Here's a bet for you: I bet that a metric ****load more GA pilots have crashed
due to NOT looking at the instruments (like in IMC) than have crashed due to (over)reliance on instruments. It's a great exercise to do a landing with the ASI, etc. out once in a while whether a student or experienced pilot just to know that it can be done in the event of an instrument failure. But I will tell you that when one is faced with it, either real or simulated, it is a grave mistake to fly any sort pattern other than an unhurried one with gentle turns. There is no good reason to compound one problem (e.g. ASI inop) with another (steep turn/uncoordinated/sudden pitch changes/etc.). Most accidents, including training accidents, are caused by a series of events and bad decisions - not just one. You know, my old C-150 was real easy to land without looking at the ASI. It had a low stall speed, lots of warning before a stall, and a wide band of approach speeds that would work. But my Musketeer, while easier in general to fly and land, has a high(er) stall speed, little warning before a stall, and a narrow band of approach speeds that will work. Can I land without an ASI? Damn skippy I can, but I'm going to take advantage of everything in my toolbox if it comes to it. I'll try to go to an airport with a long runway, make shallow turns, use full flaps, keep the ball centered, and I'm not going to practice it either. It's just not worth it. Stepping up on an even higher soap box now: I get absolutly worn out with the guys who want to tell everybody that they aren't a good/safe/real pilot if they aren't completely minimalist and avoid use of any new-fangled inventions. Like the slip/skid ball. Oh please! "Boy, you just ain't a real pilot if you can't fly a tail dragger". Fine. I don't want to be a "real" pilot then. Tricycle gear is easier and safer. Ask your insurance man if you want proof. Good enough for me. "Back in my day, we had to learn to spin them aeroplanes. You just ain't no kinda pilot if you don't do it and like it.". Well why is it now that spin avoidance rather than spin training is taught that the occurance of stall/spin accidents is lower? And so forth. If you want to fly a plane with no dials, then go right ahead. Just stop telling everybody that you are superior to those of us who divide their time properly to looking at the panel and out the window. Off my soap box now. Best regards, Steve Robertson, CFI and old guy N4732J 1967 Beechcraft A23-24 Musketeer Super III Roger Long wrote: Guilty as charged of poor word choice. The key point is that an overshot turn, in most cases, doesn't have to even be salvaged. Just hold normal pattern turn attitude and you'll come back to centerline in time to get down on most runways used by anything larger than trainers. Holding attitude instead of trying to increase the turn with bank and or rudder is the core message. Even if you are going around, you want to get back to the centerline in case someone is flying a real tight downwind. Holding that 20 degree bank until you get there will make it easier to look for them. I got us off on instrument use which is really a separate discussion that applies to all pattern flying; not just an overshot turn. If I were a CFI and my student got into that position, I would sure want to think he would take a quick check at the gauges to be sure he hadn't strayed too far out of the envelope instead of thinking he wasn't supposed to do that and trying to feel his way out. Learning to rely less on the instruments, attitude flying, and all that is an important part of training and an objective for proficiency. However, "Don't look at the panel!", is not a dogma that should be handed out to blindly apply to all landing situations. Learning to fly without reference to the instruments is something the student should be initially doing with a CFI in the right seat. Most students will be overshooting a number of final turns before they are ready to judge RPM, airspeed, and coordination without instruments. Being able to get a plane landed with out looking at the instruments is one thing. Flying a precise pattern, landing in the minimum distance, at the lowest touchdown speed is another. Most pilots are not going to be able to maintain the level of proficiency where they can do those things safely without a glance at the panel at certain points in the pattern. Flying like it was flight simulator is a different issue which should be addressed. Pilots should practice patterns without looking at gauges. They should also do patterns with gauge checks to be sure that they really are flying the flight profile they are practicing. A sad but true thing is that the kind of training most students are going to get will require that they use the instruments as checks while they teach themselves how to fly the pattern properly. Having CFI's who teach attitude flying properly telling them in a forum like this that looking at the panel is a bad thing is, in my view, a bad thing. -- Roger Long A Lieberman wrote in message ... Roger Long wrote: Sure it is, if you are a low time student pilot trying to salvage an overshot turn before you have developed a good feel for the plane. Hi Roger, Just "my opinion". but salvage and student in the same sentence is a bad choice of words. If the low time student overshot the turn to the point where the word salvage comes into play, I would suggest just going around and trying again..... Allen (who is not a CFI). |
Steve,
Thank you for taking time to write such a long and excellent post. I'm used to all sorts wacky opinions and divergent viewpoints in these newsgroups but the near unanimous position that I'm a dangerous nut because I look at my gauges while flying was startling. I asked the question in the Pilot Techniques Forum at Cessna Pilots Association where I spend a lot of time and the unanimous position there backed up my view point. Interesting cultural difference. A fellow who teaches seminars for advanced pilots said, "Relying on the sight picture ONLY and not glancing at the airspeed has resulted in many a flatlander stalling on final at a high altitude airport. Airspeed, airspeed, airspeed." I would hate to thing that a student pilot, perhaps not getting the best of instruction, would look at the consensus of lot of high time pilots here and decide that he should stop looking at his gauges as opposed to properly integrating no panel flying into his training. Let's see if we can get anyone to take you up on your bet ![]() -- Roger Long |
"Roger Long" om wrote in
