doomed never to understand each
other.
Old October 24th 03, 01:56 PM
Todd Pattist
other.
You lasted longer than I. :-) There seems to be a
fundamental disconnect with Jan-Olov, probably exacerbated
by the language difference. I was never able to decide
quite what his point was. If it's any consolation to you, I
found your posts quite helpful.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old October 26th 03, 07:40 PM
David
On Fri, 24 Oct 2003 at 08:56:43 in message
, Todd Pattist
other.
Thank you Todd! I have got caught before by those who come back with
isolated facts that they seem to have collected.
Sometimes their arguments feel like this:
The very existence of quantum mechanics means that weighing a few pounds
of potatoes on a grocer's scales is now invalid without taking account
of the quantum effects!
Old October 25th 03, 08:27 PM
Jan-Olov Newborg
, Jan-Olov Newborg
repetition]
David you should read this article about "The Venturi Pipe"!
http://www.mitypiac.net/
All pilots in the aviation world knows about Piper Aircraft Coperation
and their different aircraft. Piper Colt was a 2 seater built before
the long Piper PA28 Cherokee period!
Have you ever flown a aircraft?
I have been flying 4300 hours!
You donīt need the front part of the venturi to measure the
pressuredifference between total and static pressure. The cut venturi
was used before the pitot pipe!
I would like to to see the Continuity equation and Bernoulli relation
applied on a Windsock!
All constrictions in normal pipes for real fluids, slows down the
speed of the flow due to friction and turbulence!
Jan-Olov Newborg
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Copyright Đ2004-2025 AviationBanter.
