Sebastian,
With data on both engine and speed it is easy to calculate an propeller. I sugest you make a wood propeller first, then you can see how much prop you need, The Idea is to "load" the engine so you get the desired RPM, with the most optimum prop you can get at the design "point" (speed) Even if it is calculated correctly there can be unknown factors, like if the engine turn out 2 HP more or less!? Then it is easy quick and cheep to make a new wood propeller The blade have to be twisted, you have to know the differens of Pitch and Angle, an prop with uniform pitch along the blade have the blade twisted to higher angle closer to the hub. Even with reduced pitch near the hub, the angle is normaly higher there. With the Prop behind the back(pack) It will work in turbulant air, specially near the hub it will be "dead" air, closer to the tip it will work in the "aircrafts" forward speed + the induced air (air sucked in) The Induced airspeed will be large compered to forward speed. What is the normal Climb speed, Cruise speed and top speed for a paramotor? Jan Carlsson www.jcpropellerdesign.com "sebastian" skrev i meddelandet om... then youre saying the best way to answer the questions is...empirically. or can i make decisions a priori about prop geometry based on my input power (15hp) and rpm (2500)? it would seem that long non twisting, tapered, symetric airfoil blades that are ground adjustable in pitch and varied in the nr of blades on the hub would be the better way since the the variables of pitch, diameter(shortening), & nr of blades could be experimented with and optimized. I suppose under these circumstances all effort should be put into aspect ratio since that is the one varibale that would be most difficult to vary and test. so with that said, any advice on choosing an aspect ratio for my purpose? and as a i vary these parameters...how do i measure changes in thrust directly...attach my motor to a scale somehow? "Jan Carlsson" wrote in message ... A constant pitch will be better then a constant angle and blade width. The Q is what Pitch, what Diameter, what Aspect Ratio, what nr of blades? The questions is the same whatever it is a one meter model plane, back pak or a turbo-prop. Jan Carlsson "sebastian" skrev i meddelandet om... ah well, that was exactly the type of feeback i was looking for thanks. My revised plan is to experiment with building a carbon fiber propeller. I like the general design theory behind the wind turbine that i specified, so I am thinking of inverting the pitch for thrust and making the blade shorter and broader (45-50" diameter, 2-4" wide tapering to tip). My plan is to make foam airfoil cores with a hotwire cutter, extensively reinforce the lengthwise direction with unidirectional carbon fiber roving, and wrap the whole blade with carbon fiber farbric and vacuum bag. I would use a similar twisting geometry that narrows and goes from ~20 degrees to nearly a flat pitch at the tip and transforms from an elipitcal cross section at the hub to an airfoil at the tip. or would it be better and simpler to have a constant pitch, width, and airfoil and make the overall pitch ground adjustable. Rememeber i need it to be as light and efficent as possible this is for a paraglider fan (backpack type) not some big beefy airplane. Any suggestions? |
Hi Jan I really appreciate the feedback,
Paragliders are inherently very very slow. A typical paramotor will have between 15-30hp a very moderate climb rate of 150-300ft/min, climb speed of 15-20mph, and cruise at about 25-30mph, max speed ~35mph on good day. Part of the reason im setting out to design my own is that i plan to make use of an electric motor rather that internal combustion engine. Im using a dc motor that produces maxium power (15hp) at 48v with 72 rpm/volt =3456rpm. But i may try to run it at 36v first =2592rpm. One of the nice things about this motor is its increadibly high and flat torque across the rpm range. so constant speed propeller= no twist but changes angle of attack and constant pitch propeller =constant change in angle over length (twist) how is that measured... angle change/inch??? fixed angle propeller =no change in pitch or angle of attack how do i do i measure or determine loading... or since i know my torque will be good at any speed should i design the propeller for maximum power which i know is going to be ~3400rpm. and how do i factor number of blades in the the equation...simpler would be better but wont more blades allow more thrust per rpm and smaller diameter and lower tip speed/noise...part of the reason im going electric is to make it as quiet as possible... thanks!!!! 'Jan Carlsson" wrote in message ... Sebastian, With data on both engine and speed it is easy to calculate an propeller. I sugest you make a wood propeller first, then you can see how much prop you need, The Idea is to "load" the engine so you get the desired RPM, with the most optimum prop you can get at the design "point" (speed) Even if it is calculated correctly there can be unknown factors, like if the engine turn out 2 HP more or less!? Then it is easy quick and cheep to make a new wood propeller The blade have to be twisted, you have to know the differens of Pitch and Angle, an prop with uniform pitch along the blade have the blade twisted to higher angle closer to the hub. Even with reduced pitch near the hub, the angle is normaly higher there. With the Prop behind the back(pack) It will work in turbulant air, specially near the hub it will be "dead" air, closer to the tip it will work in the "aircrafts" forward speed + the induced air (air sucked in) The Induced