![]() David Megginson wrote: Is that a Continental O-320 (if such a thing exists)? The Lycoming O-320 operator's manual suggests that all Lycoming O-320's have the carb underneath: My Lycoming has the carb behind the engine. It is nearly directly underneath the oil filter. The induction pipe runs forward from there into the sump. Putting the carb back by the accessory drive would probably mess up the distribution quite a bit. How well does your engine run lean of peak? Not real well. Once you get lean of peak, the engine gets real sensitive to the mixture. Very slight adjustments make for very large rpm changes. It doesn't shudder so much as just die. George Patterson You can dress a hog in a tuxedo, but he still wants to roll in the mud. |
"G.R. Patterson III" writes:
Not real well. Once you get lean of peak, the engine gets real sensitive to the mixture. Very slight adjustments make for very large rpm changes. It doesn't shudder so much as just die. My experience with sensitivity is the same as yours. The hardest part of setting power with mixture only is that the mixture is at least an order of magnitude more sensitive than the throttle -- there's only a tiny range of movement between full power and cutoff. I generally take the throttle friction lock off while very gently nudging the mixture lever, then put it back on when I have the right setting. If it dies without much shuddering, then the distribution is probably pretty good, I'd guess (as a non-technician). All the best, David |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 12:40 AM |
Testing your glide. Are people doing this? | Montblack | Owning | 50 | November 1st 03 12:56 AM |
