Flying with the Carb-Heat on for a long(er) tour?
Old November 14th 03, 05:23 PM
noah
Default Flying with the Carb-Heat on for a long(er) tour?
Hi,
After taking two passengers on SF-Bay tours, I realized that I
want to take the tour slower... A north-bay tour (SF, GGB, Ocean
Beach, without the 101/Bravo transition) takes about 40min roundtrip
from OAK - a little quick.
I've been used to flying with the rpm around the bottom of the
green arc for this kind of thing, as my CFI used to always remind me
that "Carb-Heat introduces unfiltered air [into the carb]" which is a
bad thing...
Basically - is it bad for the aircraft (C172) to float around at
around 85kts with the power somewhere below the green arc (say
1800rpm) and the Carb-Heat on? Ok, there is a second benefit - my club
charges based on tach time, and I have to be honest about that -
although I really do wish for the tours to be slower.
Thanks for any comments,
Noah
Old November 14th 03, 05:36 PM
Ron Natalie
"noah" wrote in message om...
Most of the dirt is pretty close to the ground. Unless you're flying through
a duststorm or volcanic erruption, at altitude there shouldn't be much harm
in leaving the heat on.
Old November 14th 03, 07:00 PM
Cecil E. Chapman
My thread isn't really on-topic, but I just had to chime in. The SF Bay
tour is such a charge to take friends with you on. While I've certainly
taken some on the $100 hamburger stops, nothing has quite inspired the oohs
and aahhs as the SF Bay Tour. I'm so glad that the Fatherland... oops I
mean Homeland security , hasn't been needlessly paranoid and allowed the SF
Bay Tours...
Good Flights!
Cecil E. Chapman, Jr.
PP-ASEL
"We who fly do so for the love of flying.
We are alive in the air with this miracle
that lies in our hands and beneath our feet"
- Cecil Day Lewis-
Check out my personal flying adventures: www.bayareapilot.com
om...
Hi,
bad thing...
Noah
Old November 14th 03, 07:37 PM
Peter Duniho
om...
Just remember to lean the engine. Technically, at that altitude you
theoretically wouldn't need to, based on the POH. But in reality, even
without the carb heat, leaning in cruise regardless of altitude is a fine
thing, and especially with the enrichened mixture caused by the carb heat,
it's nice for the engine.
Pete
Old November 14th 03, 09:41 PM
Roger Long
I just want to take this opportunity to totally, 100%, and unreservedly
agree with Peter
Roger Long
Peter Duniho wrote in message
om...
Pete
Old November 14th 03, 09:51 PM
Newps
noah wrote:
Hi,
bad thing...
The Cessna Pilots Assoc, in its systems and procedures courses,
reccomends that you use whatever amount of carb heat it takes to keep
the carb temp above freezing. You are doing no damage.
Old November 15th 03, 12:51 AM
G.R. Patterson III
No problem, but, as Peter says, lean the engine.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Old November 15th 03, 06:12 AM
Peter Duniho
"Roger Long" om wrote in
message ...
agree with Peter
I know you do that just to **** me off!
Old November 15th 03, 01:37 PM
Thomas Borchert
Peter,
Wrong. Most all POHs tell you to lean at any altitude AT CRUISE POWER
SETTINGS.
Thomas Borchert (EDDH)
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 12:33 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
Progress on Flying Car Steve Dufour General Aviation 5 December 19th 03 03:48 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
