In article , Robert Moore
writes: Reset the altimeter passing through FL180 going up or down. However, I hope I am not sucking oxygen as this would be indicative of a major malfunction. :-) Ah, I forgot to mention that I do this in the continental US. The rules, of course, are different alsewhere. How do you know that you are passing FL180 on the way up? Ok, let's try this. In the continental US, I set the altimeter to 29.92 at or near 18,000' in the climb and passing through about FL180 in the descent. No conflict with traffic should occur since an aircraft will not be assigned and altitude of FL180 if the current barometric pressure is less than 29.92. It is not necessary to be exacting in this. Just be sure to have the correct altimeter setting in the window when approaching the assigned altitude to avoid traffic and/or terrain conflicts. However, should I desire to know that I am passing FL180 in the climb, and since I a have three altimeters at my disposal, I could set one to 29.92 to indicate my current FL. G. Lee |
In article , Robert
Moore wrote: If you are not assigned FL180 why would you want to know when you are passing it in a climb? So you know when you reset your altimeter so you don't go through the 190 you were assigned. A few years back we had a day with an absurdly low local altimeter setting (something like 29.02). We were climbing to FL190, so as we're passing through just under 18,000 feet and climbing like a bat outta hell, I whirl the altimeter up to 29.92 to find we (ahem...) almost climbed through our altitude. There were only 200 feet between 17,900 feet and FL190. Quite an eye opener, to say the least. -- Garner R. Miller ATP/CFII/MEI Manchester, CT =USA= |
