Forward CG Experience
Old November 14th 03, 08:45 PM
Larry Fransson
On 2003-11-14 06:42:39 -0800, "Jay Honeck" said:
I opted for two notches of flaps.
That probably did a lot to help your landing. Flaps add a nose down pitching moment - something you don't really need with a forward CG.
We arrived firmly, in a flat attitude. The nosewheel and mains hit nearly
simultaneously, and the end result was more like a mush into the ground than
my usual "flare, chirp, chirp, settle...". It was surprisingly smooth, but
I realized that if I hadn't given that extra burst of power, and a firmer
yank on the yoke, we might well have landed on the nose gear, with possibly
expensive consequences.
Not necessarily. Sometimes, this is as good as it gets. I've had lots of nosewheel first arrivals in a Seneca (before I figured out the little flap trick). It's only a problem if you let it get out of hand by chasing the oscillation.
Old November 15th 03, 04:12 AM
Koopas Ly
Larry Fransson wrote in message news:2003111412455475249%newsgroups@larryandjenny .net...
Not necessarily. Depends whether you fly a low or high wing aircraft.
Old November 15th 03, 04:52 AM
karl gruber
******Not necessarily. Depends whether you fly a low or high wing
aircraft.****
Not necessarily. The old Piper Cherokee wing pitches down with flaps. The
newer Warrior wing pitches up with flaps.
Has NOTHING to do with wing placement!!
Karl
Old November 15th 03, 05:55 AM
Peter Duniho
"karl gruber" wrote in message
aircraft.****
Well, actually...
It has a little to do with the wing placement in that wing placement
certainly can affect whether flaps cause a nose-up or nose-down trim change.
Other factors are involved as well, so knowing the wing placement alone
won't tell you what flaps will do. But certainly, all else being equal,
moving the wing can change the way flaps affect trim.
Now, all that said...I don't think that's what Larry was talking about. The
trim change is usually a result of a combination of things, including
airflow over the horizontal stabilizer and elevator. But if I recall
correctly, flaps extended below the wing *also* create a pitching down
moment, always. This moment may be enhanced or obscured by other factors,
but it always exists.
Since trim changes often become negligible at lower airspeeds, this moment
can become more significant during the flare, even if the net trim change at
the normal flap extension speed would be nose-up.
At least, I think that's the point Larry was trying to make. I could very
well be wrong about what point he was trying to make, and I might have
misremembered this particular aspect of the aerodynamics of flaps.
Pete
Old November 15th 03, 08:46 AM
karl gruber
***** Has NOTHING to do with wing placement!!
Well, actually...
It has a little to do with the wing placement in that wing placement****
So true. I must remember, the words "nothing, always, never,...Etc" don't
get very far on usenet.
Best
Old November 15th 03, 03:19 PM
Larry Fransson
That was my point exactly
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
So Who Has More Military Command Experience, Bush Or Kerry? W. D. Allen Sr. Military Aviation 11 April 22nd 04 01:27 AM
So Who Has More Military Command Experience, Bush Or Kerry? W. D. Allen Sr. Naval Aviation 11 April 19th 04 05:12 PM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 05:50 PM
