![]() "C J Campbell" wrote in message ... "Peter R." wrote in message ds.com... | | And Cessna still denies there was a quality control problem with these | spinners? There should have been an AD last year. | | Inspect those late model Cessna spinners for cracks at the bases very | carefully during each preflight... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? |
![]() "Tom S." wrote in message ... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? The prop isn't really connected to the spinner. It's mounted to a plate which is mounted behind the prop on the crankshaft. It shouldn't be possible to bend the blade enough to contact the spinner. |
![]() "Ron Natalie" wrote in message m... "Tom S." wrote in message ... Sounds like someone is pushing on the spinner to move the aircraft around. Or the prop blade? The prop isn't really connected to the spinner. It's mounted to a plate which is mounted behind the prop on the crankshaft. It shouldn't be possible to bend the blade enough to contact the spinner. True, but nothing surprises me anymore. I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. |
![]() "Tom S." wrote: I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. Did it work? George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
![]() "G.R. Patterson III" wrote in message ... "Tom S." wrote: I had one guy try to fix my garbage disposal by hitting it really hard with a hammer. Did it work? Sure did..sorta. He told me it was broke and needed to be replaced. |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Piloting | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
