Preflighted today for a two-hour trip only to discover one side of the
'02 C172 spinner bent outward. The metal spinner base holding that crucial bolt had ripped off like a piece of paper. With nothing to counteract the spinning forces, the outside skin of the spinner opened right up. Fortunately, four downstream screws prevented it from being completely ripped from the aircraft during its last flight. I have read accounts of people discovering the same problem with 30 hours on their aircraft. This aircraft has about 600 hours on it. And Cessna still denies there was a quality control problem with these spinners? There should have been an AD last year. Inspect those late model Cessna spinners for cracks at the bases very carefully during each preflight... -- Peter |
"Peter R." wrote in message ds.com... | | And Cessna still denies there was a quality control problem with these | spinners? There should have been an AD last year. | | Inspect those late model Cessna spinners for cracks at the bases very | carefully during each preflight... Sounds like someone is pushing on the spinner to move the aircraft around. |
"C J Campbell" wrote in message ... "Peter R." wrote in message ds.com... | | And Cessna still denies there was a quality control problem with these | spinners? There should have been an AD last year. | | Inspect those late model Cessna spinners for cracks at the bases very | carefully during each preflight... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? |
C J Campbell wrote:
"Peter R." wrote in message ds.com... | | And Cessna still denies there was a quality control problem with these | spinners? There should have been an AD last year. | | Inspect those late model Cessna spinners for cracks at the bases very | carefully during each preflight... Sounds like someone is pushing on the spinner to move the aircraft around. To my knowledge this aircraft is not pushed around with the spinner. I just got off the phone with maintenance who admitted that there have been so many late model C172 spinner cracking problems that they actually keep three or four in stock. Because of this, they were able to replace the spinner Saturday morning (this morning). Maintenance opined that there definitely seems to be a quality problem with these. -- Peter |
"Tom S." wrote in message ... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? The prop isn't really connected to the spinner. It's mounted to a plate which is mounted behind the prop on the crankshaft. It shouldn't be possible to bend the blade enough to contact the spinner. |
"Ron Natalie" wrote in message m... "Tom S." wrote in message ... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? The prop isn't really connected to the spinner. It's mounted to a plate which is mounted behind the prop on the crankshaft. It shouldn't be possible to bend the blade enough to contact the spinner. True, but nothing surprises me anymore. I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. |
C J Campbell wrote:
"Peter R." wrote in message ds.com... | | And Cessna still denies there was a quality control problem with these | spinners? There should have been an AD last year. | | Inspect those late model Cessna spinners for cracks at the bases very | carefully during each preflight... Sounds like someone is pushing on the spinner to move the aircraft around. CJ, this morning I stopped at out local maintenance shop to pick up the aircraft and to thank the A&P for quickly replacing the part early this Saturday morning. Since I knew that Cessna's warranty would be paying for the work, I brought him a dozen of fresh doughnuts. ![]() For a comparison, the A&P pulled out both an '03 and an '02 spinner "bulkhead" (where the spinner connects to the prop shaft), as he had both in stock. Cessna most certainly redesigned the bulkhead for '03 to prevent the type of failure that this 172's spinner bulkhead experienced. It was obvious that Cessna beefed up the metal surrounding the bolt holes as well as moved these bolt holes a tad closer to the center, away from the edge of the bulkhead. So I wonder to no one in particular: With the apparent number of reported failures (as per the A&P, along with what I read in either AOPA or Flying mag several months ago) coupled with this obvious redesign, why doesn't Cessna release a service bulletin for this part? -- Peter |
"Tom S." wrote: I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. Did it work? George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
"G.R. Patterson III" wrote in message ... "Tom S." wrote: I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. Did it work? Sure did..sorta. He told me it was broke and needed to be replaced. |
| Thread Tools | |
| Display Modes | |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Piloting | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
