Wire for homebuilts.
Old March 19th 04, 10:16 PM
clare @ snyder.on .ca
Default Wire for homebuilts.
I've come across a supply of wire at a reasonable price that I think I
want to use to wire my plane. It is NOT aircraft wire, but I have all
the spec on it. It is MTW (machine tool wire) AMW 1015/1230, FT1 and
VM1 rated. The 18 guage is 16 strand. Insulation is PVC (not
crosslinked) rated for -55 to 106C and 600 volts (1200 for
electronics) Some also has TEW rating.
It is wire designed for use in machine tool cabinets and appliances,
and is oil and fuel resistant.
Any reason not to use this? I have 3 colours of 18awg, 3 colours of
14awg, and 2 of 14awg. There is likely more available. It is non
tinned wire.
Old March 20th 04, 02:11 AM
David D Cowell
One good reason not to use it would be the PVC insulation. PVC when burned
gives off toxic fumes. Not the kind of thing you want in the cockpit at
altitude. I know you can't use PVC covered CAT 5 cable in common air
passages/ductwork like above ceiling tile because of this. We use "plenum"
cable that is Teflon coated I believe.
David D Cowell
Wildcat Computers, Inc.
http://www.wildcatcomputers.net
800-686-4685
clare @ snyder.on .ca wrote in message
tinned wire.
Old March 20th 04, 07:02 PM
On Fri, 19 Mar 2004 21:11:25 -0500, "David D Cowell"
Non plenum rated cable is VM2 of FT2
Plenum rated wire is VM1 or FT1 wire.
The wire I have is FT1 and VM1 rated -
Teflon when heated above 600F will cause "polymer fume fever" just
like PVC
Old March 23rd 04, 05:02 AM
Bruce A. Frank
When Teflon burns it creates the same problems as PVC.
David D Cowell
800-686-4685
tinned wire.
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
\(-o-)/ AIRCRAFT PROJECTS CO.
\___/ Manufacturing parts & pieces
/ \ for homebuilt aircraft,
0 0 TIG welding
While trying to find the time to finish mine.
Old March 23rd 04, 05:50 PM
Jay
I just saved a box of mil-spec teflon insulated wire from the garbage.
Check industrial surplus (or e-bay?) you can find partial rolls
because those kinds of companies are constantly getting rid of old
stock at the back door and buying new rolls at the front.
I've vaporized the PVC on a short circuit, made a big puff of smoke.
People are saying that teflon will do the same thing, but its going to
have to be hotter.
The teflon insulation is easier to work with because it does
burn/melt/shrink away when you're soldering a stripped end.
Regards
clare @ snyder.on .ca wrote in message . ..
tinned wire.
Old March 24th 04, 05:33 AM
Morgans
have to be hotter.
Regards
Do some searching on teflon toxcicidy. It starts being a problem as low as
500 degrees F.
Enough to kill birds, very quickly. How would that do for us?
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.629 / Virus Database: 403 - Release Date: 3/17/2004
Old March 24th 04, 06:18 PM
Jay
500 degrees F.
Being that we're sometimes called "birdmen" I guess it would be none
to good. I don't doubt that its bad for us too. I was just saying
that it seems to take more heat to turn into something you can breath.
Old March 25th 04, 04:01 PM
tongaloa
You could always run your wire through woven glass sleeve
if visions of vapor are standing in the way of progress.
Ceramic beads would work too but are heavier. Or if the airframe
is all non-conducting composite, or wood, just route bare wires
and don't worry about insulation. Of course you'll still have
the fumes/smoke problem if they get hot. Best is no wire. Just
send a kid out on the wing with a kerosene lamp or a burning handful
of straw(like the kid shimmying up the mast on the fishing junks in the
South China sea when the see your cable dragger bearing down on them.
Cable over nets like stone over scizzors or sail over power unless power
is dragging cable. Dragging cable has ROW over everything. You thought
flying was complicated.
Old March 25th 04, 05:51 PM
Richard Lamb
Or?
Design the electrical system with the corect protection devices
(fuses and/or breakers) so that it CAN'T catch fire...
Just a thought.
Richard
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Suitable coating for spring-steel wire? Wright1902Glider Home Built 6 February 9th 04 04:12 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 01:53 PM
Brace wire Tom Mathes Home Built 5 October 22nd 03 02:11 PM
Tefzel Wire, RG400 Coax, Crimpers, Terminals, etc.. Stein Bruch Home Built 0 September 20th 03 04:35 AM
