Corky Scott wrote:
Sebastian, several people have fabricated composite propellers in their shop. It isn't easy to do and the prop REALLY has to be of sound construction in order to withstand the forces of thrust, vibration reasonance and turbulence. I suggest you do a search on the internet to see if you can find the websites of those who have documented their techniques. Be prepared to spend a LOT of time getting it right. Propeller design is not simple. Good luck, Corky Scott In the library section to my website I have a link to "How I Make Propeller" The author does a very good job of telling you things you want to know. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Thanks Ernest,
To all you electric nay sayers take a look at this... http://www.aviationtomorrow.com/nuke...ew_photo. php the reason this guy is smilin is hes probably going to be the first private aviator to have an functional electric airplane...never mind its costing half a million smackers...ultimately hes gona use fuel cells...but before that hes using...drumroll please...li ion batteries...theyre doing the first electric flights in april so well see...check out the rest of their web site pretty intersting... you guys are right about lead acid batteries and that weight is the major limitation but i think general aviation is on the cusp of practical electic flight...im gona give it a try...and li ion batteries are part of my trick too...ive sourced some 10 amp hour li ion batteries...and my total weight for 20ah@48v will be...well a small fraction of la bats...not cheap...i also found some 100amp lightweight controllers that i can run in parallel to as someone correctly calculated run ~200amps peak...so i might be able to just barely do it...keep my copper connectors short...and if i can run for 10 minutes electric i would be happy because i know i could optimize tweek and lighten to get more...thats the plan...so now i need a REALLY good prop any more sugguestions appreciated... Ernest Christley wrote in message om... Corky Scott wrote: Sebastian, several people have fabricated composite propellers in their shop. It isn't easy to do and the prop REALLY has to be of sound construction in order to withstand the forces of thrust, vibration reasonance and turbulence. I suggest you do a search on the internet to see if you can find the websites of those who have documented their techniques. Be prepared to spend a LOT of time getting it right. Propeller design is not simple. Good luck, Corky Scott In the library section to my website I have a link to "How I Make Propeller" The author does a very good job of telling you things you want to know. |
If you want an electric plane, you can buy one here.
http://www.alisport.com/eu/eng/silent_b.htm They claim you can climb to over 2000 feet with a 90 pound battery, then it turns into a sailplane and you do the rest with "solar thermal" energy. sebastian wrote: Thanks Ernest, To all you electric nay sayers take a look at this... http://www.aviationtomorrow.com/nuke...ew_photo. php the reason this guy is smilin is hes probably going to be the first private aviator to have an functional electric airplane...never mind its costing half a million smackers...ultimately hes gona use fuel cells...but before that hes using...drumroll please...li ion batteries...theyre doing the first electric flights in april so well see...check out the rest of their web site pretty intersting... you guys are right about lead acid batteries and that weight is the major limitation but i think general aviation is on the cusp of practical electic flight...im gona give it a try...and li ion batteries are part of my trick too...ive sourced some 10 amp hour li ion batteries...and my total weight for 20ah@48v will be...well a small fraction of la bats...not cheap...i also found some 100amp lightweight controllers that i can run in parallel to as someone correctly calculated run ~200amps peak...so i might be able to just barely do it...keep my copper connectors short...and if i can run for 10 minutes electric i would be happy because i know i could optimize tweek and lighten to get more...thats the plan...so now i need a REALLY good prop any more sugguestions appreciated... Ernest Christley wrote in message om... Corky Scott wrote: Sebastian, several people have fabricated composite propellers in their shop. It isn't easy to do and the prop REALLY has to be of sound construction in order to withstand the forces of thrust, vibration reasonance and turbulence. I suggest you do a search on the internet to see if you can find the websites of those who have documented their techniques. Be prepared to spend a LOT of time getting it right. Propeller design is not simple. Good luck, Corky Scott In the library section to my website I have a link to "How I Make Propeller" The author does a very good job of telling you things you want to know. |
The Book "How I Make Propeller" is very good for what it says to be, HIS way
to make propellers, Interesting to see how he struggle to learn, He most of the times have to make 2-3-4 propellers before he get it right, but he learn from it every time, working a lot with VW's he is out on unknown waters, and that don't make it easier. But he get to know his VW's (and others) He is wrong about that it is impossible to calculate the correct pitch and propeller, you don't have to guess. They could do that during and before WW I What he is guessing is really how powerful his engines is, and how fast the plane will be. Knowing the HP, RPM and Speed you can calculate an correct Propeller the first time. You can do that with pen and paper, hand-calculator or why not a computer. The Computer make it possible to calculate it faster and more exact, easy to change a parameter and see the result and get warnings when it start to get unsafe, all in a milli sec. Carving the Propeller isn't that hard as many think, all you need is some tools most homebuilder have. Make a few templates, start with a saw and axe or power disk sander, a draw knife or planer, and finish with sandpaper. A propeller balancer should every homebuilder or wood propeller owner have. Jan Carlsson www.jcpropellerdesign.com "Ernest Christley" skrev i meddelandet m... Corky Scott wrote: Sebastian, several people have fabricated composite propellers in their shop. It isn't easy to do and the prop REALLY has to be of sound construction in order to withstand the forces of thrust, vibration reasonance and turbulence. I suggest you do a search on the internet to see if you can find the websites of those who have documented their techniques. Be prepared to spend a LOT of time getting it right. Propeller design is not simple. Good luck, Corky Scott In the library section to my website I have a link to "How I Make Propeller" The author does a very good job of telling you things you want to know. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
first time. You can do that with pen and paper, hand-calculator or why not a computer. The Computer make it possible to calculate it faster and more exact, easy to change a parameter and see the result and get warnings when it start to get unsafe, all in a milli sec. lets see ive got 15hp, 3400rpm and 25mph...can you help me out with the calculations? thank you |
hmm so i found this little model aiplane prop calculator utility...
http://www.gylesaero.com/freeware/propcalc.shtml i plug in 3400 rpm and 0mph airspeed (static) and if i want ~100lbs of thrust w/a 2blade it says i need an 8" pitch 50" diameter prop... i think thats doable but many questions remain... how do i select a propeller airfoil, aspect ratio? does an 8" pitch seem reasonable for my application? thats 3.8degrees at 0.75r if this little caculator is correct so is pitch usually measures at 3/4 the radius of the prop? how then do i determine twist from tip to hub? Shold i just use constant pitch with no twist for simplicity? how broad should the blade be? aaaahh... (sebastian) wrote in message . com... Knowing the HP, RPM and Speed you can calculate an correct Propeller the first time. You can do that with pen and paper, hand-calculator or why not a computer. The Computer make it possible to calculate it faster and more exact, easy to change a parameter and see the result and get warnings when it start to get unsafe, all in a milli sec. lets see ive got 15hp, 3400rpm and 25mph...can you help me out with the calculations? thank you |
MT MTV-9-B-C/C190 Propeller for Sale - Pitts N5351N.jpg (0/1) | Chris Nehls | Aerobatics | 2 | December 19th 04 05:38 AM |
Propeller question | John Nicholson | Home Built | 1 | October 11th 03 03:36 AM |
Pulsar with a turbine? | Badwater Bill | Home Built | 33 | August 28th 03 04:02 PM |
propeller calculation and how to build | jgarner | Home Built | 7 | August 25th 03 03:23 AM |
Propeller | Jan Carlsson | Home Built | 11 | July 12th 03 10:36 PM |
