#61
"Jay Honeck" writes:
I've never seen a vacuum failure, in over 800 hours of flying. (Although I did experience a vacuum attitude indicator failure a couple of months ago...) I experienced my first vacuum failure about 100 hours after I bought my Warrior. I was about 10 miles back at night in excellent VMC. I reduced power to start a gentle descent, and immediately the vacuum indicator lit up (it was impossible to miss). I crosschecked the suction gauge, which read 0. By the time we touched down, the AI was seriously tilted and the HI was barely moving. My plane was imported to Canada in 1988 and got a new set of logs then (as is typical). I have found no reference to a vacuum pump replacement in the logs, so the pump that failed had at least 1,000 hours and 15 years on it. All the best, David |
#62
(Although I did experience a vacuum attitude indicator failure a couple of months ago...) I experienced my first vacuum failure about 100 hours after I bought my Warrior. Augh -- I KNEW I shouldn't have said anything like that out loud! My DG just went belly-up on my flight to Pella yesterday. It's totally, 100% dead -- no movement or gyro spinning up at all. And I just replaced the AI last month. But the vacuum is still reading a good strong "5", for whatever that's worth. Nothing like losing both of your vacuum instruments within a month of each other... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#63
Augh -- I KNEW I shouldn't have said anything like that out loud! My DG just went belly-up on my flight to Pella yesterday. It's totally, 100% dead -- no movement or gyro spinning up at all. And I just replaced the AI last month. But the vacuum is still reading a good strong "5", for whatever that's worth. I wonder if it's spewing junk into your gyros -- did you change the central air filter (or whatever it's called) when you installed the new AI? All the best, David |
#64
central air filter (or whatever it's called) when you installed the new AI? Dunno -- I would assume that my A&P would know to check that, but I'm sure going to be asking him now... (He just called me to say that all the lines and fitting are tight, eliminating the cheap and easy problems...) It's always something with airplanes, isn't it? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Dover short pilots since vaccine order | Roman Bystrianyk | Naval Aviation | 0 | December 29th 04 12:47 AM |
[OT] USA - TSA Obstructing Armed Pilots? | No Spam! | Military Aviation | 120 | January 27th 04 10:19 AM |
[OT] USA - TSA Obstructing Armed Pilots? | No Spam! | General Aviation | 3 | December 23rd 03 08:53 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
