I made a device once to allow me to talk to an individual in a crowd from a
distance. I used an array of small speakers and DSPs to produce delays for each one so that it acts like a phase array RADAR and the central beam can be directed electronically with no motion of the array. The most difficult part is that the signal has to be spectrally broken down and delays calculted for each speaker AND each frequency. This is aproblem in reinforcement. The same applies to candellation. Look up "reciprocity callibration" for an idea of how complicated it is. As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies with frequency so finding silence is probematic though there may be a "sweat spot" if everything works out. There is also likely to be sum and difference frequuncies and (and more if the rsponse is nonlinear). The difference or beat frequency is the difference between two frequencies, so if the engines are not perfectly synchonized you will get a beat. If one is at 101 and one at 100, you get a nice loud 1 Hz beat as any of yo uknow from synchonizing a twin in a pane or boat. -- Charlie Springer |
Hi Richard, thanks for joining the discussion, read below...
Richard Lamb wrote in message ... SHOCK waves, not sine waves. Any periodic signal (or sound) can be thought of as an infinite sum of the harmonics of the fundamental. Even complicated waveforms. and more harmonics than a '60's rock band! Yup, lots of harmonics, each one containing its portion of the sound power. The higher the harmonic, the less power it generally contains. AND, to make it work, they ALL have to be exactly (there's the E word) and perfectly (the P word too) (I _could add Absolutely and score 3 for 3!) 180 out of phase? Its really a matter of degrees (pun intended), the closer to 180 you get, the better the cancelation, but its not an all or nothing kind of thing. For example, a 170/190 degree phase shift cancels 98%. |
There is really only one problem with your cancellation idea. To work in all
directions the sounds have to come form the same point in space. If they are not the same, all you can do is local cancellation or an interference pattern with some areas silent and some twice as loud. Just take two points and start drawing circles around each. The intersections will form lines of interference. The PDE's are harder than pulse jets since the detonation wave is supersonic. You exceed what you might call the ellasticity of the air and I don't know if linear theory (like Fourier) will apply. There is probably a dramatic discontinuity and Fourier requires at least piece wise continuity. But I have not looked at shock physics in a long time. Sombody on RAM would know, like Marry Shafer. -- Charlie Springer |
