![]() Peter Duniho wrote: It's not the controller's job to ensure that the pilot is obeying the FARs. If the pilot claims that flight visibility is 1 mile, the controller should approve SVFR (assuming the necessary traffic separation conditions are met). That would only apply if there were no weather reporting at the field. If the field has an ASOS, for example, then it would have to report at least a mile, no matter what you say. |
That's a contentious point that I don't know has been settled yet, though I think
the rulings so far are leaning the way you describe. Since the ASOS/AWOS is usually not located at the end of a runway (I think they try for a spot close to airport center) and airports are pretty large pieces of real estate, it's entirely possible for the system to be reporting visibility different from what the pilot is seeing from the air on approach. I think what will certainly cause the FAA to jump on you is if an RVR is installed for the runway you used and it was reporting visibility less than minimums. Dave Reinhart Newps wrote: Peter Duniho wrote: It's not the controller's job to ensure that the pilot is obeying the FARs. If the pilot claims that flight visibility is 1 mile, the controller should approve SVFR (assuming the necessary traffic separation conditions are met). That would only apply if there were no weather reporting at the field. If the field has an ASOS, for example, then it would have to report at least a mile, no matter what you say. |
![]() David Reinhart wrote: That's a contentious point that I don't know has been settled yet, though I think the rulings so far are leaning the way you describe. Since the ASOS/AWOS is usually not located at the end of a runway (I think they try for a spot close to airport center) and airports are pretty large pieces of real estate, it's entirely possible for the system to be reporting visibility different from what the pilot is seeing from the air on approach. I think what will certainly cause the FAA to jump on you is if an RVR is installed for the runway you used and it was reporting visibility less than minimums. At my airport it is common to get a fog bank over the eastern half of the airport, the half that includes the ASOS. The western half will be CAVU, which includes the full length of the small runway I normally use. There I sit in the full sun unable to get a clearance for takeoff. |
"David Reinhart" wrote in message
... That's a contentious point that I don't know has been settled yet, though I think the rulings so far are leaning the way you describe. Since the ASOS/AWOS is usually not located at the end of a runway (I think they try for a spot close to airport center) and airports are pretty large pieces of real estate, it's entirely possible for the system to be reporting visibility different from what the pilot is seeing from the air on approach. I think what will certainly cause the FAA to jump on you is if an RVR is installed for the runway you used and it was reporting visibility less than minimums. I've seen fog obscure one otherwise usable runway but not another. le moo Dave Reinhart Newps wrote: Peter Duniho wrote: It's not the controller's job to ensure that the pilot is obeying the FARs. If the pilot claims that flight visibility is 1 mile, the controller should approve SVFR (assuming the necessary traffic separation conditions are met). That would only apply if there were no weather reporting at the field. If the field has an ASOS, for example, then it would have to report at least a mile, no matter what you say. |
![]() "David Reinhart" wrote in message ... That's a contentious point that I don't know has been settled yet, though I think the rulings so far are leaning the way you describe. Since the ASOS/AWOS is usually not located at the end of a runway (I think they try for a spot close to airport center) and airports are pretty large pieces of real estate, it's entirely possible for the system to be reporting visibility different from what the pilot is seeing from the air on approach. I think what will certainly cause the FAA to jump on you is if an RVR is installed for the runway you used and it was reporting visibility less than minimums. What's the point of contention? A SVFR clearance is issued on the basis of weather conditions reported at the airport of intended landing/departure. If the weather observation site is enveloped in fog while the rest of the surface area is CAVU, then fixed-wing SVFR is not available. Flight visibility doesn't come into play at all. |
"Newps" wrote in message
news:R9Smb.34321$Fm2.13493@attbi_s04... If the field has an ASOS, for example, then it would have to report at least a mile, no matter what you say. That's true. I still don't see where "IFR minimums" comes into it. |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
About when did a US/CCCP war become suicidal? | james_anatidae | Military Aviation | 96 | February 29th 04 03:24 PM |
US plans 6,000mph bomber to hit rogue regimes from edge of space | Otis Willie | Military Aviation | 14 | August 5th 03 01:48 AM |
Rogue State | jukita | Military Aviation | 18 | July 13th 03 02:22 PM |