message ... [...] I asked the question in the Pilot Techniques Forum at Cessna Pilots Association where I spend a lot of time and the unanimous position there backed up my view point. Interesting cultural difference. A fellow who teaches seminars for advanced pilots said, "Relying on the sight picture ONLY and not glancing at the airspeed has resulted in many a flatlander stalling on final at a high altitude airport. Airspeed, airspeed, airspeed." No one here is proposing one rely ONLY on the sight picture. I made it very clear that one needs to pay attention to the other sensory input. In particular, engine and airstream noise along with control feel are very important and clear indications of airspeed. If all else fails, you have a stall warning indicator (on any reasonably "modern" airplane), but it really shouldn't get that far. The sight picture is useful only for airplane attitude information and for that, is only completely accurate in unaccelerated flight (though it's still useful in accelerated flight). I am always amused when someone takes a debate from one forum, claims to have posed it in another forum and then comes back and says "well, at least *those* guys agree 100% with me". It is almost never the case that a) the nature of the debate was actually conveyed accurately, and b) that the support in the other forum is as unanimous as claimed (unless the information posed in the other forum was SO skewed as to be absurdly and obviously wrong). Steve's post also demonstrates a sad misinterpretation of the debate at hand. He's obviously a bit touchy about the subject and is taking things personally. No one is claiming that he isn't a good pilot just because he wants to use "new-fangled" inventions, nor is this debate anything like the "tricycle vs conventional" stuffed-shirt crap. He's getting his ego bent out of shape for no reason at all. No one is suggesting that aircraft instruments should be ignored. But to claim that during VFR flight, the aircraft's instruments deserve anywhere close to 50% of your attention is just plain absurd. Yes, pilots need to "divide their time properly to looking at the panel and out the window". But "divide their time properly" means the vast majority of time is spent looking OUTSIDE. And those instruments are NOT the primary reference for maneuvering, not even close. Pete |
Well, now you're doing it. I never said 50%. Dividing time properly could
be 5% / 95% or even 1% / 99% Anyway, we've had fun. I think we all know where we stand. Excuse me, gotta go check my airspeed ![]() -- Roger Long Peter Duniho wrote in message ... "Roger Long" om wrote in message ... [...] I asked the question in the Pilot Techniques Forum at Cessna Pilots Association where I spend a lot of time and the unanimous position there backed up my view point. Interesting cultural difference. A fellow who teaches seminars for advanced pilots said, "Relying on the sight picture ONLY and not glancing at the airspeed has resulted in many a flatlander stalling on final at a high altitude airport. Airspeed, airspeed, airspeed." No one here is proposing one rely ONLY on the sight picture. I made it very clear that one needs to pay attention to the other sensory input. In particular, engine and airstream noise along with control feel are very important and clear indications of airspeed. If all else fails, you have a stall warning indicator (on any reasonably "modern" airplane), but it really shouldn't get that far. The sight picture is useful only for airplane attitude information and for that, is only completely accurate in unaccelerated flight (though it's still useful in accelerated flight). I am always amused when someone takes a debate from one forum, claims to have posed it in another forum and then comes back and says "well, at least *those* guys agree 100% with me". It is almost never the case that a) the nature of the debate was actually conveyed accurately, and b) that the support in the other forum is as unanimous as claimed (unless the information posed in the other forum was SO skewed as to be absurdly and obviously wrong). Steve's post also demonstrates a sad misinterpretation of the debate at hand. He's obviously a bit touchy about the subject and is taking things personally. No one is claiming that he isn't a good pilot just because he wants to use "new-fangled" inventions, nor is this debate anything like the "tricycle vs conventional" stuffed-shirt crap. He's getting his ego bent out of shape for no reason at all. No one is suggesting that aircraft instruments should be ignored. But to claim that during VFR flight, the aircraft's instruments deserve anywhere close to 50% of your attention is just plain absurd. Yes, pilots need to "divide their time properly to looking at the panel and out the window". But "divide their time properly" means the vast majority of time is spent looking OUTSIDE. And those instruments are NOT the primary reference for maneuvering, not even close. Pete |
message .. . Well, now you're doing it. I never said 50%. Dividing time properly could be 5% / 95% or even 1% / 99% You're right. That figure was simply an example, my interpretation of more general and vague comments. But the actual figure doesn't matter that much. IMHO, any non-zero amount of time spent watching the instruments while making a downwind-to-base or base-to-final turn while in the pattern is too much time. That's for any kind of turn, but becomes especially true in the overshoot case. Transitioning to instrument flight (as your original post suggested) while attempting to reintercept final approach in a VFR pattern is just plain wrong. Pete |
The instruments may well be a VFR crutch. This all started by my suggesting
that pilots who are still at the stage where they need a crutch sometimes, make use of it when they've gotten in a situation where many pilots have screwed up. Since we are clarifying, I was didn't mean to say (although it wasn't my best and clearest piece of newsgroup banter) that they should transition to the instruments and use them to fly through the turn, just that it would be a good time to check that were still comfortably within the envelope. While the underlying cause may well have been lack of proper training or proficiency, there are certainly a lot of pilots who wish they had checked their airspeed during their last base to final turn. I wish we could hear from them but their computer access is kinda blocked right now.... -- Roger Long Peter Duniho wrote in message ... "Roger Long" om wrote in message .. . Well, now you're doing it. I never said 50%. Dividing time properly could be 5% / 95% or even 1% / 99% You're right. That figure was simply an example, my interpretation of more general and vague comments. But the actual figure doesn't matter that much. IMHO, any non-zero amount of time spent watching the instruments while making a downwind-to-base or base-to-final turn while in the pattern is too much time. That's for any kind of turn, but becomes especially true in the overshoot case. Transitioning to instrument flight (as your original post suggested) while attempting to reintercept final approach in a VFR pattern is just plain wrong. Pete |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
How 'bout a thread on the F-22 with no mud slinging, no axe grinding, no emotional diatribes, and just some clear, objective discussion? | Scott Ferrin | Military Aviation | 23 | January 8th 04 12:39 AM |
This post will clear a lot of things up | Jack White | Military Aviation | 0 | September 14th 03 10:52 AM |