airspeed will be large compered to forward speed. What is the normal Climb speed, Cruise speed and top speed for a paramotor? Jan Carlsson www.jcpropellerdesign.com "sebastian" skrev i meddelandet om... then youre saying the best way to answer the questions is...empirically. or can i make decisions a priori about prop geometry based on my input power (15hp) and rpm (2500)? it would seem that long non twisting, tapered, symetric airfoil blades that are ground adjustable in pitch and varied in the nr of blades on the hub would be the better way since the the variables of pitch, diameter(shortening), & nr of blades could be experimented with and optimized. I suppose under these circumstances all effort should be put into aspect ratio since that is the one varibale that would be most difficult to vary and test. so with that said, any advice on choosing an aspect ratio for my purpose? and as a i vary these parameters...how do i measure changes in thrust directly...attach my motor to a scale somehow? "Jan Carlsson" wrote in message ... A constant pitch will be better then a constant angle and blade width. The Q is what Pitch, what Diameter, what Aspect Ratio, what nr of blades? The questions is the same whatever it is a one meter model plane, back pak or a turbo-prop. Jan Carlsson "sebastian" skrev i meddelandet om... ah well, that was exactly the type of feeback i was looking for thanks. My revised plan is to experiment with building a carbon fiber propeller. I like the general design theory behind the wind turbine that i specified, so I am thinking of inverting the pitch for thrust and making the blade shorter and broader (45-50" diameter, 2-4" wide tapering to tip). My plan is to make foam airfoil cores with a hotwire cutter, extensively reinforce the lengthwise direction with unidirectional carbon fiber roving, and wrap the whole blade with carbon fiber farbric and vacuum bag. I would use a similar twisting geometry that narrows and goes from ~20 degrees to nearly a flat pitch at the tip and transforms from an elipitcal cross section at the hub to an airfoil at the tip. or would it be better and simpler to have a constant pitch, width, and airfoil and make the overall pitch ground adjustable. Rememeber i need it to be as light and efficent as possible this is for a paraglider fan (backpack type) not some big beefy airplane. Any suggestions? |
![]() "sebastian" wrote how do i do i measure or determine loading... or since i know my torque will be good at any speed should i design the propeller for maximum power which i know is going to be ~3400rpm. and how do i factor number of blades in the the equation...simpler would be better but wont more blades allow more thrust per rpm and smaller diameter and lower tip speed/noise...part of the reason im going electric is to make it as quiet as possible... thanks!!!! More importantly, how do you factor in the couple hundred pounds of battery weight? Start by doing some power required, and wattage required calculations. Then convert that to battery weight you can afford. You may soon see why electric flight has not become a realistic option. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.629 / Virus Database: 403 - Release Date: 3/17/2004 |
![]() "sebastian" wrote in message om... Hi Jan I really appreciate the feedback, Paragliders are inherently very very slow. A typical paramotor will have between 15-30hp a very moderate climb rate of 150-300ft/min, climb speed of 15-20mph, and cruise at about 25-30mph, max speed ~35mph on good day. Part of the reason im setting out to design my own is that i plan to make use of an electric motor rather that internal combustion engine. Im using a dc motor that produces maxium power (15hp) at 48v with 72 rpm/volt =3456rpm. But i may try to run it at 36v first =2592rpm. One of the nice things about this motor is its increadibly high and flat torque across the rpm range. and how do i factor number of blades in the the equation...simpler would be better but wont more blades allow more thrust per rpm and smaller diameter and lower tip speed/noise...part of the reason im going electric is to make it as quiet as possible... thanks!!!! You might want to consider that a horsepower is 746 watts. 15 times that is about 11000 watts. At 50 volts, you're going to be drawing about 220 Amperes. You're going to need a lot of copper to transmit that current. You're going to need a lot of battery to provide 220 amps for any significant period of time. Designing a motor controller at those currents is _NOT_ a trivial exercise. A propeller is the least of your worries. Tim Ward |
I like your idea of experimenting if you just wanted to fly it would be
cheeper to just buy a redy to fly kit. I put some comments in between below; "sebastian" wrote. Hi Jan I really appreciate the feedback, Paragliders are inherently very very slow. A typical paramotor will have between 15-30hp a very moderate climb rate of 150-300ft/min, climb speed of 15-20mph, and cruise at about 25-30mph, max speed ~35mph on good day. Part of the reason im setting out to design my own is that i plan to make use of an electric motor rather that internal combustion engine. Im using a dc motor that produces maxium power (15hp) at 48v with 72 rpm/volt =3456rpm. But i may try to run it at 36v first =2592rpm. One of the nice things about this motor is [How many HP is it developing at 36V?] its increadibly high and flat torque across the rpm range. so constant speed propeller= no twist but changes angle of attack [ Constant speed propellers keep the RPM at the from cockpit set RPM, The propeller still have a twist ] and constant pitch