I made a device once to allow me to talk to an individual in a crowd from a
distance. I used an array of small speakers and DSPs to produce delays for each one so that it acts like a phase array RADAR and the central beam can be directed electronically with no motion of the array. The most difficult part is that the signal has to be spectrally broken down and delays calculted for each speaker AND each frequency. This is aproblem in reinforcement. The same applies to candellation. Look up "reciprocity callibration" for an idea of how complicated it is. As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies with frequency so finding silence is probematic though there may be a "sweat spot" if everything works out. There is also likely to be sum and difference frequuncies and (and more if the rsponse is nonlinear). The difference or beat frequency is the difference between two frequencies, so if the engines are not perfectly synchonized you will get a beat. If one is at 101 and one at 100, you get a nice loud 1 Hz beat as any of yo uknow from synchonizing a twin in a pane or boat. -- Charlie Springer |
I guess you're talking about interference patterns and such. All that stuff
is irrelevant. The noise coming from a pulse jet will only have a couple of periodic components. The rest is a bunch of quasi-random, aperiodic noise resulting from some extreme turbulence. While turbulence phenomena are chaotic in nature and not truly random, you might as well treat them as random for this case. You never get a periodic interference pattern setting up. "Regnirps" wrote in message ... As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies |
The spectrum of the sound from the engine does indeed have several
strong harmonics that rise up from a random noise floor. I think you'd be able to cancel the periodic components of the noise leaving the random part behind. If I had to guess, you'd get rid of the buzz and be left with the roar. So with cancelation it might be similar to a jet turbine in sound. Regards p.s. As far as synchronization, if I understand correctly, most of the simple forms of these motors are started with a spark, but then carry on self sustained operation at the natural frequency of the pipe. You could however use a spark to ignite the charge slightly early and thus force synchronization. "Pete Schaefer" wrote in message news:%gc6c.32308$J05.219351@attbi_s01... I guess you're talking about interference patterns and such. All that stuff is irrelevant. The noise coming from a pulse jet will only have a couple of periodic components. The rest is a bunch of quasi-random, aperiodic noise resulting from some extreme turbulence. While turbulence phenomena are chaotic in nature and not truly random, you might as well treat them as random for this case. You never get a periodic interference pattern setting up. "Regnirps" wrote in message ... As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies |
"Jay" wrote in message
m... The spectrum of the sound from the engine does indeed have several strong harmonics that rise up from a random noise floor. I think you'd be able to cancel the periodic components of the noise leaving the random part behind. If I had to guess, you'd get rid of the buzz and be left with the roar. So with cancelation it might be similar to a jet turbine in sound. Regards p.s. As far as synchronization, if I understand correctly, most of the simple forms of these motors are started with a spark, but then carry on self sustained operation at the natural frequency of the pipe. You could however use a spark to ignite the charge slightly early and thus force synchronization. Okay, already! That's enough, "I suppose" and "I think". Build something and report back next Thursday. Documentation to follow within five days. Oral boards will convene at their convenience no less than two weeks after the thesis is finalized and submitted. Warning - the penalty for failure is severe! Miss Twyla Geeter. |
OK. We'll stand by for the check to fund this boondogle.
"Rich S." wrote in message ... Build something and report back next Thursday. Documentation to follow within five days. Oral boards will convene at their convenience no less than two weeks after the thesis is finalized and submitted. |
Yup, that jives with what I've seen. If you could cancel out the fundamental
and a couple of harmonics for a given direction, it's still going to be freakin' loud. "Jay" wrote in message m... The spectrum of the sound from the engine does indeed have several strong harmonics that rise up from a random noise floor. I think you'd be able to cancel the periodic components of the noise leaving the random part behind. If I had to guess, you'd get rid of the buzz and be left with the roar. So with cancelation it might be similar to a jet turbine in sound. |
Pete Schaefer wrote:
Yup, that jives with what I've seen. If you could cancel out the fundamental and a couple of harmonics for a given direction, it's still going to be freakin' loud. EH? WHADYA SAY? |
