ink.net... It assumes nothing at all. If a pilot reports he's in the clouds, then any other aircraft that is within 2000 feet horizontally, 1000 feet above, or 500 feet below the reporting aircraft MUST be in IMC. ATC has no way of knowing that the VFR target in question is within those limits. Yes there was. You said ATC can't rely on PIREPs to KNOW something. That's obviously incorrect. Wow. With the "...about the VFR target" implied, your misunderstanding was understandable, if a bit surprising. But with it being called out explicitly to you, your ignorance is downright shocking. Pete |
It assumes nothing at all. If a pilot reports he's in the clouds, then any other aircraft that is within 2000 feet horizontally, 1000 feet above, or 500 feet below the reporting aircraft MUST be in IMC. ATC's definition may be different, but I found these defined on the web. From FAR Part 1 IFR conditions means weather conditions below the minimum for flight under visual flight rules. This seems to be the definition that you are using for IMC. From http://www.visi.com/~lindowdy/aviation/glossary.htm Glossary of Aviation Terms IMC instrument meteorlogical conditions; unable to see visual references outside the plane This seems to be the definition that most mortal pilots use. Bob Moore |
![]() "Steven P. McNicoll" wrote in message nk.net... PIREPs are assumed to be accurate. Yes but as far as the FAA "officially" is concerned, they are "anecdotal" when it comes to enforcement actions. |
![]() "Ron Natalie" wrote in message ... Yes but as far as the FAA "officially" is concerned, they are "anecdotal" when it comes to enforcement actions. We're not talking about enforcement actions. |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
About when did a US/CCCP war become suicidal? | james_anatidae | Military Aviation | 96 | February 29th 04 03:24 PM |
US plans 6,000mph bomber to hit rogue regimes from edge of space | Otis Willie | Military Aviation | 14 | August 5th 03 01:48 AM |
Rogue State | jukita | Military Aviation | 18 | July 13th 03 02:22 PM |