propeller =constant change in angle over length [ Correct] (twist) how is that measured... angle change/inch??? [ Normaly the pitch is measured at different Stations along the blade, like 15, 30, 45, 60, 75, and 90% of the radii.] fixed angle propeller =no change in pitch or angle of attack [Called Fixed Pitch Propellers.] [ A constantspeed/adjusteble prop can have a constant PITCH at a certain angle measured at the 75% radii (like15 deg.) from tip to about 40% radii. The blade angle change ofcourse with the radii to keep the pitch. When the Pitch/angle is changed (blade rotated) the pitch will no longer be constant, with higher then the 15 deg setting the PITCH will be greater at the tip then at the 40% radii ] how do i do i measure or determine loading... or since i know my torque will be good at any speed should i design the propeller for maximum power which i know is going to be ~3400rpm. [You want the engine to turn at maximum at max speed, or with a less powerful engine near max rpm at climb speed, then you will cruise at near max RPM but with reduced power, that is good with en electric engine because it will use less energy at high RPM then at reduced RPM with more propeller load. ] and how do i factor number of blades in the the equation...simpler would be better but wont more blades allow more thrust per rpm and smaller diameter and lower tip speed/noise...part of the reason im going electric is to make it as quiet as possible... [ I don't think the tip speed will be a problem, a 2 blad prop will be better with its larger diameter, what you want/need is max thrust with the extra weight from batteries and the relativ weak engine. With the 15 HP/3450 RPM you will end up with a 43"- 45" diameter, 38,5" with 3 blade, and 35,5" with 4 blade!] Jan Carlsson www.jcpropellerdesign.com thanks!!!! 'Jan Carlsson" wrote in message ... Sebastian, With data on both engine and speed it is easy to calculate an propeller. I sugest you make a wood propeller first, then you can see how much prop you need, The Idea is to "load" the engine so you get the desired RPM, with the most optimum prop you can get at the design "point" (speed) Even if it is calculated correctly there can be unknown factors, like if the engine turn out 2 HP more or less!? Then it is easy quick and cheep to make a new wood propeller The blade have to be twisted, you have to know the differens of Pitch and Angle, an prop with uniform pitch along the blade have the blade twisted to higher angle closer to the hub. Even with reduced pitch near the hub, the angle is normaly higher there. With the Prop behind the back(pack) It will work in turbulant air, specially near the hub it will be "dead" air, closer to the tip it will work in the "aircrafts" forward speed + the induced air (air sucked in) The Induced airspeed will be large compered to forward speed. What is the normal Climb speed, Cruise speed and top speed for a paramotor? Jan Carlsson www.jcpropellerdesign.com "sebastian" skrev i meddelandet om... then youre saying the best way to answer the questions is...empirically. or can i make decisions a priori about prop geometry based on my input power (15hp) and rpm (2500)? it would seem that long non twisting, tapered, symetric airfoil blades that are ground adjustable in pitch and varied in the nr of blades on the hub would be the better way since the the variables of pitch, diameter(shortening), & nr of blades could be experimented with and optimized. I suppose under these circumstances all effort should be put into aspect ratio since that is the one varibale that would be most difficult to vary and test. so with that said, any advice on choosing an aspect ratio for my purpose? and as a i vary these parameters...how do i measure changes in thrust directly...attach my motor to a scale somehow? "Jan Carlsson" wrote in message ... A constant pitch will be better then a constant angle and blade width. The Q is what Pitch, what Diameter, what Aspect Ratio, what nr of blades? The questions is the same whatever it is a one meter model plane, back pak or a turbo-prop. Jan Carlsson "sebastian" skrev i meddelandet om... ah well, that was exactly the type of feeback i was looking for thanks. My revised plan is to experiment with building a carbon fiber propeller. I like the general design theory behind the wind turbine that i specified, so I am thinking of inverting the pitch for thrust and making the blade shorter and broader (45-50" diameter, 2-4" wide tapering to tip). My plan is to make foam airfoil cores with a hotwire cutter, extensively reinforce the lengthwise direction with unidirectional carbon fiber roving, and wrap the whole blade with carbon fiber farbric and vacuum bag. I would use a similar twisting geometry that narrows and goes from ~20 degrees to nearly a flat pitch at the tip and transforms from an elipitcal cross section at the hub to an airfoil at the tip. or would it be better and simpler to have a constant pitch, width, and airfoil and make the overall pitch ground adjustable. Rememeber i need it to be as light and efficent as possible this is for a paraglider fan (backpack type) not some big beefy airplane. Any suggestions? |
MT MTV-9-B-C/C190 Propeller for Sale - Pitts N5351N.jpg (0/1) | Chris Nehls | Aerobatics | 2 | December 19th 04 05:38 AM |
Propeller question | John Nicholson | Home Built | 1 | October 11th 03 03:36 AM |
Pulsar with a turbine? | Badwater Bill | Home Built | 33 | August 28th 03 04:02 PM |
propeller calculation and how to build | jgarner | Home Built | 7 | August 25th 03 03:23 AM |
Propeller | Jan Carlsson | Home Built | 11 | July 12th 03 10:36 PM |
