Hi,
After taking two passengers on SF-Bay tours, I realized that I want to take the tour slower... A north-bay tour (SF, GGB, Ocean Beach, without the 101/Bravo transition) takes about 40min roundtrip from OAK - a little quick. I've been used to flying with the rpm around the bottom of the green arc for this kind of thing, as my CFI used to always remind me that "Carb-Heat introduces unfiltered air [into the carb]" which is a bad thing... Basically - is it bad for the aircraft (C172) to float around at around 85kts with the power somewhere below the green arc (say 1800rpm) and the Carb-Heat on? Ok, there is a second benefit - my club charges based on tach time, and I have to be honest about that - although I really do wish for the tours to be slower. Thanks for any comments, Noah |
![]() "noah" wrote in message om... Basically - is it bad for the aircraft (C172) to float around at around 85kts with the power somewhere below the green arc (say 1800rpm) and the Carb-Heat on? Ok, there is a second benefit - my club charges based on tach time, and I have to be honest about that - although I really do wish for the tours to be slower. Most of the dirt is pretty close to the ground. Unless you're flying through a duststorm or volcanic erruption, at altitude there shouldn't be much harm in leaving the heat on. |
My thread isn't really on-topic, but I just had to chime in. The SF Bay
tour is such a charge to take friends with you on. While I've certainly taken some on the $100 hamburger stops, nothing has quite inspired the oohs and aahhs as the SF Bay Tour. I'm so glad that the Fatherland... oops I mean Homeland security , hasn't been needlessly paranoid and allowed the SF Bay Tours... -- -- Good Flights! Cecil E. Chapman, Jr. PP-ASEL "We who fly do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis- Check out my personal flying adventures: www.bayareapilot.com "noah" wrote in message om... Hi, After taking two passengers on SF-Bay tours, I realized that I want to take the tour slower... A north-bay tour (SF, GGB, Ocean Beach, without the 101/Bravo transition) takes about 40min roundtrip from OAK - a little quick. I've been used to flying with the rpm around the bottom of the green arc for this kind of thing, as my CFI used to always remind me that "Carb-Heat introduces unfiltered air [into the carb]" which is a bad thing... Basically - is it bad for the aircraft (C172) to float around at around 85kts with the power somewhere below the green arc (say 1800rpm) and the Carb-Heat on? Ok, there is a second benefit - my club charges based on tach time, and I have to be honest about that - although I really do wish for the tours to be slower. Thanks for any comments, Noah |
om... Basically - is it bad for the aircraft (C172) to float around at around 85kts with the power somewhere below the green arc (say 1800rpm) and the Carb-Heat on? Just remember to lean the engine. Technically, at that altitude you theoretically wouldn't need to, based on the POH. But in reality, even without the carb heat, leaning in cruise regardless of altitude is a fine thing, and especially with the enrichened mixture caused by the carb heat, it's nice for the engine. Pete |
I just want to take this opportunity to totally, 100%, and unreservedly
agree with Peter ![]() -- Roger Long Peter Duniho wrote in message ... "noah" wrote in message om... Basically - is it bad for the aircraft (C172) to float around at around 85kts with the power somewhere below the green arc (say 1800rpm) and the Carb-Heat on? Just remember to lean the engine. Technically, at that altitude you theoretically wouldn't need to, based on the POH. But in reality, even without the carb heat, leaning in cruise regardless of altitude is a fine thing, and especially with the enrichened mixture caused by the carb heat, it's nice for the engine. Pete |
"Roger Long" om wrote in
message ... I just want to take this opportunity to totally, 100%, and unreservedly agree with Peter ![]() I know you do that just to **** me off! ![]() |
![]() Peter Duniho wrote: "Roger Long" om wrote in message ... I just want to take this opportunity to totally, 100%, and unreservedly agree with Peter ![]() I know you do that just to **** me off! You get upset when people agree with you? That explains a lot. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
"G.R. Patterson III" wrote in message
... You get upset when people agree with you? No, just Roger. I only get ****ed off because I know he's doing it to **** me off. ![]() missed). That explains a lot. Like what? Pete |
Peter,
echnically, at that altitude you theoretically wouldn't need to, based on the POH. Wrong. Most all POHs tell you to lean at any altitude AT CRUISE POWER SETTINGS. -- Thomas Borchert (EDDH) |
"Thomas Borchert" wrote in message
... Peter, echnically, at that altitude you theoretically wouldn't need to, based on the POH. Wrong. Most all POHs tell you to lean at any altitude AT CRUISE POWER SETTINGS. Wrong? Completely? So wrong that you found it so very important to follow up to say so? Amazing. In any case... Not all do. Many state or imply that leaning is not necessary below 3000' or 5000', for example. And it may even be true that leaning isn't *really* necessary, from an operational point of view. But engine will be much happier if you do. I don't have the POH he's using, so I have no idea what it says. My comments were offered purely in the hypothetical, so I don't see how you can make an unqualified assertion that they were wrong. My point is that, even if the POH says you don't need to lean, one ought to anyway in this particular case. Do you disagree with the actual point, or are you so hard up you find it necessary to critique embedded statements that could be construed as being flatly incorrect, even when they aren't? Pete |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
