Q for Jim Weir or others: solid state fuel level probes?
Old March 12th 04, 12:35 AM
Ken Moffett
Jim Weir wrote:
I think the chips themselves are worth investigating. I do have a prejudice
against UK semiconductor manufacturers, having had a major one and a minor one
simply stop producing parts that rendered several tens of thousands of dollars
of hardware and engineering time down the drain.
I realize that they are not ALL like that, but the only two that have screwed me
thus far in 40 years have been UK based.
-If you want to do some tinkering of your own (legal disclaimer here..) you
-may want to look at sensor chips from QProx (www.qprox.com). They have a
-couple of capacitive level monitor chips like the QT300/301 or QT117L that
-may provide real-time non-contact level information. If you have a non-metal
-tank you may be able to just attach two strips on the side of the tank and
-be done.
-Jim, what do you think?
-Rob
http://www.rst-engr.com
I've used the QT114 for a single point fluid (alcohol) level control in
a one liter plactic cylinder. Precise within fractions of a mm. I also
used the QT110 for an isolated (behind a glass display window) proximity
switch for one of our students' Physics class projects. The QT117 or
QT300 might work for a tank level gauge. They even have "slosh" filter
software built in,
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 02:21 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
