New Bombardier-Rotax engines
Old October 20th 03, 03:57 AM
John Galban
Thomas Borchert wrote in message ...
John,
Liquid cooling looks like it'll make it difficult to retrofit to
existing designs.
Why? The Thielert diesel is liquid cooled and is being retrofitted to
C172s and PA28s as we speak. Everything firewall forward is replaced,
so where's the problem?
I didn't say it was impossible. Maybe I should rephrase that to say
"...looks like it'll make it difficult to cost-effectively retrofit to
existing designs".
From what I've seen over the years, most firewall forward engine
conversions tend to approach the value of the unconverted plane.
Unless these engines are going to sell for substantially less than
their air cooled bretheren, all of those necessary bits and pieces are
going to make the conversion look pretty unattractive from an economic
standpoint (at least for the lower end of the market, i.e C-172s and
PA28s).
Old October 20th 03, 06:56 AM
Thomas Borchert
John,
Depends on a lot of factors. Let's look at the Thielert Centurion 1.7
diesel, not yet available in the US (due to stalling of the FAA,
AFAIK), but certified in Europe. AFAIK, the engine is 20,000 $,
including all accessories and a guarantee for 2400 hours (TBR) or 12
years. If something breaks before, you'll get the new engine prorated.
The conversion kit for the 172 is 40,000 $. The Centurion will use 4
gallons or so of JetA1.
If you calculate the difference between the amount of JetA1 used by the
Centurion and the Avgas used by an O-320, factor in the cost of the
engine per hour (guaranteed with the Centurion, full of surprises with
the Lyc), you'll find that the point at which you'll get the extra
20,000 for the conversion back depends very much on local fuel cost and
similar factors - but the point will come.
Thomas Borchert (EDDH)
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
Questions Rotax Engines Mark Smith Home Built 2 August 13th 04 11:01 PM
Jabiru and Rotax engines Marco Rispoli Home Built 14 July 16th 04 07:23 AM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
