#161
link.net... How do YOU know I'm not familiar with ATC's radar capabilities? I don't. Note the use of "appear" in my post. All I can comment on is what appears to be the case. Obviously I cannot comment on the actual facts. That's why I used the word "appear". What makes YOU think most controllers are much better informed than I am? If you mean why does it appear most controllers are much better informed than you are, if you'll read back in this thread, you'll see why. The other controllers aren't asking for detailed explanations of how ATC radar works and what its capabilities are. If you literally mean "what makes me think..." that's no more valid a question then "have you stopped beating your wife?" I never said what I think. I simply said how things appear. Pete |
#162
![]() "Peter Duniho" wrote in message ... I don't. Note the use of "appear" in my post. All I can comment on is what appears to be the case. Obviously I cannot comment on the actual facts. That's why I used the word "appear". You didn't use the word "appear" when you wrote; "ATC doesn't have enroute radar capable of determining when another aircraft is within those limits." You stated it as a fact. If you mean why does it appear most controllers are much better informed than you are, if you'll read back in this thread, you'll see why. That cannot be ascertained by reviewing this thread. The other controllers aren't asking for detailed explanations of how ATC radar works and what its capabilities are. And the other non-controllers are not making statements about the capabilities of ATC radar. You are. If you literally mean "what makes me think..." that's no more valid a question then "have you stopped beating your wife?" I never said what I think. I simply said how things appear. Actually, with regard to ATC radar, you said how things are. What made you think you knew something about ATC radar? |
#163
![]() "Steven P. McNicoll" wrote in message hlink.net... "Greg Goodknight" wrote in message hlink.net... 6 degrees, at the equator, is 24 minutes, do the math (remember, 360 degrees in 24 hours) but that's at the equator. No math required, read the regulation. I did. What is the working definition of "sunrise" and "sunset" here? When Grass Valley (O17) had a night closure a few years ago over a trees and obstruction light snafu, SVFR is not available at O17. I didn't say it was. I *was* relating how the local FSDO popped up with 30 minutes for a local regulatory issue. I pressed the issue with the local FSDO; they came back with 30 minutes being the rule of thumb they use in the 48 states. The US has fifty states. Ya don't say! Brilliant observation, Sherlock. Trying to be snotty, are we? The US has 50 plus some occupied territory (including D.C.) but I was talking about 48 of them. You can guess which ones if you try. I probably could have said 49 but I wasn't sure if Hawaii was included in the factoid. It's not a "rule of thumb", it's a regulation. The regulation clearly states that fixed-wing Special VFR operations may only be conducted between sunrise and sunset (or in Alaska, when the sun is 6 degrees or more below the horizon) unless the pilot and airplane are capable of IFR flight. Yes, Alaska sometimes doesn't have a sunrise or sunset. The ICAO has the 6 degree rule to define twilight; not the sun 6 degrees below the horizon, but the midpoint of the sun being 6 degrees below the horizon. For some of that time the sun is showing, and around here there is light good enough for unlit airport operations until about 30 minutes after the sun's midpoint is on the ideal horizon, or 30 minutes before for "sunup". Since that reg calls it sunrise and sunset for 49 states but in essence quotes the ICAO definition for twilight for Alaska, I'm going to believe they were not defining a lower standard for Alaska but rather letting Alaska's aviators figure it out for themselves when they don't have most would call a daily sunrise and sunset, and when you can see sunlight in the morning (which is six degrees) it's sunrise, and in the evening and you can't see sunlight that's sunset. If controllers really do stop day SVFR operations in California when it's still light enough to see, I stand corrected; and it could be a lower light standard in Alaska because the light levels change slowly there. You may have caught me this time, Steven. It's about time you got one right! ![]() -Greg |
#164
hlink.net... You didn't use the word "appear" when you wrote; "ATC doesn't have enroute radar capable of determining when another aircraft is within those limits." Why would I have? That cannot be ascertained by reviewing this thread. Of course it can. And the other non-controllers are not making statements about the capabilities of ATC radar. You are. What do non-controllers have to do with it? Actually, with regard to ATC radar, you said how things are. What made you think you knew something about ATC radar? How is that relevant to the question of what YOU know (or appear to know) about ATC radar? If you want to change the subject, start a new thread. Otherwise, try to stick to what we were actually talking about. Pete |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
About when did a US/CCCP war become suicidal? | james_anatidae | Military Aviation | 96 | February 29th 04 03:24 PM |
US plans 6,000mph bomber to hit rogue regimes from edge of space | Otis Willie | Military Aviation | 14 | August 5th 03 01:48 AM |
Rogue State | jukita | Military Aviation | 18 | July 13th 03 02:22 PM |
