![]() "David Reinhart" wrote in message ... I don't think this is right. In Class B airspace, the only requirement is to be clear of clounds. That means that an aircraft could be in the clouds at (for example) 5,000 ft. and other aircraft could be VFR at 4,500 or 5,500, be clear of the clouds and be quite legal. True, but since most airspace is other than Class B it is right in most airspace. |
Also true, but one thing I've learned about the FARs is that it's the "unusual"
that can either get you grounded or help you get where you're going. It's sad that pilots need to know the law as much or more than they need to know about stick and rudder. Dave Reinhart "Steven P. McNicoll" wrote: "David Reinhart" wrote in message ... I don't think this is right. In Class B airspace, the only requirement is to be clear of clounds. That means that an aircraft could be in the clouds at (for example) 5,000 ft. and other aircraft could be VFR at 4,500 or 5,500, be clear of the clouds and be quite legal. True, but since most airspace is other than Class B it is right in most airspace. |
![]() "David Reinhart" wrote in message ... BTW, this kind of scenario is a potential "gotcha" when leaving Class B airspace. You can be flying along in Class B airspace, just above or below a cloud deck, exit the Class Bravo and be instantly illegal when it comes to cloud clearance. The same "gotcha" exists when leaving a surface area under SVFR. |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
About when did a US/CCCP war become suicidal? | james_anatidae | Military Aviation | 96 | February 29th 04 03:24 PM |
US plans 6,000mph bomber to hit rogue regimes from edge of space | Otis Willie | Military Aviation | 14 | August 5th 03 01:48 AM |
Rogue State | jukita | Military Aviation | 18 | July 13th 03 02:22 PM |
