Thad Beier wrote in message ...
The pulsejet sounds is not a sine wave, or even close, so two 180-out-of-phase signals will not cancel out. Wouldn't 2 identical square waves cancel if you summed them exactly 180 degrees out of phase? Fourier tells us that any periodic signal can be completely represented by the sum of an infinite series of harmonically related sinusoids. So I think what you really mean to say is that the 2 sounds are not identical and thus will not completely cancel, and I would be inclined to agree with you. The point I was making in an earlier post was that the fundamentals and some of the lower harmonics can be made to cancel, and these are the harmonics that contain most of the sound power. The remaining sound would be lower in volume but higher in pitch. Here's some news I found from a google. PULSED DETONATION ENGINE SHIPPED FOR VEHICLE INTEGRATION: As part of a joint Propulsion Directorate/Air Vehicles Directorate program to evaluate the feasibility of using pulsed detonation engine (PDE) propulsion with manned aircraft, PR recently shipped a complete engine assembly to Scaled Composites in Mojave, California, for vehicle integration. The engine was shipped following successful testing of a prototype flight-worthy pulsed detonation engine. It is believed that the test demonstrated the first self-contained PDE in operation. The prototype engine consists of a PDE assembly and pod which contains everything required to make a selfcontained propulsion system. This includes an auxiliary power unit, oil system, fuel pumps and June 2003 Page 2 Prototype flight PDE (in background on test stand) and pod (foreground) which supplies air to the integrated engine. Royce Bradley (left) and Curt Rice (right) prepare to ship a complete PDE to Scaled Composites. The PDE and tubes will replace a conventional pusher prop engine on an experimental Long-EZ aircraft. The pod below and forward of the PDE contains the APU, alternator, pumps, etc. required to make a self-contained propulsion system. This pod will be contained in a bomb or ventral-tank like structure underneath the Long-EZ. fuel injection system, alternator, battery, throttles, and control computers, as well as superchargers to enable static starts and nonself aspirated operation. The complete engine is constructed from off-theshelf components and is designed to meet FAA durability requirements for experimental propulsion systems. The shipped engine assembly consists of a PDE and pod integrated together to create the second of three flight engines. This engine is currently being integrated with an experimental Long-EZ airplane using a mount designed by Burt Rutan's company, Scaled Composites. Following fabrication of the engine mount, a duplicate mount will be shipped back to Wright-Patterson AFB for installation on a ground test Long-EZ using flight engine number three. Engine number one, which has additional test instrumentation, will take part in outdoor acoustic testing and be used as a spare. Although the current joint program between PR and VA is studying integration issues with a manned subsonic airframe, pulsed detonation technologies are expected to have performance benefits in the Mach 0-4+ Integration of the Pulsed Detonation Engine with a flight test Long-EZ aircraft at Scaled Composites. The first-stage wingtip of Burt Rutan's X-Prize entry is overhanging the PDE powered experimental aircraft. June 2003 Page 3 Dr. Charles MacArthur Dr. MacArthur receives the Meritorious Civilian Service Award from Col Mike Heil, PR Director regime and for hybrid/combined-cycle applications. The current program addresses structural, acoustic, and durability concerns while maturing this potentially revolutionary propulsion technology. (F. Schauer, AFRL/PRTS, (937) 255-1554) |
Alan Baker wrote in message ...
No. You're assuming that the compression portion of the wave is equal in shape to the rarefaction portion of the wave, and thus can be cancelled by a rarefaction from another engine in close proximity. But this is highly unlikely to be the case. Isn't this the case for a sinusoid? If I excite an air mass with a speaker being driven by a sinewave which moves the paper cone in a sinusoid fashion, and then I have a microphone whose diaphragm is made to move in the same manner because of the excitation of the air mass, and I read a sinewave, then wasn't the air mass moving in a sinewave. Now I do this for with a bunch of speakers, all playing tones but which are multiples of the lowest frequency, wouldn't this also be the case? The combined sound would be that of a pulse jet ripping apart the air. "Super position does hold." This web page has some great intuitive animation: http://www.gmi.edu/~drussell/Demos/s...rposition.html One weakness of my above explanation is that air does not respond in an entirely linear fashion, so maybe superposition doesn't entirely hold. This is what they're depending on with the "throw your voice" technology where they're "mixing" 2 ultra-sonic (and directable) sounds and having them produce a sum (inaudible) and difference (audible) sound at the intersection. Regards |
LOL - personally, I suspect if you use two pulse jets to cancel, all that will
happen is you will have a pulse jet twice as loud! But then again, I am not a noise expert ..... well sort of I guess, I know how to make it. |
LOL also...
But that twice as loud assumes that the sounds will 'sum'. If the argument that the sounds cannot subtract, then they should be just as hard to sum.... -- Dan D. .. "DJFawcett26" wrote in message ... LOL - personally, I suspect if you use two pulse jets to cancel, all that will happen is you will have a pulse jet twice as loud! But then again, I am not a noise expert ..... well sort of I guess, I know how to make it. |
"Blueskies" wrote:
LOL also... But that twice as loud assumes that the sounds will 'sum'. If the argument that the sounds cannot subtract, then they should be just as hard to sum.... Think "double-barrel shotgun". Mark Hickey |
![]() I don't seem to be following the thread here... SHOCK waves, not sine waves. and more harmonics than a '60's rock band! AND, to make it work, they ALL have to be exactly (there's the E word) and perfectly (the P word too) (I _could add Absolutely and score 3 for 3!) 180 out of phase? Richard (one eyebrow WAY up) |
Submarines use a device (the name escapes me just now) to do exactly
what you guys are talking about. AL 180 out of phase? Richard (one eyebrow WAY up) |
You can do it when you're only producing real low fundamental frequencies
and can control the phase. In a pulse jet or any kind of rocket motor, it's a ton of high-frequency broad-band noise. You might be able to control one or maybe two frequencies (assuming they are correllated), but forget about the rest of the junk. "AL" wrote in message ... Submarines use a device (the name escapes me just now) to do exactly what you guys are talking about. |
